Question about Garden
I have a Countax K14 ride on mower the cutter deck
I have a Countax K14 ride on mower the cuter deck wount rotate belts are intact and running flick the switch and nothing?
  • Anonymous Mar 12, 2014
    having trouble getting the belt back on
  • Anonymous Mar 13, 2014
    How to set up cutter deck on T1600M
  • 246 Answers
Hello ianh_2007:
Usually this Problem is Caused by a Blown Fuse or a Bad PTO Ground.
1-The Following is a Basic File I Made for Checking the PTO (Blade Engagement).
>>The Most Common Cause for this Problem is the PTO Ground. >>A Quick Ground Check is to Use Another Wire and Ground the PTO at the Harness Connection Nearest the PTO.
>>Be Careful and Do Not Ground the HOT Wire. Use a Multimeter and Locate the Ground Wire.
>>Clean the PTO Ground and All the Connections for the PTO Wiring Harness.
>>If you have an Ohmmeter, Disconnect the Wiring Harness from the Front of the Clutch and Check the Resistance of the Clutch. You should have around 4 or 5 OHMs. If at or near Zero, the Coil has Shorted.
2- >>The Following is a Basic File I made for Setting the PTO Clearance. Any Input is Appreciated. **Some of the Newer PTOs cannot be Adjusted.
>>If you can Get a Blade Style Feeler Gauge between the PTO Magnet and Clutch, then Set the Clearance at .015in. The Newer PTOs have the Same Set Up as the Older PTOs, except there is No Adjustments.
>>I Suggest also that you Rig a 12 Volt Light for Testing the Current Flow to the PTO while Operating the Mower. If the Light Blinks During Operation, then you have a Bad Connection somewhere to the PTO Clutch.
>>If the Light Stays Steady and the PTO Still Kicks in and Out, then it is the Adjustment.
>>You can Also Try Turning the Spring Loaded Adjuster Nuts 1/4 Turn and Operate the Mower. Do Not Adjust Over 1/2 Turn.
>>If you have Adjusted to 1/2 Turn and the Problem is Still Present and you Know the Voltage to the PTO is Steady, then Replace the PTO.**
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 12, 2009
Hi i have a countax ride mower when you engage cutter the belts turn but blades are not cutting just folds the grass please help
Posted on May 15, 2011
I need parts for a T1200 Westwood ride on lawn mower,cant find
Westwood Parts ' eBay
www.ebay.co.uk/bhp/westwood-parts
Find great deals on eBay for Westwood Parts in Lawnmower Parts and Accessories. Shop with ... COUNTAX WESTWOOD Parts Garden Tractor Breaking For Parts ... Westwood Countax T1200 Ignition On Off Starter Switch Repl Part No/ 1649.
BREAKING FOR SPARES WESTWOOD T1200 1400 RIDE ON ... - eBay
www.ebay.co.uk > Garden & Patio > Lawnmowers > Lawnmower Parts & Accessories £0.99 - ‎In stock
Breaking for parts - Westwood T1200, 1400 & 1600 years 1987-92. ... Ignition Starter Switch Fits Some WESTWOOD T1200 Ride On Lawnmower 1649.
Westwood Tractor Spares - Largest Genuine Spare Parts Dealer
www.westwoodtractorspares.co.uk/ Genuine Westwood spare parts dealer. Huge range of parts in stock for all models including T Series, S Series, X Series, W Series, V20/50 Series. We ship ...
Westwood T1200 Ride on Tractor Mower Parts
www.japgmowers.co.uk/westwood-t1200-ride-on-tractor-mower-parts-56-c.asp Mower Deck Parts Parts, spares and accessories for Westwood T1200 Ride on ... Westwood S1200, T1100, T1200 PGC Sweeper Grass Collector Drive V Belt ...
Westwood Parts - Buyamower.co.uk
www.buyamower.co.uk/category/westwood-parts.aspx Genuine Westwood Spare Parts. ... At Buyamower, we are Westwood main dealers and as such we stock thousands of ... Westwood Lawn Tractor Blades.
Westwood Parts Manual : Beltingonline.com, Supplier of power ...
www.beltingonline.com/garden...belts.../westwood.../westwood-parts-manual-850/ Beltingonline.com : Westwood Parts Manual - Rubber Timing Belts Garden Machinery ... Westwood Tractors Parts lists for ALL Models by year of manufacture ...
parts for T1200 Westwood ride on lawn mower Google Search
Apr 01, 2017 | Garden
Snapper NXT236 keeps twisting and breaking mower deck belts
check for failing cutter shaft bearings , misalignment of pulleys , incorrect belt tension, wrong section belts in use
breaking belts is an indication of the belt going around a pulley and flexing against the belt fabric structure ( bending backwards as opposed to running properly in the groove) which indicates that the tension pulley is on the wrong position on the belt
Jul 14, 2016 | Snapper NXT2346 46" 23HP NXT Lawn Tractor
Countax k15 need to tension the cutting blade belt how do i do this
there should tension pulley on the deck if its tight replace streached belt with new one that is what is w2rong not unless your pulley tesnioner spring broke the n replace that
Sep 03, 2014 | Garden
Replace cutter belt for a Victa Pro 12 ride on
Contact dealership/service center or buy a service manual online
Jan 25, 2014 | Garden
Ride on mower can ride around but whe engage fanbelt for cutter motor stall no power but very thing does turn easy with hand
Sounds like your mower deck safety switch is bad..it is located near the end of the handle that engages the mower deck..try unhooking it and bypassing it with a wire or heavy paper clip...then try mowing if it mows that is your problem..the mower deck will,operate that way but is a safety switch..you need to get it replace,,easy to do yourself..good luck.
Jan 09, 2014 | Briggs & Stratton Garden
Countax c400h noisy when engage deck
In all likely hood, you have a bad bearing on one of the blade spindles. A very common problem and a easy repair. You don't have to replace the whole unit. You can just take them apart and put in new bearings ( upper and lower ). The bearings have numbers on them nand you can get them at any bearing store.
Jul 05, 2013 | Garden
Where can I get a replacement cutting deck for a Countax K14 tractor mower?
Not sure of your geographic location but here is the contact data for Countax:
http://www.countax.co.uk/contact_us.htm Call them using the 0800 number on the linked page.
Parts link:
http://www.greenstripe.net/Parts-diagram/Diagram-405_Page-1.aspx
60 32726700 36 IBS DECK SHELL £300.11 view 60 32726601 38 IBS DECK SHELL £301.75 view 60 32726500 32766500_34 £302.82 view 60 32732500 48 DECK SHELL £265.49 view
If you not in the UK, I need to know your location please to locate other sources in your area.
Thanks for choosing FixYa,
Kelly
Aug 24, 2011 | Garden
My countax C300H starts OK but when I engage the cutters it immediately cuts out. If I let the engine run for 10 minutes then engage the cutters they usually work ok but this is pretty annoying. Is there...
Just got one of these mowers myself - accidentally got a large stone caught in the blades which caused the same problem. It looked to me that there's a sensor on the flywheel that cuts the motor if the blades aren't rotating freely. You might find either that the sensor is broken (check it by pulling off the connectors and connecting them together) or that the blades aren't rotating for some reason.
Mar 26, 2011 | Honda Garden
The cuters wont drive under load
My name is Dane and I am going to try to help you solve your problem.
I believe you have a worn and stretched Mower Deck belt. You may have to remove the mower deck in order to replace the belt. More information for you is hard because I don't have your model number of your mower.
I hope I've helped. If you found this information useful, please leave me some THUMBS UP if deserved. Thank you! Dane
Dec 09, 2010 | Garden
Garden Logo
2,008 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
