Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Caloric gas stove prestige series
I tried to set the clock and while doing so (no manual) The oven no longer works.  The pilot light works but the oven won't light.  The broiler works.
Someone told me it had something to do with the timers not being set right.
HELP PLEASE
  • 1 more comment
  • philco326 Jun 21, 2008
    i need to change my gas range from natural gas to work with porpane gas. what part must i change.
  • Mike Martin Aug 15, 2008
    Hi I just recently have started to have the same problem. The broiler in the oven works. The range top works. The oven takes forever to light. When it does ( if it does), it never gets to temp ( for the sake of discussion) say 350F. In looking at it further, the oven burner will light and it seems that it goes off shortly after it starts.
    I have seen notes about the timer being improperly set. However, I must apologize, I am not quite sure what that really means. I would really appreciate some input.
    Thank you and have a great day.
  • Lawo Jan 26, 2009
    I recently experienced the same problem. Any suggestions?
    Problem Solver:
  • 15 Answers
To jenna 12 Does your stove have a stop and start timer? When you set your clock you may have inadvertantly moved the stop or start time on that timer. Check them, if they have knobs for setting the stop and start time, make sure the pointer is pointing to the current time and that the knob is popped out and not stuck in. when you have it right both the stop and the start knob should be out, not pushed in. They will pop out when you turn them to the current time.
These timers allow you to start something cookin at a time delayed several hours. this means they will not allow the oven to come on until it hits that time that you may have set in error.
If your stove has a digital stop and start timer check each one so that both show the current time, then your oven should light.
Posted on Oct 07, 2008
Caloric gas range shows error code f-5
Posted on Jul 29, 2009
My one spark ignitor on my stove top comes on by itself and keeps clicking till I pull the plug. It will reset itself and stay off for awhile then it will come on by itself again sooner or later. What is the problem??
Posted on Sep 30, 2008
Can not light the pilot light for stove top or broiler
Posted on Nov 18, 2009
HELP PLEASE
Posted on Sep 12, 2008
  • carlbouie Sep 12, 2008
    the oven doesn't work
  • 833 Answers
To get your manual go to: http://www.geappliances.com/service_and_support/
If you have a timer issue, simply open your circuit breaker for the stove and then turn it back on. That should fix the clock issue and get you running.
Posted on Dec 13, 2007
How does light cover come off on inside light
Posted on Dec 02, 2009
How to light pilot light with sealed broiler oven
What make and model is it? I maybe able to help.
Aug 25, 2016 | Kitchen Ranges
Finding the flame pilot on a caloric prestige series gas stove
There is no pilot. The igniter is in the oven cavity under the floorpan. This is a picture of the regulator and gas valve- the wire nuts at the top of the pic just left of center are on the leads that go to the igniter...
Jun 26, 2016 | Kitchen Ranges
Why won't the gas oven heat? The oven won't light and gas is not leaking when I turn the oven on.
does it have a pilot light or is it electronic ignitor . might need ignitor replaced
Jul 23, 2014 | Ovens
I have a Caloric Prestige series gas range. I don't have the manual and the clocks on the oven which allows you to set a start and end time for oven cleaning (I think that's what the clocks are for) do...
best thing you can do is to search for the manual of the unit either on the net or on the website of the merchant that sells of manufactures these units. Doing anything improperly might render the unit useless or if overdone, it might clog the heads and cause not to work, or worse, to clog and cause a build up and possibly an explosion. Don't mess with gas, do it properly and safely.
Nov 18, 2013 | GE Kitchen Ranges
Broiler works. Oven does not
Plugged gas pipe which connects to the burner.
Jul 04, 2013 | Tappan Kitchen Ranges
Oven won't light
ck thermal coupling see if its to far from pilot light or burnt out
Feb 18, 2012 | General Ovens
When i turn on oven all i smell is gas i cleaned with a wire brush still nothing. also is the pilot light always have to be on and can you see it when oven is off
Most gas ovens that aren't electronic ignition usually have a pilot light.
Usually one in the oven area and one for each burner. (Sometimes shared between two burners.)
These pilot lights must lit at all times...otherwise it won't light up and you'll smell gas.
Usually the pilot light is in the very back of the oven and can be seen with the broiler drawer opened.
There is a small set screw located at the pilot light assembly in the oven and also at every burner.
This allows you to adjust pilot light up or down, thereby letting you set pilot light flame to a level that doesn't get blown out by a draft...or you can turn it off completely.
If you use that set screw to turn off the pilot light gas, you'd need to strike a match to light the oven or burners everytime you needed them.
Jul 17, 2011 | Ovens
I have a 1965 gaffers & sattler wall oven with the oven on the top and the broiler on the bottom. It began having issues lighting even though the pilot light was on. Now the burner doesn't light up at...
My Mom has a 1965 Gaffler & Stattler Mark 21 wall mount oven, it had the "Same Problem", People may tell you that the flame switch is no longer avalible but I found a universal fit flame switch at Applance Parts Center, I took the old part in and had it matched up, with a minor modification to the thermal sensor mounting bracket, "drilling a larger hole and lightly crimping it", it's a perfect fit, "problem solved". You may want to try cleaning the pilot light area with a small wire brush first, if that dosn't work try a jumper wire on the two terminals of the flame switch, if that works then replace the flame switch.
This operation can be done without removing the oven from the wall mount, just remove the two screws from the panel at the inside rear of the broiler, you will find the flame switch behind the panel it has two screws two wires a thermo leed and a sensor tip that goes up to the thermo sensor mounting bracket above the pilot light, the thermo sensor mounting bracket has one screw and a nut behind it, you will also need to remove one end of the 1/4" pilot gas pipe in order to remove the thermo sensor mounting bracket, When your done puting it back togather, check for gas leaks using soapy water in a spray bottle, a dish soap solution works great, also check your vent pipe connections.
After I cleaned the dust and grease out of this old thing, the 45 year old clock and timer started working again.
My Mom is very happy, try and find new oven to fit the cutout and vent, we saved a lot of $$$,
"Good Luck".
Nov 18, 2010 | Ovens
I just moved into an apartment that has an older Caloric Prestige oven and range and cannot find the Pilot light--Please help
Hi, The caloric ranges use diferent types of pilot igniters, to avoid any further delays, I suggest geting the model number off the stove usually located under the stove's top, you don't need any tools just lift the range top(like when you are going to clean it) the model number is located usually on a metal plate in between the burners, or if it's not there , it will be inside the oven around the door liner or the oven liner. When you do locate the model, just go to the repair clinic.com website and type in the model number, follow instruction after that. see the following figure it might help in locating the model number: small_13_4.jpg
Apr 13, 2010 | Ovens
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
5,127 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
