First check your input devices, the keyboard & Mouse. If they are OK, i.e. no bent pins or try a working keyboard & mouse. If the motherboard beeps more than twice then remove the RAM from the slot, clean the contact points. If that too does not work check all connections as snug-tight.Remove all hardware accessories except for the HDD. Use the bootable OS disc and reload the OS..............sodeep
SOURCE: my CPU is starting but my monitor is not the light
One of 2 possibilities come to mind.
1, The vga chord is loose on the back of the monitor.
2, Your resolution is set too high or low to be displayed.
The blinking light means that the monitor is either not getting or understanding a signal.
Hope this helps.
No display on my monitor but have power
No keyboard display
There is power on the power supply
there is power on the motherboard as indicated by the led attached to it
All the fans have power...BUT I STILLL DONT GET DISPLAY
