Question about LG 22" FLATRON LCD Monitor
Can't switch on monitor screen
My monitor was on sleep mode (orange light) so i pressed spacebar to awake it. However, it just went blank on me and i couldn't turn it on since. the indicator light doesn't light up at all. i tried another power cable but it still doesn't work. I'm guessing it's an internal problem with the screen but i don't exactly know what the problem is. How do i go about fixing it? Thanks!
    Sergeant:
    Champion:
  • 225 Answers
Please try to connect the monitor to another PC, and it continues to happen when connected to another PC, then the hardware (internal electronic parts) is having trouble powering up the panel / ccds and it should be replaced / serviced according to the terms of the warranty. regards
Posted on May 15, 2009
Acer p223w monitor does not turn on
Try a different monitor, check the connections to the pc. When the monitor light changes to orange, press the spacebar to see if the light changes back to blue. Your pc power settings might need to be re-adjusted, is the pc going to sleep or hibernating too soon?
Jan 02, 2014 | Acer Computers & Internet
Spacebar on keyboard makes my computer go to sleep mode
Sounds like your keyboard is sending the wrong signal (the one telling your PC to enter sleep mode) to your motherboard when you press space key, which (if true) would indicate it's faulty. It could also be you've contracted a virus and is playing a particularly nasty practical joke on you (let's hope that's all it does). Try connecting another keyboard to your PC and see if that helps. If it doesn't, then you'll need to clean your computer of any viruses. Try also disconnecting your mouse and see if that changes anything. If your keyboard comes with a shortcut utility software for it, run it and check there's no shortcut set on your keyboard's space bar. You've additionally specified you're not using wireless keyboard, but could you also please write what OS you're on?
Mar 23, 2012 | Compaq Keyboard
Monitor will not awake from sleep mode. Pilot light is amber when asleep. If the monitor is turned off pilot light goes from amber to off or black or nothing. Turning the monitor back on the pilot light...
That means your monitor is not receiving a signal from your video card.
A couple things to check:
*Make sure your cable is ok - unplug and replug the cable to see if it is a loose connection. Or try a different cable.
*Make sure your computer is not in sleep mode - Move your mouse or otherwise ensure your computer is awake and sending a video signal
*If you have another computer, try the monitor on the other system and see if it works.
Sep 03, 2017 | LG L196WTQ-BF 19" Monitor
Monitor does awake from sleep mode
You need to check the inverter fuse, transistors, caps, solder joints. Please see my pictures here to get some ideas so you will know what to look for inside.
http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
Please post back.
Replacement board: http://www.lcdrepair.us
Apr 27, 2010 | Dell E173FP 17" LCD Monitor
Went into sleep mode and will not awake, gives message of not being able ti find vga source, but all connections are good and secure, then returns to sleep mode
Sounds like there could be a short in your video cable. I had this problem occur where i would boot up my pc and after about 5 seconds the screen would go blank. Also give your monitor a reset manually after starting up your box. Just unplug the power cable to it for about 10 secs and see if that helps. Good Luck
Dec 09, 2009 | HP vs17c 17" LCD Monitor
You must go into the BIOS of you computer and turn off the sleep mode and also in windows. Disconnect the monitor and power it on without hooking it up to the computer. If the monitor turn on and is working , then hook it up to the computer and try with with the sleep controls off to see if it works correctly.If this works you must check the owners manuals of the motherboard and monitor for the correct operation of the sleep mode functions.Then reinstall the sleep mode operation and see if everything works correctly. If the monitor fails to work. Try the monitor on another computer and see if it will function. If all this fails to get the monitor working , then you will need to have the monitor tested in a service center to find the problem and have it repaired. You should also check your computer on another monitor just to maker sure you don not have a problem with the computer too. Hope this helps you with your problem.
May 12, 2009 | Mag Innovision LT776s 17" LCD Monitor
Stuck in sleep mode
Press the power button on the Computer it should come out of sleep mode then if it doesn't hold the power button of the computer down until the system turns completely off.
Then turn back on the computer should now boot fine. Once in windows goto control panel and select power option then adjust the setting.
Hope this helps you
Cheers J
Jan 05, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
When I select sleep or hibernate mode - the monitor stays black...
Hit the keyboard keys. It is better to just turn sleep and hibernate off and just use a screen saver or tun it off.
Aug 24, 2007 | ViewSonic VX910 19" LCD Monitor
LG 22" FLATRON LCD Monitor Logo
191 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
