Washing machine wont empty removed screwable filter all water ran out still wont empty
  • 27 Answers
This is a comment problem. The drain pump may be broken or jambed with lint from the clothing. Remove the pump and check its operation. I usually just replace the pump as they dont last.
Posted on May 12, 2009
Machine is getting stuck and wont go into spin cycle.
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. While it's trying to get the water evacuated, you will probably see the machine doing a slow tumble for up to 8 minutes and you may also hear the empty pump running too.
You need to locate and clean the filter. Depending on the model (You haven't stated the model here, so I can't be sure) there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom) Many models of this design also have a small hose to the right of the filter cap that you can pull out, remove a plug from and drain off any water in the filter before you remove the filter and get your floor wet, so take a look for this before you remove the filter and get soaked.
Jul 28, 2011 | LG Washing Machines
My mastermind 708 dosen't spin after wash cycle.It spins fine in the wash cycle but dosen't drain water or spin in the spin cycle.Pease help
Your empty pump filter is blocked with debris. If it can't evacuate all the water then it wont allow the spin cycle to start. Locate the filter (probably behind a little door at the botton of the front of the machine). Remove, clean and remove the debris, re-fit and all will be well
Jul 01, 2011 | Westinghouse Washing Machines
It doesn't empty the water from the bottom wondering if i need to clean the filter ?
Yes!
You should be cleaning the filter regularly anyway (Between 1 - 6 months depending on usage of the machine)>
If there is water in there now that wont empty, pull the machine out and tip it back 45 degrees sop you can remove the filter without the remaining water spilling out all over you and your floor
May 27, 2011 | Washing Machines
What does error code 2 means on proline washing machine
With mine when i had the error 2 code, it was money in the filter.
Switch machine off
I had to get a baking tray and a towel, i pu tthe baking tray under the filter corner, then slowly unscrew the filter (bottom right front of machine) then let water slowy trickle into baking tray and then empty, and repeat until water stops took about 20 mins. Of course you could do it quicker if you want to flood your kitchen. :)
Then emptied the filter, then ran spin only until end. worked fine after this.
Apr 11, 2011 | Washing Machines
Washer won't drain
When you removed filter did you get any water out? if not then the pipe from the bottom of the tub to the pump may be blocked.If water did come out from filter then your pump may be gone. To do this you need to remove rear panel to gain access to pump.Check washing machine spares before you start removing pump as some people think they need to remove all filter for replacement. This is not often the case. Try and view your pump online and this will give you some idea of what to remove.
Mar 09, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
Wont spin
Probably down to the water not emptying from the machine in the empty cycle and the machine won't spin because there's still water in the drum. If this is the case, the root of the problem is almost certainly a blocked filter, restricting the draining of the water and not allowing it all to pump out in time during the empty cycle. You probably need to find and clean your filter.
Feb 02, 2010 | Washing Machines
Door locked and will not open. i ran an empty cycle to see if that would work and it doesn't.....thanks! Margit
IF water is left in machine then door wont unlock, check pump, run drain cycle. If pump runs but doesnt remove water, then check filter at bottom (small door on bottom front) water will come out when this is done. If washer is completely empty of water and door locked then you may access lock release tab from bottom or reaching down from top to lock asm. Then check lock
Jul 19, 2009 | LG WM1814CW Front Load Washer
Hotpoint dwf 30 - Water wont empty
if the drain is plumbed into a spigot on the sink trap, then this spigot is blanked off to prevent water coming out when you empty the sink. remove blank
Aug 31, 2008 | Dishwashers
Washing Machines Logo
110 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
