HP SCANNING ERROR (Sorry, could not find required user interface files.)
  • Chris Hingee
    Chris Hingee May 11, 2010
    Have you installed the drivers?
    Most scanners use Twain drivers.
  • 72 Answers
U can remove software...then install it............
if some files are gone.............
thank u
Posted on May 12, 2009
How to fix error 616-302
Automatic Solution for Novice PC Users (no manual option selections are required):
  1. Download the Dell 2130cn Printer Repair Tool
  2. Install the application after download completes
  3. Click the "Scan" button that appears on the first interface
  4. Click the "Fix Errors" icon that will appear once the automatic scan has finished
  5. Restart your system as usual
Jun 23, 2014 | Dell 2130cn Laser Printer
Error code f70
F70 Error code means Central Control Unit Heartbeat Failure. If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the Central Control Unit to the User Interface.
F71 error code meansUser Interface Heartbeat Failure. If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the User Interface to the Central Control Unit.
In both the above situations the following things are required to be checked and replaced where required:
1. Continuity of the User Interface harness.
2. Wire harness connections to the User Interface and the Central Control Unit.
3. Replace User Interface if drum is rotating.
4. Replace Central Control Unit if drum is not moving.
Oct 04, 2010 | Whirlpool Duet WFW9550 Washer
I power on my hp pavilion laptop and its in korean how do i change it
You are going to have to flash the bios to the english version and/or reinstall windoze to reset the language.
pls rate 4 stars
Nov 29, 2009 | HP Pavilion dv6000z Notebook
Scanner does not work- photosmart 2610
You can obtain the drivers from the following link
ftp://ftp.hp.com/pub/softlib/software10/COL18476/mp-47754-2/AIO_CDB_Full_Network_enu_NB.exe
Happy to help
Nov 29, 2009 | HP Photosmart 2610 All-In-One InkJet...
My C6180 also will not scan documents.
well this problem needs very grave trouble shooting with a lot of steps and it cannot be explained over here,
if you want a technician to do the entire troubleshooting for you.You may get in touch with one of the techbuddies,they offer free technical support for such issues.
you may get them at http://tinyurl.com/m7ghqz
Jun 22, 2009 | HP Photosmart C6180 All-In-One InkJet...
Scanner : could not find required user interface
I just turned off my firewall protection with CA security center (virus software) and my scanner came back to life. I've had nothing but problems with CA so it's back to Norton for me!
Mar 22, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C7180 not scanning
I had this very same problem yesterday & solved it, after about 4 hours, with a clean install!!
Check my "solution" post at another question where I explained it in detail.
Jack
Dec 29, 2008 | HP Photosmart C7180 All-In-One InkJet...
HP Deskjet F2200 All-in-One SCAN green light flashes but does not scan
Error: “HP Cue Scanning Flow component has encountered a problem and needs to be closed”.
The problem is caused by HP software not installing the file path to the scanner correctly in XP, so if you run a registry cleaner such as RegCure it will delete the file path.
OS: Windows XP.
If you encounter this error message please follow the steps below:
1. Go to registry by clicking on Start/Run then typing in regedit and hitting enter.
2. Go to HKEY_ Local_ Machine\Software\Hewlett-Packard\DigitalImaging\
3. Click on the Digital Imaging Folder and in the Right Hand Side Pane and check if the String Value “ProfileWritePath” is present and Value is set to %APPDATA%\HP\Digital Imaging\Data\Destination
4. If the Sting Value is not present right click and then click on new and then click on String Value Name it as “ProfileWritePath” and then right click on that and click on Modify and make sure that the value is set to “%APPDATA%\HP\Digital Imaging\Data\Destination” and close the registry editor.
5. Then go to My computer C:\Documents and Settings\All Users\Application Data\HP\Digital Imaging\Data and check if the Destination folder is present. If not create a new folder and name it as “Destination”.
6. If you are unable to locate the Application Data folder under All users, click on Tools and then click on Folder Option. In the Folder Options Window click on the View tab and under Hidden Files and Folders make sure that “Show Hidden Files and Folders” is checked and then click on Apply and then click on OK..
7. Then Make sure that the same that the HP\Digital Imaging\Data\Destination folder is present under all user profiles Application Data folder.
8. Run Regcure and after the scan check the file/path errors and tell it to ignore the HKEY_LOCAL_MACHINE\SOFTWARE\Hewlett-Packard\digitalImaging ProfileWritePath= C:\Documents and Settings\ (whatever your file path to the destination folder is)
Now it should run flwalessly even after you run regcure.
For other registry cleaners I'm sorry but you will have to find out how to tell your cleaner not to delete the erroneous file/path error.
Graham Sept 13th 2009.
Oct 14, 2008 | Office Equipment & Supplies
Scanner could not find required user interface files
I've had the same problem although with a HP Laserjet 3392. In order for the scanner to work it needs two services to run. (In Windows Xp goto CONTROL PANNEL, then ADMINISTRATIVE TOOLS and then SERVICES.)
The following two services was dissabled 1) HP CUE DeviceDiscovery Service and 2) HPQCXS08
I've changed the STARTUP-TYPE to AUTOMATIC for both services and the start them also manually.If you system is not using these two files go into the SYSTEM Event Viewer and look for error messages from the DCOM source just after you have tried a scan. These errors should give you an idea where to search
Aug 08, 2008 | Office Equipment & Supplies
Computers & Internet Logo
699 people viewed this question
David Payne
David Payne
