Back to:
Tags:
Lexmark X83 All-In-One InkJet Printer
Lexmark X83 "Unlock Scanner" error (by 8 users)
posted by irmiux on Oct 13, 2007
When I plug the printer I get the message Unlock Scanner. I looked for solutions in Lexmark web site and I tried both posted. One, to move lock button in back up and down, unplug the device, wait one minute, plug it again; the other one, after lock, unlock and unplug, turn device in its left side, plug again, etc. Nothing worked. Same error as soon I plug it.  Does anybody have any other solution?
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
7 Other Users Have The Same Problem
Comment by djmac7539, posted on May 17, 2008
I have the same problem. I've tried unplugging power cord, USB cable, turning off power, flipping red switch on back, turning printer onto left side, reconnecting everything and rebooting. I've even uninstalled printer/scanner application and reinstalled it. Nothing is working!
Comment by bullfrog222, posted on Mar 10, 2008
every time i turned on the printer i get a unlock scanner,i have turned off the printer and unpluged the port,and had it at a 45degree angle
Comment by Guest, posted on Mar 03, 2008
Lexmark X83 keeps coming up "Unlock Scanner". I have unplugged the 2 on back of machine, unplugged from wall, disconnected and reconnected, turned power off ...sometimes it corrects itself but this time it is not.
Any solutions to correct this problem would be wonderful
Thank you, Diane
Lexmark X83 Printer/copier/scanner ....comes up with "Unlock Scanner".
I have unplugged from back of machine, unplugged it, shut power off and disconnected and reconnected ....sometimes it will correct it self but this time, it keeps saying "Unlock Scanner".
Any solutions to this problem would be wonderful!
Thank you, Diane @ rgofourth350@charter.net
Comment by Guest, posted on Feb 28, 2008
SAme problem
Best Solution
posted on May 04, 2008
Helpful (85)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I had this problem and am still getting it regularly
Lexmark support say remove power and usb leads take off loose top and take out papers turn it on its side and shake vigorously!
It works for me.
Best of luck...
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Lexmark X83 "Unlock Scanner" error:
I don't want to Accept this solution
Solution #2
posted on Mar 01, 2008
Thanks for Trying (70)
Guest
Rating: 0%, 0 votes
1 pulls out and it inserts a AC adapter again.
2 lifts the right of the printer by 45 degrees.
3 turn on power switch.
Thank You!
Solution #3
posted on Oct 23, 2008
Not Rated (0)
fwbailey
Rating: 0%, 0 votes
I had the same problem and the solution is this: There is a red lever switch by the power chord on the scanner/printer. Above this red lever switch is the drawing of a lock in the "locked" position and at the bottom this red lever switch is the drawing of a lock in the "opened (unlock)" position. The lever on the red switch should point to the "opened" lock symbol (unlock). It the switch lever is pointing to the "locked" position of the lock symbol, flip it to the "opened" position and recycle power on the scanner by removing the power chord for a 30 seconds. If the lever is pointing to the "unlock" lock symbol, flip it to the "locked" position and then back to the "unlocked" position and recycle power. Good luck!
Thank You!
Solution #4
posted on Apr 27, 2008
Not Rated (0)
VS2008
Rating: 0%, 0 votes
YOU ARE NOT GOING TO BELIEVE THIS!!!! I HAVE A 5150 LEXMARK. IT HAS BEEN SAYING UNLOCK SCANNER.
I FIXED IT BY LIFTING THE COVER (AS IF CHANGING THE INK CARTRIDGES) THERE IS A LITTLE RED LOCK DEVICE RIGHT NEXT TO THE BIGGER LOCK DECIVE (USED TO HOLD THE COVER UP TO CHANGE CARTRIDGES). THE LITTLE LOCK WAS PUSHED UP, I PULLED IT DOWN, CLOSED THE COVER AND VOILA! FIXED!
Thank You!
Can you Help with these Printers problems?
The black side prints with occasional overlapping lines...
Paper jam. When I use my printer paper is jam and goes at...
trying to fax multiple pages...it will only scan one page...
7 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Dec 17, 2007
Unlock Scanner and nothing works
Comment by Guest, posted on Nov 06, 2007
I Keep getting 'unlock scanner'. Printer will not work.
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
