Question about Freezers
Candy frost free fridge freezer .freezer working ok
Candy frost free fridge freezer freezer working ok but the fridge keeps freezing up like the freezer
  • Anonymous Mar 30, 2014
    it is full of frost
  • 27 Answers
The thermostat might be turned up too high or is faulty. It should click when turned up and down from the setpoint.
Posted on May 12, 2009
Self defrost mechanism failed causing to ice up, blocking airflow. Leave door open overnight and switch off fridge. Leave a towel down for the ice melting and obviously remove frozen goods. This will need doing every 6 months or so.
Posted on Jul 21, 2013
Fridge freezer problem
Sounds like the defrost system of your freezer is not working. It could be either the defrost timer, defrost thermostat or the heater has a problem. The defrost timer turns off the compressor periodically to sent power to the defrost heater via the thermostat. The defrost heater then powers up and heats the evaporator coil to melt the accumulated ice buildup on the cold coils. Most likely issues are that the timer motor is not advancing the timer or the heater itself has burned out.
Jul 14, 2010 | Freezers
Model m331blk1 fridge freezer warning light flashing what is the problem will my freeze be ok it is only 1 yr old
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 06, 2010 | Frost Freezer WCWO F15WA FREE - POCKET...
Brandt apollo fridge/freezer - food defrosts + salad freezes
Check the vents in the fridge side and close a little if you can. On the freezer side just for good measure>>>>
Jan 05, 2010 | Freezers
I have a Beko frost free fridge freezer but the freezer part has stopped freezing, the fan is working although it is not on all the time and the freezer is getting cold but no cold enough to freeze, have...
have you checked the door seals, if it has split it won`t freeze 100% as warm air will get in and keep the temperature up, bit like leaving the door slowly open hth
Oct 12, 2009 | Freezers
Fridge working fine but freezer keeps freezing rock solid in a matter of weeks
check door seal fit tightly.if its frost free make sure drain is clear at the bottom of evaporater if all ok check defrost heater and sensors..
Sep 28, 2009 | Freezers
1999 Frigidaire Refrigerator
Check rear wall of freezer by feel for frost. Heavy, even frost indicates likely problem in the defrost system. Unplug unit. Defrost heater (in freezer behind rear wall panel), defrost thermostat (same area-must be checked at freezer temperature) or Defrost timer-located lower back outside of unit. Near compressor. Do continuity test on heater and defrost thermostat and if they show continuity (good), replace defrost timer. If not, replace the one that tests bad.
Defrost coils fully. Reassemble.
Please let me know if I have helped with comments and rating.
Refrigerator will work about 7-10 days after being defrosted until thick frost builds up again cutting off air flow to both compartments
Sep 07, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
Frostfree hoover fridgefreezer
If its freezing at the back that indicates refrigeration is good. it sounds like you have a thermostat control problem. Replace the thermostat.
Jan 12, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Fridge freezer
Defrost timers usually cause this type of frost build up. However it can also be caused by the defrost heater and/or heater thermostat, and these items are behind the panels therefore not easy to get to. Also before you attempt to take the panels apart make sure the refrigerator is unplugged.
Aug 04, 2008 | Candy Freezers
Candy fridge freezer
check that the correct thermostat is installed and that the element wire is connected.check door rubber and door hinges.check if it has independant defrost timmers and if it is working.oh and see if the element is drawing current if fitted with one.
Nov 05, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Freezers Logo
490 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
