Question about Honeywell International Honeywell Universal Electronic Fan Timer St9120u1003
I can get the timer to start the boiler but it will not turn off its a hunnywell 20 years old with no serial number
    Scholar:
  • 152 Answers
Hi there, first of all you can try a simple test which will determine if the thermostat is faulty or not. With the boiler turn on or off simply turn the thermostat clock wise then anti-clockwise can you hear a click sound when you do this? if yes then, the thermostat is probably okay and the problem maybe a stuck relay which would require you to open the control panel on the boiler, keep in mind that the power must be shut off before you do this to prevent any chance of an electric shock , if the thermostat does not make any sound at all , then chances are that the contact points are welded shut in the on position and would require you to open the thermostat and release them (power off of corse) do not attempt to do this with the power on, if you feel that you are unsure of trying this then please contact a tradesperson in your area, if not then this how to do it.
With the power off take the cover off the thermostat, inside you will see a bi-metal strip with two contact points , try turning the knob an watch this contact point and see if is in fact opening the circuit, if you see that it is stuck , find a small flat blade screw driver and gently pry them apart, once this is done , inspect the contact point and lightly file it using a nail file , try to keep it square to the points so as to create a fresh contact point , do this to both or all points you can see, gently blow away the filing dust and replace the cover, turn it all back on and try it again, if it still does the same thing then replacement is imminent in which case you may either buy the part yourself (now that you know how to open it or contact a trades person in your area.
I hope this information helps you , but if it is not what you wanted or would like to chat live , give me a shout I'm on as often as possible so maybe i can help you even more ..
Posted on May 12, 2009
How do I fix a problem with my boiler not coming on?
Ive just resolved this issue on my own boiler...... Its the programmer ,replace it as the micro switch has gone , when it comes on the lights only come on the internal switch does not ,so no sognal to boiler , replace programmer
Aug 01, 2016 | Water Heaters
I have a Bosch Worcester 24i Combi boiler which is 4 years old, last year had problems with boiler not always coming on and had the circuit board replaced, now the boiler does not come on at all and the...
hello!
Thats is the problem of the boiler when the circuit had already replaced this will work but it cause another problems on the timer.
Please try unplug the boiler and replug it again to reset the setting . If not solve then maybe you should examine again the circuit board there might some parts that is not functioning.
melnavz
Mar 14, 2008 | Kitchen Ranges
Need the year of my furnance, have the model and serial number
manufacture can tell you year. what brand is it? goodman? my guess is 97 dec.
Feb 26, 2014 | Emerson Lennox Ducane Armstrong Furnace...
Vaillant boiler clock not working
your timer clock may need to be replaced.
Aug 12, 2017 | Water Heaters
The Maytag washer is 26 years old. The problem is
Sounds like the timer motor may be dead. Can you hear it ticking when it is on or can you see the gear on the timer motor shaft turning when it is running? If not then the timer should be replaced.
Jan 16, 2010 | Washing Machines
Hi R
There should be a middle position between O & I
check carefully - not much movement in needed
Oct 12, 2009 | Water Heaters
What boiler?
This is a test by FixYa Staff.
MODS - DO NOT REMOVE
Thank you!
Sep 22, 2009 | Combi Centre DX - Mango
Hi i hope youcan help me, i am trying to locate a gas valve for a fagor 15/20 combination bolier. The boiler is about 8 years old and is fitted in my caravan. Please can you help. Regards Jamie
I would bring the valve to your local appliance parts store. Likely they will be able to match it with a universal or after market valve. Make sure you write down the model and serial number of the boiler and bring it with you.
Jan 16, 2009 | Heating & Cooling
Honeywell International Honeywell Universal Electronic Fan Timer St9120u1003 Logo
187 people viewed this question
Top Honeywell International Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Honeywell International Hardware and Accessory Expert? Answer questions, earn points and help others
