Question about ASUS P5GL-MX Motherboard
PC PROBLEM My PC is is starting but monitor is not the light of my monitor is blinking on and of but there is no display so what should i do
  • 3,267 Answers
First check your input devices, the keyboard & Mouse. If they are OK, i.e. no bent pins or try a working keyboard & mouse. If the motherboard beeps more than twice then remove the RAM from the slot, clean the contact points. If that too does not work check all connections as snug-tight.Remove all hardware accessories except for the HDD. Use the bootable OS disc and reload the OS..............sodeep
Posted on May 12, 2009
2 Suggested Answers
sodeep
  • 3267 Answers
SOURCE: My PC is starting but the monitor is not starting
Blinking with no signal video displayed,also blinking picture after started windows
"no signal" means exactly that. You monitor is not receiving signal from your PC. Recheck the video cable on both the monitor and the PC, make sure they plugged in properly.. Also try another monitor if you have it, and if it works with that monitor than more likely you have a frequency sync problem. In this case, using another monitor that works, and try resetting the video to basic 60Hz. In Windows, Start->Control_Panel->Display. Change the display resolution to the lowest, apply the setting, then change the monitor back to the questionable one. If it still doesn't work, then your video processor on your monitor is bad; RMA it if it's still warrantied.
Blinking picture problem, try suggestion above.
May 30, 2010 | ViewSonic VX1935wm LCD Monitor
The system unit is started but the monitor is making black so, what is the problem , pleas tell me the solution
first check your monitor front power light blinking or not.
if it's blinking then then remove the signal cable to the cpu then check the company logo moving in the monitor.if it's moving means your monitor is OK.means no display in *********** board.
Jan 08, 2010 | Computers & Internet
Lg monitor studioworks e 700, ligh is blinking
The most likely cause of your problem is your display card and not the monitor. If the monitor led is blinking there is most likely no VGA signal being sent to the monitor. Plug your monitor into a PC that you know is working and check to see if it works through the other pc.
Let me know if this solves your problem.
Best wishes,
Graemevm
Aug 17, 2009 | LG Studioworks 700S 17" CRT Monitor
Power problem
low power consubtion first on ur moniter then cpu
Jun 19, 2009 | Acer AL1717 17" LCD Monitor
There is no display on the monitor screen. The amber light on the power switch keeps blinking uselessly!
The monitor requires service The monitor is not receiving a signal from the computer
Apr 15, 2009 | Computers & Internet
Why is my Monitor blank when i switch on the pc?
Normally, blinking indicator lights and no display on the monitor indicating a wrong resolution or refresh rate frequency, that the monitor can not display it.
To fix, enter safe mode, and configure the display to the lowest resolution. After restart, you should be able to have the display.
Dec 31, 2008 | Intel D945GCCR Motherboard
Black screen, blinking power light, no signal
Hi...there,
It's seems you got a defective DVI card. Try using a VGA cable instead. Have nice day!
Aug 22, 2008 | ViewSonic VX924 19" LCD Monitor
Monitor not coming up
try unplugging the monitor cable from the computer and check if you get a power on self test displayed
if yes then the monitor is fine we have to troubleshoot the computer
and if nothing is displayed the monitor needs to be replaced.
Jun 05, 2008 | Dell OptiPlex GX260 PC Desktop
Blinking lights when PC is turned off
This works if you boot the monitor with a pc, open the osd menu and go to reset. reset the monitor.
Dec 08, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
ASUS P5GL-MX Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
