Question about Pioneer XM2go Inno Satellite Radio Receiver
Unable to hook my Panasonic inno to my car stereo
According to the instructions on my inno, both the CD-INHOME2 & CD-INCAR2 install guides, I'm supposed to to press the "XM" button, select "Settings" and then select "FM Modulator" to program in the radio station that I'll be using for my inno. One little problem: Under "Settings" there is no "FM Modulator" to select, only "Preferences" and "Setup". Under these there's nothing else that solves my problem. Help me please. I'm beginning to hate this little paperweight.
I'm having the same problem. Still no solution???
Posted on Nov 26, 2011
All you have to do is remove and re-install the battery. This clears the glitch and the FM modulator menu will re-appear.
Posted on Aug 21, 2011
  • Jessica Morris Nov 26, 2011
    This did not work for me.
Same problem as otter3. all wires disconnected and still no modulator. The quick ref guide says that i must have the car adapter yet i am told the inno has its own modulator. what gives?
Posted on Feb 02, 2010
Not sure if this will help but I noticed that the modulator won't show up if you have your head phones, ear buds, cassette adapter etc. hooked up. Unplug any line out and see if it helps.
Posted on Jan 17, 2008
I have a Panasonic CQ-RX400U and I need to hook it up to a 1992 Ford Taurus and I need cables to hook it up and the thing that holds it in place in the dash.
I would get an stereo installation kit from Auto Zone or a local automotive audio store. It will come with the surround for the new stereo to fit where the old stereo went, and a wiring harness to hook the new stereo up to and plug into the existing car wiring.
May 20, 2010 | Panasonic CQ-RX400U Car CD/ MP3 Player
Unable to select auxillary input
its xm ready shouldnt need to use rcazzz
Jan 07, 2009 | Panasonic CQ-C3301U CD Player
Pioneer inno radio-doesn't work in car
When its in the car dock, the Inno sends an FM signal to the car radio. It does not receive a signal from the car radio. You must have the external antenna correctly installed outside the vehicle for the Inno to work. The built in antenna is disabled when the device is placed in the car dock. Make sure to test it outside, since garages or car ports will block the signal.
Dec 03, 2008 | Pioneer XM2go Inno Satellite Radio...
Problems with the panasonic cd stereo system
problems with the panasonic cd stereo system for some days.
The model no is SC- AK640 and i have been experiencing such problems such as "F61" and in the operating guide it says to check and correct the speakers cords i have done that but the problem can not be fix so please if you can assist me that willl be great thank you
Aug 31, 2008 | Panasonic 5 DVD/CD Micro System with MP3,...
Pioneer Inno
Rick,
You can connect the inno via the home doc and the provided cable in the home kit. You may have to connect to an unused component on the receiveer (VCR comes to mind)...You move the VCR source on your receiver and you should be good to go.. I have a Pioneer Elite receiver but Pioneer makes no cable to connect those two ..no matter... I wanted to control the Inno from outside the receiver's controls..
Sam
Nov 23, 2007 | Pioneer Audio Players & Recorders
Car stereo installation
I had this problem as well. On my harness was a wire for connecting the factory amp. You have to connect the Automatic Antenna wire to the Factory Amp Turn On wire. Should be a blue wire to a blue wire with a white stripe.
Oct 15, 2007 | Car Audio & Video
Panasonic cq-c8303u Car stereo problem
There is for sure a hook up problem my friend. There should be a memory wire that always has power to it even when the car or the ignition is off. Then there is a switched type wire that only comes on when the cars ignition is on. Check both of these wires in the car. Check the car wiring diagram to confirm this. To confirm the wiring in this vehicle, I Good Luck with this install. And if all else fails, don't take a chance and blow out the unit, take it to a pro to be installed. Good Luck found the right wiring diagram for your car. Confirm this wiring diagram with this one you have. Go here:http://www.the12volt.com/installbay/stereodetail/955.html
Jun 19, 2007 | Panasonic CQ-C8303U CD Player
298 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
