Epson Stylus C43SX InkJet Printer
Problem for Epson Stylus C43SX InkJet Printer
Green and red light flashing
By pepita219 on May 12, 2009
what is the ssc function on the epson c43
Comments:
May 13, 2009
- The red and green light are still flashing I downloaded the ssc and followed your instructions, is there some other reason for the flashing?
May 15, 2009
- hi thanks for all your help but it is still not working, I did reset the counter and it says 0 so as you say maybe there is something else wrong it is an old printer and I use it a lot???? the poor thing is probably just knackered again thanks for your help
Solution #1
posted on May 12, 2009
Somewhat Helpful)
gwbm
Rank: Guru  Epson Expert
Rating: 89%, 158 votes
Both green and red lights flashing usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
http://www.ssclg.com/epsone.shtml
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (C4x), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. Check the current count value - if it is greater than the limit shown it will confirm this is your problem. Then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
Comments:
May 14, 2009
- Hi there
Did you check the protection counter has reset to zero? Also, did you turn the printer off and then on again? If the answer is yes to both these, then the printer has a fault of unknown type. You will need to dismantle the printer to investigate further. But PLEASE check you have carried out the protection counter reset properly, because I have never heard of any other fault causing the two lights to flash.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Somewhat Helpful)
jayzee140
Rank: Wiz
Rating: 85%, 28 votes
SSC Service Utility allows you to do many things to your Epson printer, Work directly with CSIC in Epson Stylus printers cartridges, Freeze internal ink counters, Reset internal ink counters even with empty cartridges, Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode, Hot swapping of cartridges supported, Resetting of protection counter (even then it is already full), More then 60 different Epson printers supported This allows many people with high printing demands to save money (program works with both black and color cartridges).
Was this helpful?
Yes
No
Popular Solutions for Epson Stylus C43SX InkJet
Questions and Unsolved Problems for Epson Stylus C43SX InkJet
Do you recommend Epson Stylus C43SX InkJet Printer?
Answer
Answer
The printer c43sx cartridge aren't moving properly bothside tell me how can i slove this problem
Answer
Hi, I have Epson C43SX printer; I did not use the printer fro sometime. I changed the Cartridge; but... (More)
Answer
Epson Styus color 440 i just replaced black ink cartridge, printer goes thru all the motions but... (More)
Answer
is there possible solution to reste without software?
Answer
hi! I was printing happily with my C43SX printer at 3 pages of draft output printed successfully,... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Epson Stylus C43SX InkJet...:
Top Printer Experts
Rank: Guru Guru
Solutions: 800
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
