Question about Olympus mju 740 Digital Camera
Bad compressing pictures by mju780
I have Olympus Mju780. After I made the photos, some pictures are not compressing good by the camera. I can see them in the camera (even on TV), but on PC they are not completed (I can see only few first lines). Does some body recognize this problem? How I can repair those pictures? Is there some special software I should use?
jackboy
  • 2985 Answers
SOURCE: Olympus FE 240 - downloading problems
Remove the Software
Restert the Computer
Plug camera in and turn on set it to the upload mode.
Windows will then fid it via the Camera/Scanner Wizard.
If there is still a problem
A cheap card reader will do the trick
Posted on Dec 28, 2007
  • 15 Answers
SOURCE: Computer not recognizing Camera
Are you always using the same USB-port on your PC? If yes try to use another USB-port.
If the above solution will not work try to re-install the camera drivers.
Posted on Nov 30, 2008
SOURCE: Problem transferring photos from my digital camera to my PC
Be sure that you plug original Olympus USB cable directly into USB port on mother board (ussualy on the back side of PC) not on the front pannel hub and not into extention USB cable.
Posted on Mar 23, 2009
  • 919 Answers
SOURCE: picture error message on olympus 1200
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the Picture error message and the card can be used again. The picture error message indicates that this image is now corrupted and unable to be viewed through the camera.
Posted on Apr 23, 2009
leecom72
  • 4806 Answers
SOURCE: Write protected-Olympus EVOLT E-510 Digital Camera.
Hi there
The write protect is on the memory card, take the card out and unlock it, it will be at the side of the card like this 59a6de4.jpg .
Good luck and thanks for using Fixya!!
Posted on May 15, 2009
How do i delete photos?
Come on dude, the button on the back of the camera with the icon that looks like a garbage can is the delete button. Good luck
Jul 13, 2014 | Olympus X Cameras
My olympus e volt 500 will not display image when in shoot mode
There is a little button on the back, marked 'info'. Press it to switch from picture view to settings view. It also operates the viewfinder.
Olympus also has a good photo editing program that is free and it allows you to edit photos and stitch pictures taken pn panoramic mode into one panoramic picture. It's called Olympus Master.
Dec 12, 2012 | Olympus EVOLT E-500 Digital Camera
Problem with the Olympus FE-115 Digital Camera my
Unfortunately, the picture error message means that the image been modified such that the camera can't read it. It is possible that the camera thinks the picture was taken by another camera. Since the picture is still good when you check it with the computer, it hasn't been damaged. Archive the picture and make sure to back it up after it goes on the computer. (If the computer couldn't view it, then you'd need some sort of file recovery software and might not get the entire image back.)
Manuals for the FE-115 are available from the Olympus site: http://www.olympusamerica.com/cpg_section/cpg_archived_product_details.asp?id=1227&fl=8 .
I hope this helps.
Mar 10, 2011 | Olympus FE-115 Digital Camera
Hey my Olympus 230 digital camera seems to have deleted my photos, a message appeared on the camera "picture error", just wondering how I can get them back??
If you are using a memory card, take no more pics until you've recovered the photos, take the card out of the camera. This is to reduce the chance of you overwriting some of your "lost" photos. There are many good freeware photo recovery software options that are available to help you recover your photos. This blog article reviews and outlines several of the better ones.
All the download links listed in the article are through CNET, primarily to verify that these are malware free software, and to give you a chance to read user reviews on the software before downloading.
Nov 27, 2010 | Olympus FE-230 Digital Camera
Bonsoir, L'objectif de mon appareil Olympus 840 reste bloqué en mode ouvert, il ne se referme plus même appareil éteint. Je ne peux plus prendre de photo ni...
Good evening, The lens of my camera Olympus 840 remains blocked in open mode, it does not close even device turned off. I can not take a picture or even view the pictures taken, no buttons is functional. Thank you in advance for your help.
Jan 17, 2018 | Olympus Stylus 840 Digital Camera
Card 'full' but no files found...olympus 1040
hi, there's a problem in your memory card and you need to do first is format the memory card into camera (if its ok to you to delete all the picture save in memory card). If the problem still occur you need to buy new memory card.
thank you and good luck my friend
Jul 17, 2010 | Olympus Stylus / mju 1040 Digital Camera
Pictures deleted!
If the photos were on a memory card then yes you have a good chance of recovery.
http://datadoctor.biz/
Go to this site and download the demo programs. You will be able to see if they can recover your photos. The progs are not free but memories are priceless - I know!
Even if they are on the camera memory they offer progs to recover photos from the camera.
Good luck
PS do not take any more photos until you have tried the recovery software!
Apr 14, 2008 | Olympus FE-210 Digital Camera
The pictures go blank/black
Could be the mirror is sticking - can you hear it go up?
Sep 04, 2007 | Olympus EVOLT E-300 Digital Camera
How many photos will I be able to put on the 32 MB card or the 64MB card?
I think a lot of things depend here. - how many pictures do you like to take on your trips - what quality you like to shoot at. Here are the various number of pictures as described in the manual at 1600x1200. Again this may vary depending on the complexity (colors) in your picture. Setting 8MB 32MB 64MB HQ 16 64 128 SHQ 5 22 45 I have found HQ to be very acceptable in terms of trading number of photos for compression. I find the 8x10 output from them to be very good, but then again I am critical yet not overly critical. If you are thinking that you shoot more, then carry a laptop of have access to one on your trips. Or then again, you can shoot at lower res. i.e. 1280x960 or 1024x768.
Sep 07, 2005 | Olympus Camedia C-2100 Ultra Zoom Digital...
Olympus mju 740 Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
