Question about ASUS Computers & Internet
Need front panel connection diagram power switch lrf connectipns on 9 pin connector on motherboard
I have a asus ptgd-la motherboard thatb i need to put into a new case need the wiwihg diagram for panel switches on the 9 pin connector on motherboard i.e. power switch ,hard drive led, reset switch etc.
  • 20 Answers
Hi u can easily solve this problem.
open your computer cover and and see the motherboard front panel connectors. a use of screw driver touch any two front panel connectors if any led or switch working this condition you can note this and connect successfully. one by one touch all penal connections and u will be solve ur problem thanks mukesh kumar
mukesh_ibm@yahoo.com
Posted on May 13, 2009
  • mukexh
    mukexh May 13, 2009
    EASY THIS PROBLEM
Front panel pinout connections for ASUS A8M2N-LA (NodusM3
The Asus A8M2N-LA motherboard was made SPECIAL for HP.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00757531&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3339286
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00820191&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3339286
As such Asus has no info on it.
Looking at the second link posted (Motherboard Specifications), scroll down to the bottom, and click right on - Motherboard Layout
Motherboard layout shown (Direction), is the same as is installed in your computer; Processor to the Top, white PCI slots to the Bottom, Ram Memory to the Right.
The plastic front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the cables (Wires) go to from the Front Panel, is the Front Panel header.
Abbreviated F_PANEL 1, at the bottom right corner of the motherboard, is the Front Panel header.
There are 9 contact pins. Two rows.
Across the Top row they are numbered ODD.
Across the Bottom row they are numbered EVEN.
Coming from the Left side of the motherboard towards the right side, on the Top row;
Pins 1, 3, 5, and 7
Coming from the Left side of the motherboard towards the right side, on the Bottom row;
Pins 2, 4, 6, 8, and 10.
A) Pins 1 and 3 are for the HarDDrive activity LED light.
Pin 1 is for the Positive wire. ( + )
If the HDD LED is dim when operating, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pins 2 and 4 are for the Power On LED light.
Pin 2 is for the Positive wire.
D) Pins 6 and 8 are for the Power On switch.
Regards,
joecoolvette
Apr 10, 2012 | Gigabyte Computers & Internet
Needed to move motherboard to new case because of overheating / ventilation problems - do not know what the power / reset / hdd led leads are for the 9 pin f_panel (new case has each as separate...
Photo of the Asus M2N78-LA motherboard,
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c01421635&dlc=en
This photo also shows the orientation (Direction), that the motherboard is sitting in a computer case.
To the very bottom right is the Front Panel header.
The front plastic panel of the computer is the Front Panel.
The area of pins on the motherboard that the cables, (Wires) from the Front Panel connect to, is the Front Panel header. ( F_PANEL )
The Front Panel header, is the black rectangular shaped plastic block, that is sitting vertically on the motherboard.
Has two columns of pins.
4 on the left side, 5 on the right side. Makes it look as though there is a pin missing, at the top left corner.
I'm going to number the pins.
Pins on the Left side starting at the Top, going down;
Pins 1, 3, 5, and 7.
Pins on the Right side starting at the Top, going down,
A) Pins 1 and 3 are for the Power On switch. (Power On button)
B) Pins 5 and 7 are for the Power On LED light.
Pin 7 is for the Positive ( + ) wire.
(If the LED light is dim, reverse the wires around)
C) Pins 4 and 6 are for a Reset switch, IF a Reset switch is used. (Reset button)
D) Pins 8 and 10 are for the HarDDrive activity LED light.
Pin 10 is for the Positive wire. ( + )
(If the HDD LED light is dim when operating, switch the wires around)
Pin 2 at the top Right is NOT used. (NC. Not Connected)
For additional questions please post in a Comment.
I am looking at a motherboard manual in PDF file form, for the Asus M2N78-LA motherboard.
Regards,
joecoolvette
Sep 03, 2011 | HEWLETT-PACKARD HP Pegatron M2N78-LA ASUS...
I don't know how to plug in the wires for the ASUS a8n sli deluxe motherboard
Here is the manual for your motherboard (since describing a diagram probably isn't very useful...)
http://dlcdnet.asus.com/pub/ASUS/mb/socket939/A8N-SLI/e2024_a8n-sli.pdf
You want to look at pages 27-35, they describe what you need to plug into the motherboard. Basically make sure you have connected:
1) 24-pin power cable (from power supply)
2) 4-pin power cable (for CPU from power supply)
3) Any case fans with 3/4 pin connectors.
3) hard drives (SATA or IDE)
4) USB front panel ports
5) Audio front panel ports
6) Case plugs (power LED, hdd LED, power switch, and reset switch).
Apr 19, 2011 | ASUS A8N-SLI Deluxe Motherboard
I have unpluged the 20 pin ATX Power Connector on the PTGD-LA motherboard, there is a 24 pin plug, I am not sure where to plug it in. I can only find manuals for the PTGD1-LA which shows a 24pin/24plug.
If the motherboard has a 24-pin socket, you need a 24-pin connector on your power-supply.
If the motherboard has a 20-pin socket, then only 20-pins from the connector need to be connected to the motherboard.
Oct 22, 2010 | HP Computers & Internet
Front panel power switch & led'S pinout
asus web site download manual for a p5pe-vm thats all you need
Apr 30, 2010 | ASUS P5PE-VM Motherboard
just go to the asus website and download the manual for your board
Jul 17, 2009 | Computers & Internet
Need the pin assignments for the mother board
On most motherboards the front panel connections are printed in the connectors on the motherboard. When you connect the various LED indicators and when you power up and they do not light up then just switch the connectors around, because they are are polarized.
You can go to the motherboard WEB site (ASUS) to download a manual, the manufacturer and model number is printed on the motherboard.
Jun 28, 2009 | HP Compaq Presario SR1420nx...
Need connecton diagram for ASUS P4S-LA motherboard.
if colours don,t match up. your main connectors hdd/pwr/reset remove the front panel on the computer. and check from the switches located on the front panel. or you could use a multimeter and test for continuity. if you have one.
you should have green/white red/white orange/white Or blue white.
Mike @ Compurepair.
Mar 15, 2009 | ASUS P4S800-MX Motherboard
Power led connector problem
[ 1] [ 2] [ 3] [ 4] [ 5][ 6][ 7][ 8][ 9][10]
[11][12][13][14][15]16][17][18[19][20]
Robert,
Above is a rough diagram of the Front panel connector on your Motherboard. Your Power LED should connect to pins 1 & 3 if this connection does not have the power LED come on with the PC then reverse which wire you've attached to those two pins. (As LED's are polarized they must have current flow in one particular direction to operate) Pins 11 & 12 are your Hard drive activity connector
Hope this helps you
Dave
Nov 11, 2008 | ASUS P4P800-VM Motherboard
Computers & Internet Logo
1,549 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
