Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Washer won't stop filling with water.
At the desired water level, it continued to overfill out onto the floor.Is there a switch that could have gone bad?
  • 27 Answers
There is a pressure switch with a tube to the water drain. The switch may be faulty or needs adjustment. The tube may be blocked or disconnected.
Posted on May 12, 2009
GE Super Capacity Plus won't stop filling
Does it stop if you stop the cycle or do you need to turn the valve off?
What is the complete model number of your unit?
Feb 17, 2013 | GE 3.2 cu. ft. Washer
When washer fills for wash or rinse it won't stop filling and over flows onto the floor.What do you think it is ?Is it a float problem?
Their are 2 possibilites causing it to overflow
1) the water inlet valve that the hoses from the house plumbing attach to is sticking open,when it sticks it will stick open regardless if thier is power to the machine or not,so to determine if that is the problem,start the washer and quickly unplug it,if the water continues to fill, that valve is sticking
2) the water level switch is defective,do the same as far as starting it,if the fill stops when power disconected it's the water level switch that is in need of replacement
Good luck, i hope this helps and if it does please give me a 4 thumbs up rating
Gene
Jul 29, 2011 | Roper RAX4232KQ Top Load Washer
Wont stop filling up. It will overflow with water
Hi
Thanks for using FixYa. Overfilling in your washer occurs mainly due to two things: water inlet valve going bad and/or the water level switch. If the water inlet valve has gone bad it won’t be able to shut off even when the electricity has been turned off. If the issue is with the water level switch then it won’t tell the water to shut off and the machine will overflow as this switch is to sense the water level in the clothes tub. However, with that being said it seems that you’ll need to replace the water inlet valve. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Frigidaire Gallery GLWS1339EC Top Load...
Does not stop filling with water
A machine that overfills or underfills can often have a faulty water level switch. It's a diaphragm like device with a small plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level increases, so does the pressure on the air in the plastic tube and when it reaches a certain level, it activates the switch to shut off the water. Make sure there is no damage to or obstruction in the plastic tube. The switch can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad switch. Really sorry for your trouble and I hope this helped. Best wishes.
Oct 01, 2009 | Washing Machines
What would cause the washer to overfill the tub?
If water is overflowing and you disconnect power to the machine. then:
A. It continues to fill: Replace water fill valve. (the part the fill hoses screw onto)
B. It stops filling: Most likely has a plugged tube from the tub to the water level switch.
Jul 27, 2009 | Washing Machines
Water level will not stop and floods floor
check the level switch by blowing on it if clicks is good if not replace the switch , make sure that the hose that connects to the switch is free of debri
Jun 18, 2009 | Kenmore 22422 Top Load Washer
Washer over fills and floods the floor
Morning. There is a Water fill level switch in your unit that monitors the level of the fill process. this switch is malfunctioning and, it will need to be replaced asap if possible.
Jun 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will not stop filling.
Remove the rubber tube from the water level switch and blow out the sand and stuff from the base of the tub so that air pressure can buildup inside that tube as the water rises. After blowing it out make sure that hose is tightly secured to the water level switch,
Mar 16, 2009 | Washing Machines
GE washer
mostly likely your pressure switch has gone bad or the hose has come loose from the pressure switch. open access to the console. your pressure switch is the water level. if the hose is attached, then the switch itself is bad. Joe
Nov 18, 2008 | GE Washing Machines
When washer is in super wash cycle water will not stop causingthe tub to over fill running onto the floor.
It sounds like you are trying to use the largest water level setting. If this is correct you may have a pressure switch problem.
First turn the timer to spin and get all of the water out, that start a washer cycle with the water level set to the small or low setting and see if the washer fills to this level. if it stops at the low level great Now if it continues to fill and does stop you may need a pressure switch or the hose needs to be replaced that runs from the tub to the pressure switch.
Now set at the medium level and try again. does it stop or over fill?
If it over fills you probably need a pressure switch however before you purchase this, make sure the hose is in good condition one pin hole will cause your overfill condition.
Jul 09, 2008 | Washing Machines
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
64 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
