Question about HP Compaq dx2250 Microtower - Get 3 desktops for the price of 2 until 123107
Screen turns blank all of sudden and works normal after switching of the system for 1 hr or so.
Hi I bought hp pavilion dv9000 17' laptop around 18 months back. It was all fine till last month, now i have frequent issue with screen as it goes blank all of sudden. It becomes normal after i switch of the system for about 1 hr or so.
  • Anonymous May 12, 2009
    hi, thanks for the input
    but I dont have any of faulty CCFL symptom. Display goes all blank and sometimes backlight is on and no display on the screen!?
    Vijay
    Note: This is not happening when screen saver is switched on.
  • Renierf May 11, 2010
    Does this happen when your screensaver activates or at any time?
  • HP Master
  • 32,281 Answers
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on May 12, 2009
Have a dv5 1000us and after the bios and hp logo my screen is blank...what can i do?
Hi
when you say the screen is blank
what colour is the screen please
can you hear the laptop working
or do you think that it has switched itself off then
please also tell us what operating system you are running and is it the original factory fitted os
many thanks
Mar 27, 2011 | HP Pavilion DV5-1000US Laptop
Hi! I have HP pavilion dv1000 that works fine until just this Thanksgiving (Nov.2th) when i turned the computer the screen is just blank or black but it is still working. I am able to use the computer now...
Unfortuntly sounds like your screen went bad.
Sorry I can't give you any better help with this one, it can be fixed, just going to cost you around $100.. for new screen.
Sorry
Nov 27, 2010 | HP Pavilion dv1000 Notebook
Blank screen
Sometimes there is a function button that switches from the external monitor to the laptop screen. I think your computer is Fn + F4. Try pressing that a few times and see if your screen comes back.
Also if you can see any thing on the laptops screen even a very faint image then you may have a problem with the screens inverter. The inverter is a very inexpensive part, usually less then $20. You will need a good set of small screw drivers do do this repair.
Jul 14, 2010 | HP Pavilion dv9700t Notebook PC
Hi, I have an HP Pavilion DV7 laptop. When I turn on the computer everything seems to be working but the screen is blank. Blank meaning black and/or colorless without light. Thanks!
Borrow a monitor and plug it into the side of the notebook to verify that the computer still works. If it does then the screen has gone out.
Jan 28, 2010 | HP Pavilion dv6000z Notebook
Hp pavilion dv6810us -- the screen went blank suddenly (no hint of a problem) and can't get it back to normal. I've forced shut off and turned back on (4 times over two days)...still black screen. All...
if it was the video card ...it will appear something on screen like Bios...when accessed..and affect only the installation ...I suspect the lcd connection
so...assuming is nothing inside...take a look on this tutorial
http://www.laptop-repair.info/laptop_screen_repair.html
Nov 09, 2009 | HP Pavilion dv6810US Notebook
Monitor and LCD detection problem on HP DV6000
I HAD SIMLAR PROBLEM WITH ANOTHER MODEL TURNED OUT TO BE THE LID SWITCH WAS STICKING HOPE THIS WILL HELP
Dec 07, 2008 | HP Pavilion dv6000z Notebook
Dark Screen
the ac adapter needs to be pluged in, try the normal mode..
its hard to fix it from here, if you could get someone to look at it?
Apr 12, 2008 | HP Pavilion dv4000 Notebook
Freezing then blank screen
Have you tried pressing F8 on boot-up and log into safe mode under administrator, no password, and right click on any empty space on the desktop, left click on properties, left click on settings, select a lower resolution,( e.g. 1024X768 ) select apply, select ok, reboot, log in as normal
Mar 26, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP Pavilion A6130N setup error
Did you buy the computer new? It should have come with recovery disks, also called operations disks. I have had to do this with my hp pavilion lap top a few time over the past few years so that it would run faster. If the recovery disks aren't in there, call the company. They are always supposed to be included. I've always had good luck with hp, you might even go to hp's website. It's really good as well.
Dec 27, 2007 | HP Pavilion DV4015cl Notebook
HP Compaq dx2250 Microtower - Get 3 desktops for the price of 2 until 123107 Logo
168 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
