Question about Mag Innovision LT776s 17" LCD Monitor
Can't switch on monitor screen
My monitor was on sleep mode (orange light) so i pressed spacebar to awake it. However, it just went blank on me and i couldn't turn it on since. the indicator light doesn't light up at all. i tried another power cable but it still doesn't work. I'm guessing it's an internal problem with the screen but i don't exactly know what the problem is. How do i go about fixing it? Thanks!
  • magick_33 May 12, 2009
    Thank you very much! Tried everything.. guess i have to send it in for repairs..
    Thanks anyway:)
    President:
  • 814 Answers
You must go into the BIOS of you computer and turn off the sleep mode and also in windows. Disconnect the monitor and power it on without hooking it up to the computer. If the monitor turn on and is working , then hook it up to the computer and try with with the sleep controls off to see if it works correctly.If this works you must check the owners manuals of the motherboard and monitor for the correct operation of the sleep mode functions.Then reinstall the sleep mode operation and see if everything works correctly. If the monitor fails to work. Try the monitor on another computer and see if it will function. If all this fails to get the monitor working , then you will need to have the monitor tested in a service center to find the problem and have it repaired. You should also check your computer on another monitor just to maker sure you don not have a problem with the computer too. Hope this helps you with your problem.
Posted on May 12, 2009
How to solve acer monitor sleeping issue?
Press left mouse key and wait 10-15 seconds. Black screen and orange light is caused by computer going to sleep. Adjust your power mode.
Apr 30, 2014 | Computers & Internet
Acer p223w monitor does not turn on
Try a different monitor, check the connections to the pc. When the monitor light changes to orange, press the spacebar to see if the light changes back to blue. Your pc power settings might need to be re-adjusted, is the pc going to sleep or hibernating too soon?
Jan 02, 2014 | Acer Computers & Internet
Spacebar on keyboard makes my computer go to sleep mode
Sounds like your keyboard is sending the wrong signal (the one telling your PC to enter sleep mode) to your motherboard when you press space key, which (if true) would indicate it's faulty. It could also be you've contracted a virus and is playing a particularly nasty practical joke on you (let's hope that's all it does). Try connecting another keyboard to your PC and see if that helps. If it doesn't, then you'll need to clean your computer of any viruses. Try also disconnecting your mouse and see if that changes anything. If your keyboard comes with a shortcut utility software for it, run it and check there's no shortcut set on your keyboard's space bar. You've additionally specified you're not using wireless keyboard, but could you also please write what OS you're on?
Mar 23, 2012 | Compaq Keyboard
My Acer AL2216W monitor this morning went blank. I woke up, turned on pc and went to sleep like an hour more, when I woke up, the screen was black and light orange, as usual, when pc is not used for a...
Go to Control Panel, (top right View Small Icons). Then look for Power Options. On this page, you'll have the option to leave the monitor on. You should also check "Advanced Power Options". Don't be afraid of the word, "Advanced." It only means "customizeable"
If your mouse isn't waking your monitor, try the keyboard's space bar. I found it works better than the mouse at waking a sleeping computer
Apr 04, 2017 | Acer AL2216W LCD Monitor
Went into sleep mode and will not awake, gives message of not being able ti find vga source, but all connections are good and secure, then returns to sleep mode
Sounds like there could be a short in your video cable. I had this problem occur where i would boot up my pc and after about 5 seconds the screen would go blank. Also give your monitor a reset manually after starting up your box. Just unplug the power cable to it for about 10 secs and see if that helps. Good Luck
Dec 09, 2009 | HP vs17c 17" LCD Monitor
Modrl 710N Monitor. I have just turned on this replacement monitor for the first time in about 3-months. The screen is blank with a flashing green light on the control panel. Pressing the test button tells...
When a monitor goes black and the solid green starts flashing it normally means the computer is sleep mode the screen saver blanked out the display the comp is off ect... However in this case since i assume you allready tried wiggling the mouse tapping the spacebar pressing the resume button ect... It is one of 2 things either the video card is going bad.( perhaps the computer has been on for a while and it is getting hot. With video card issues except the obvious, the case fan should be checked. there is a fan on the videocard it should checked as well the pc coul and mostlikely needs the dust blown out of it cause thats what kills fans and power supplies Hey power supply is the next possibility to th issue. No matter which part solves the problem I reccommend you do the other maybe premaintenance things I suggested. Good Luck.
Dec 03, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Please try to connect the monitor to another PC, and it continues to happen when connected to another PC, then the hardware (internal electronic parts) is having trouble powering up the panel / ccds and it should be replaced / serviced according to the terms of the warranty. regards
May 12, 2009 | LG 22" FLATRON LCD Monitor
Dell Monitor 2001FP Blank Screen
From your description your backlight is going out. The fluorescent light when it begins to burn out tries to draw too much power. Your inverter is sensing this 'too much' power draw and shuts down power to the back light. Replacing the backlight is the most technically difficult repair of an LCD, and most repair shops don't even offer this service. I recommend that you sell your LCD 'AS IS' on eBay or a similar website. The Power board and the Control Board are both usable parts that can be easily salvaged from most Dell Ultrasharp monitors.
Oct 05, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
When I select sleep or hibernate mode - the monitor stays black...
Hit the keyboard keys. It is better to just turn sleep and hibernate off and just use a screen saver or tun it off.
Aug 24, 2007 | ViewSonic VX910 19" LCD Monitor
Mag Innovision LT776s 17" LCD Monitor Logo
411 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
