Question about Dell Dimension 3100 PC Desktop
If I tick the "keep me signed in for two weeks" box, I keep getting signed out sometimes every minute, sometimes it stays on for an hour. If I leave the box empty, I don't have any problems. Is it safe to leave the box unticked? The computer engineer could not solve this problem for me. Help!!!!!
  • Dell Master
  • 13,433 Answers
Yes its safe to leave it unticked. if you still have problems try with another internet brower for example firefox www.firefox.com or google chrome www.google.com/chrome
Posted on May 12, 2009
Hi, I bought a brand new Keeway Outlook 125 jusy 5 weeks ago. Since I bought i had problems when starting it so they put in a new carburator that had a new automatic choke on it. I still have problems...
Is it normal that a new bike dies on you as you drive it? No way my friend. The carburetor should have a thermal-choke and it probably needs some adjustment.
Sep 08, 2011 | 2010 Keeway Outlook 125
I don't have a box to tick to keep me signed into Bt Yahoo mail
please keep on the option "Remember my ID & Password " or the option "Sign in Automatically"
Feb 23, 2010 | Yahoo Mail
Motorola DCH3200 cable box: sound and sometimes video cutting out
Sounds like your SNR is getting too high and causing the signal to overload. A few things can cause this a bad splitter that causes the signal to bleed and introduces noise, or a more common issue is having a weak signal coming from the cable provider and once it goes through a splitter it causes the signal to become to weak to be stable.
Since it sounds like your cable has been working up until recently, you may have had a cable or splitter go bad.
Call comcast and have a technician come out and test the line.
Sep 11, 2009 | Motorola Televison & Video
TV makes a ticking sound, red light comes on but no picture or sound?
The TV is on protect mode. The Ticking sound is the protection switc that keeps shutting down the TV to prevent more damage.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Jun 30, 2009 | SharpVision XV-Z9000U Multimedia Projector
Citizen Eco Drive second hand stoped working
The Citizen Eco Drive watches use special recharchable batteries.
I started collecting a couple of watches and I noticed sometimes a jeweler replaces them with an ordinary battery. The watch will work and at the same time it will try to recharge this one until it explodes! In newer models they made it harder to use the non-rechargable ones by adding a special connector or clip to the rechargable battery types.
Okay, if you say your battery goes bad, or watch does not run okay? It may have lost the charge over time. First thing to try is to leave it on the window sill so the dial is in the sun. It will start ticking, but please leave it out there for 3 days to a week. The seconds hand will tick irregularly in steps of one and two seconds, to show you it wants you to readjust the time, as it knows it has lost time. Adjust the time and it should run smoothly.
The seconds hand should run in single second steps, if it takes steps regularly, but every 3 seconds or so, it tries to tell you that its power level is going down. It will be able to continue for one or two days, but you should get it into the sun more often.
Charging the battery under a lamp is possible, however this heats up the watch and this may reduce battery life. As long as the watch keeps running I believe it should keep good time. It is quartz anyway. If this is not the case, and a good sunbath does not help, the mechanism could be running heavy, possibly due to overheating the watch; no help there...
If you need to know more about the Eco Drive, look for detail tech manuals for all types here: http://www.citizenwatch.com/downloads/tech/tech.htm
Those are great watches as long as you remember it needs light to charge.
May 31, 2009 | Citizen Eco-Drive BL5184-56L Wrist Watch
My yahoo will no longer let me stay signed in for any decent length of time. I check the keep me signed in box but usually have to continue signing in every 10-30 minutes. This just started about a week...
Sir,
This is the problem of internet connection that u have. Whenever the connection is lost this kind of happens check the connection frequently. also uninstall the y.messenger and download the latest version and install other drive (other than C:/ drive)
Thanks Good Luck
Appreciate to rate as "Fixya"
May 17, 2009 | Yahoo Mail
Keep being signed out
your computer has kept you sind in for to weeks now it thinks you dont want to be signed in so that is why you keep being signed out so if you can reset your login setings and i addvise you not to click the "keep me singed in for two weeks"
and just sign in every time.
please rate my help to you.
thank you.
May 12, 2009 | Dell Dimension 3100 PC Desktop
I keep being signed out, sometimes after a minute. If I DO NOT tick the "keep me signed in for two weeks" box, I don't have a problem. Can you fix this for me? The computer engineer could not solve the...
hmmm. maybe there is a problem with your internet connection dude..better to check it first before you complain..it's safe to leave the box unticked..
Dell Dimension 3100 PC Desktop Logo
22 people viewed this question
Alun Cox
