Tried to turn my Samsung sp43w6hf on. Nothing happens. Power LED turn from green to red when turned on with remote. No picture no sound. The LED will not turn back to green when the power button is pushed but stay red. Help please?
  • 1 more comment
  • yougos May 12, 2009
    I also noticed that the heatsink on the main audio amp gets very hot as well as the metal bar that it is bracketed to.
    I do own a service manual for this TV.
    Thanks for the replies.
    I am new to to Fixya and was not sure how much I can post.
    Before I posted I did the following:
    Checked fuse although I knew it wasn't the problem since the front LED goes.
    Checked solder joints.
    Had TV unplugged for more than a day.
    Saw all 3 CRT's light up, albeit very faintly.
    Tried to isolate (unplug) some areas of PCB.
    Looked at the huge capacitor and realised, aint gonna go any where near that thing!
    Scratched my head countless times.
    Realised that getting it repaired will cost me half the price of a new LCD.
  • yougos May 13, 2009
    As the cost of getting this repaired is not economical viable compared to the price and guarantess of a new set, I will just go and buy a non-rear projection TV.
    Thanks for trying to help.
    President:
  • 1,197 Answers
Yes i belive thats the best option for u.... as u might know from the service manual .... u might need to replace a lot of parts and the parts for projection tvs are not very cheap..... say alone the service charges
good luck with ur new tv....
thank you have a nice day
Posted on May 13, 2009
    Genius:
  • 1,847 Answers
If you're NOT still under warrantee you should at least open the TV and look for a blown fuse near where the power cable enters the set. A lot of times you can buy replacement fuses at a local electronic or hardware store and they're easy to replace.
Check the fuse. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again, or if it is not blown, your problem is probably in the 'X' volt regulator and you will need professional help with the repairs.
You can also check the board where the components are mounted and resoled any that look bad. Brief power outages may cause the TV to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet.
In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer.
All can be replaced at a local electronic or hardware store and they're easy to replace
If this does not correct the problem, you may need to have your TV service.
Thanks
Kevin
Posted on May 12, 2009
  • 916 Answers
It sounds like you may need to replace the power supply board. The red light you are talking usually indicates this type of problem.
  • 13,433 Answers
Unplug the set for a hour and try again if the problem comes again then the set is on protection mode (standby led on or blinking) and simply won't turn on due to a fault that it has detected. most cases will require the help of a professional tv repairer to get solved. An expert has to test and analyze the set to find the fault from the tv.
a tv has deadly voltages inside even when unplugged and home user repair is never recommended.
I have samsung plasma tv hpp5071x/xaa when i push the power button with remote control, i can hear cliking sound and looks like turn on and see red led light at the bottom right corner and also saww flash...
Hey If you have tried Using remote and side pannels Have you tried another TV to see if its the Cable? Also The clicking sound is normal its the TV's Power-source starting. The fan light I am not sure of but if it happens every-time it should be normal. If the screen gets warm Instantly (Hotish) Then you TV is dead D:
Mar 14, 2014 | Samsung PN42A450 Plasma TV
Samsung LCD TV 26
If you have not tried it you may want to see if the voltages listed come up with boards disconnected from the power supply one at a time---This could be anywhere from micro to the panel.
Mar 25, 2012 | Televison & Video
No picture or sound
Does anything start to work? Any of the three fans start to turn, Lamp ignite, etc., when you press the power button or does nothing happen before the Red LED starts blinking. How many times does the RED LED blink?
Jul 25, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Green power light comes on for a split second, then red.
The power supply (AC adapter) is bad. It has enough power to light the red LED, but not enough to power the TV.http://shop.ebay.com/?_from=R40&_trksid=m38&_nkw=12+volt+5+amp+power+supply&_sacat=See-All-Categories
May 23, 2009 | Proscan 19LA25Q 19 in. LCD Television
Wont turn on
I have the same problem. When I push the green button nothing comes on - just the green LED keeps blinking.....could you manage to find the solution
Sep 28, 2008 | InFocus User guide, LP500 / 530 Projector...
Televison & Video Logo
85 people viewed this question
Top Televison & Video Experts
Electro Med Services...
