Question about HP Compaq Presario C700T
Audio come from headphone as well as laptop
There is sound problem in my laptop the sound is coming from both side from the laptop and also from the headphone but this problem come after formatting the system now i use window xp but later it was windows vista
  • 535 Answers
Conexant CX20549-12 High Definition Audio driver:
ftp://ftp.hp.com/pub/softpaq/sp35501-36000/sp35940.exe
Do not click on the link. Please copy the link and paste the link at the
address bar of the browser. Next hit the enter key.
k
Installing this driver may result in an error. But continue with the
following steps to get the audio driver installed correctly.
1. Click on Start and select Run. Now type devmgmt.msc and press enter.
2. Right click on "AUDIO DEVICE ON HIGH DEFINATION BUS " or Conexant
High
defination audio entry and click Update driver.
3. Select "Install from a list or specific location"
4. Click Next. Then select "Don't search, I will choose the driver to
install"
5. Click Next and then select "Sound, video and game controller" from
the
list.
6. Click Next and then click Have Disk.
7. Click Browse C:\swsetup\sp35940 folder and the double click the
(WinxP -> Thrifty10 -> CPL30A5a.inf file for Audio) Select the .inf file
Posted on May 12, 2009
Can't get the headphone sound working from the laptop
The Laptop has 3 Ports on the side- Pink,Green,Black
Pink Port is LineIn for an external device player jack
Green Port is LineIn for the Microphone jack
Black Port is LineOut for Headset or External Speakers jack
Plug the Green jack on Headphone - into the Black Port on the laptop.
b) Go to Control Panel and open - RealTek HD Audio manager
On the top of Page are 3 Icons -
One Icon is labelled Speakers One is for Digital optics, one is for Mic,
The Speakers Icon is misleading as it is also for Headphones (LineOut)
Select Speaker Icon and make it Default. Also tick Full Range - Front LR
Ignore the 4 vertical Analog Icons on the right side.
You should now have Headphone sound if your volume is not Muted.
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select configure speech recognition then
you will see earphones with a speaker among a list set up a microphone headset with microphone then next and next again you should see your earphones with microphone being configured
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list
make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or
select the voice tab
make sure that you have the right media selected also
select volume make sure the box for microphone has a tick in it
or you might have to depending on your operating system
Click start Control Pannel
click on Hardware and Sound
click on Sound
then you devices should come up ; speakers, Digital Audio, and headphones
plug your headphones in
then select headphones
at the bottom it will say set as default
select that!!
then when you disconnect your headphones it automatically switches to the speakers and when you plug them back in it automatically will switch to headphones
Hope this helps.
Dec 01, 2012 | Samsung Silver 13.3" Ultrabook...
Headphones for a laptop not working
click on Sound
select that!!
hope this helps
Sep 02, 2012 | Lenovo B575-1450A5U - IdeaPad Laptop / AMD...
When i put head phone in my laptop sound is coming from both sides , outside and also from headphone, how when inserting head phone sound should come from only headphone
On your audio device setting/configuration.Check to see if your headphones are set to be used as the 'default communication device" instead of the integrated sound, or if both devices are set to default. Choose the "headphones" as the default device so that windows will use them only when they are plugged in.
Aug 24, 2011 | Computers & Internet
All of a sudden sound is not coming in one of the channels (right). On pressing the headphone's band a bit sound comes on and goes off.
The cable connects to one headphone and then through the headband to the other side.
I sounds like the cable connecting them that runs through the headband has been damaged.
The only solution is the try and remove the cover from the headband and repair the cable.
Please leave feedback
Cheers
Andy
May 03, 2011 | Audio Technica Audio-Technica QuietPoint...
Audio from laptop speakers is fine, headphones are not.
Do these headphones work OK in another machine??
If not they are faulty / If so then sound port may be faulty.
'Ensure it is enabled in BIOS. press DEL key when booting and look for similar.
Mar 23, 2010 | Dell Vostro 1510 Laptop
New HP monitor connected to Dell laptop (Windows XP). Sound coming from Laptop speakers but no sound from monitor (yes the monitor does have speakers). I have the audio cable connected from laptop to...
1. check whether u have inserted the audio cable in the right port (Headphone Port)!
2.also check the audio settings of headphone port (volume,channels,etc.)
Dec 31, 2009 | Gateway Essential 500 PC Desktop
Audio/sound problems
sounds (pun intended) like you have your headphones plugged into the microphone input. See if you can change the spot they are plugged in...
good luck
May 23, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
Audio input/output problem
Dear user,,
Pl go to control panel and select sound/audio device and click and see you see install sound device.
pl double click on speaker symbol at taskbar.
see volume controler and selecting hedphone device and see it is mute or not
Regards,
Ravindra Shah
I wanna hook my laptop to my tv. used a vga cable and get picture but no sound
You also need an audio cable to go along with the VGA cable. You will need a 3.5mm audio jack cable. Plug one side into the headphone jack of your laptop, the other side into the 3.5mm audio jack that is right beside the VGA connector.
Jan 29, 2009 | Televison & Video
Audio problem...
i have compaq presario c700. when i attach headphones, the laptop speakers dont get off. both headphone and speaker are on. the sound should only come from headphones..
i have windows professional installed
ishric_ishaan@yahoo.com
kindly post the feedbakc on my email
May 26, 2008 | Intel Computers & Internet
HP Compaq Presario C700T Logo
93 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
