Question about Intel Asus P5GL-MX 800MHz FSB 915GL Chipset Dual Channel DDR 400 Socket 775/T ATX Motherboard with L... (MB77ASP5GLMX)
My CPU is starting but my monitor is not the light
My CPU is starting but my monitor is not. the light of my monitor is blinking on and off and i am getting no display
motherboard version P5GL-MX
  • 3,267 Answers
First check your input devices, the keyboard & Mouse. If they are OK, i.e. no bent pins or try a working keyboard & mouse. If the motherboard beeps more than twice then remove the RAM from the slot, clean the contact points. If that too does not work check all connections as snug-tight.Remove all hardware accessories except for the HDD. Use the bootable OS disc and reload the OS..............sodeep
Posted on May 12, 2009
2 Suggested Answers
sodeep
  • 3267 Answers
SOURCE: My PC is starting but the monitor is not starting
Monitor Not Powering On
Did you tried changing the lcd settings to default?
Feb 24, 2014 | Acer S231hl Bid 23" 1080p 5ms Widescreen...
Monitor goes blank and power light remains on and when i turn it back on, it stays on for about 3 seconds and goes blank again. thank you!
  • Turn on CPU.
  • CPU will be start booting. Red/yellow light will be blinking. If yes then check your monitor light will be fixing and Show *********** Board.
  • If shows and your OS will be Booting and fail to start.
  • If yes you can repair it.
  • Insert OS disk into the DVD driver.
  • Turn off PC.
  • Turn on
  • "Press any key........" when comes this message you press any key.
  • After that you can see two option
?? Fresh copy Installation OR
?? Repair Option
  • For Repair Press "R"
  • It will be start repairing
Thanks.
May 15, 2011 | HP Compaq WF1907 Monitor
When i push my power button on my flatscreen monitor, the power light will turn green then blink off for 2 secnds then blink on
Could you please explain more about your problem. Are you able to get your monitor working or is it that it keeps on blinking without any display on screen.
If your CPU is ON and then your facing no display on the monitor then the problem could not be with the monitor instead it could be either a loose RAM. Also check that the cables attached to the CPU is not loose.
Feb 06, 2010 | Microsoft HannsG HU171D 17" LCD Monitor
The system unit is started but the monitor is making black so, what is the problem , pleas tell me the solution
first check your monitor front power light blinking or not.
if it's blinking then then remove the signal cable to the cpu then check the company logo moving in the monitor.if it's moving means your monitor is OK.means no display in *********** board.
Jan 08, 2010 | Computers & Internet
Hi, my monitor does not display anything but the lid light just keep blinking.
You should check your display cable from CPU to Monitor. If it just blinking then problem with you connection bitween CPU and Monitor So just check and keep enjoy.
Nov 11, 2009 | Samsung SyncMaster 710N 17 in. Flat Panel...
AOC color monitor model 5En...during power on all led lights blinks then stops blinking without display action. all led lights on no more action observed.
actually if u repair an aoc monitor alone without getting connected to cpu once u switch on the monitor all led's will lit on ( green light ) it will remain on situation until u connect the vga connector to cpu that's the time led's will lit off and only the power led will remain in green condition.some aoc 5en once u power on power led is in green condition and if not connected to cpu it will be in orange condition.hope u get some idea but i am not sure if it will work with ur monitor. but as long as LEDs lit on i think no problem with ur monitor.
Nov 02, 2009 | AOC 5 En 15" CRT Monitor
Monitor looks as if there is no CPU
If the power supply is coming to CPU before activation of CPU then it must be receiving current from UPS. Don't try unplugging, You may get shock. Thank you, Sir.
Sep 17, 2009 | Computers & Internet
Dell flat screen started flashing, green light was blinking then screen went blank and green light is on. Tried unplugging etc...time for a new one?
No. It is not a Flat Screen issue. It is a CPU issue. You CPU is not sending signal to your flat screen so the green light is flashing. Try to:
1. Reset OR
2. Unplug the CPU case, Open the CPU, the interchange the RAM modules, OR
3. Same with step 2 but unplug and then plug back in all expansion cards like audio, video cards, etc.
It seems that your system needs discharging from a frozen state.
Regards!
Jul 26, 2009 | Dell E152FPc 15" TFT LCD Flat Panel...
Green light continously blinking in samsung sync master 753s
1. cpu problem. why because of there is no signal output from cpu to monitor. the led blinking means there is no vertical, horizontal signals from cpu to monitor.
2. your monitor connected to another system.
3. neck board dry points.
4. cheak the display cable. 13&14 pins are horizontal, vertical signals.1, 2, 3 pins , R G B , 6 ,7, 8 pins R G B ground ( coaxiler cable used , meshed wire is ground )
Oct 13, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
MOnitor Problem
Assuming the cpu is on, then the likely culprit is your video card or your onboard video. Either replace the exsisting video card or add a video card to your system.
Jun 16, 2008 | AcerView 76E Monitor
Computers & Internet Logo
104 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
