Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
The water is staying in carpets and is not being sucked back to the machine
The suction to pick up the dirty water is not working
  • 322 Answers
The pick up slot across the front of the unit may be blocked or internal path for the water into the tank. Disconnect from electric and strip down the head and check for fibres/fluff balls - as these are the normal culprits. I am assuming that the suction motor is running?
Good luck
Posted on May 12, 2009
When the shampooer is moved forward to initially to spray the shampoo the plastic guard on the front drags the floor and keeps it from moving forward and shampooing. .
The one's I've used the sprayer is on the back of the suction (suction hood which is kind of clear plastic), you watch that clear part to see if it is picking up dirty water. Recall it's easier to pull it and if caught just push down on handles and that raises front of machine to clear carpet snag. I would walk backward as it sprayed and then picked up the water with dirt. If different machine you could spray moving backward, go back to same starting point go again and don't spray but just hold it near carpet so it picks up the water.
Jun 03, 2016 | Bissell ProHeat Pet Upright Deep Cleaner,...
Why is it not picking up dust and dirt from carpet. pipes clear. Can you help
How to Fix a Vacuum That Lost Suction - Quick and Dirty Tips
www.quickanddirtytips.com/.../how-to-fix-a-vacuum-that-lost-suction
Oct 3, 2013 - It's true, a vacuum that doesn't have suction is not very useful ... The first and most basic reason a vacuum isn't picking things up off the floor is if the ...The lower your carpet, the closer the dial or lever should be to the bare floor setting. ....it off and shaking the dust off put the power right back in my vacuum!
Common Vacuum Issues - and what you can do to solve them
blog.mchardyvac.com/.../common-vacuum-complaints-what-you-can-do...
Oct 4, 2013 - Your vacuum's job is to pick up dirt, dust and debris - so when it stopsdoing ... Often when your machine is not picking up it is due to loss of suction. If yourvacuum cleaner turns on but won't pick up on carpet or bare floors, ...
Is your vacuum cleaner not picking up dirt and debris ...
https://www.mrright.in/.../is-your-vacuum-cleaner-not-picking-up-dirt-a...
Jan 7, 2015 - But many times it does not pick up or suck the dust as effectively as it is supposed to do. ... If the vacuum cleaner fails to pick up dirt and debris and has no ... Deep clean your expensive carpets to restore their original look.
Jan 24, 2016 | Vacuums
Royal carpet extractor not picking up water well
Try to follow the suction from the machine through the dirty water tank to the front floor suction piece. Make sure the dirty water tank is seated properly. Make sure there are no suction leaks any where.
Mar 21, 2014 | Royal Procision 7910 Carpet Extractor
No suction on my Pro heat steamer
You may want to check to see if the removable nozzle is correctly placed into its place. This is the plastic part where the water is sucked up through by the carpet cleaner. The nozzle notches must fit into the groove on the cleaner correctly and the metal bar need to snap back on top of the removable nozzle, Also sometimes if you have hair trapped in the nozzle or the bristle, it will affect the suction power of getting up the dirty water. The dirty water tank need to snap in place by making sure the top of the gray snaps on each side is over the top groove of the dirty tank on each side and the the gray snaps are pushed down and pushed into the tank to until it is snapped in place.
Super Simple answer could be: The Dirty water tank could have bubbles in it causing it not to **** too.
Mar 03, 2011 | Bissell Carpet Cleaner Powerbrush Deep...
Why is the "dirty water" reservoir still empty after I cleaned the carpet?
There could be several problems that would cause the dirty water tank to be empty after you've cleaned the carpets. I'll try and walk you through each to help you diagnosis the problem.
Possible Problem #1: The dirt water tank lid may be the reason the machine is not sucking up the water. There is actually a gasket on the bottom of the lid where it connects to the actual tank itself. If the lid is not put back on properly (this is really easy to do, I've done this myself many times on my Hoover SteamVac), and the gasket is not sealing the lid to the tank, this will allow the suction to leak, greatly diminishing the suction power to **** the water back up. Try removing the lid and reinstalling it, making sure that it's put back on the correct way, and try to see if this fixed your problem.
Possible Problem #2: The Hoover SteamVac's like yours have a very poorly thought out design flaw to them on the attachment hose. Where the attachment hose connects into the SteamVac when the machine's handle is lowered to get underneath furniture and is close to the ground it puts a lot of stress on the hose where it connects into the machine (not the end the attachments go on, but the other end). This will cause the hose to tear at the stress point. This is a very common problem unfortunately, and I suspect might be the cause of your suction loss. To check this, remove the dirty water solution tank from the machine completely. Step on the handle release pedal to lower the handle part to the ground. Look at the lower part of the handle portion of the machine for where the hose enters into the handle section, then follow the hose to where it connects into the machine. Right at the end of the hose, before the hose cuff that's connected to the motor, inspect this part on all sides to see if you have a tear here. If you do, this is the reason the machine is not sucking water up off of the carpeting.
Possible Problem # 3. If neither of the first two possible problems were the source of your suction loss, try this one. Turn the machine upside down (you should probably remove both the clean water tank and dirty water tank before doing this, just to ensure that no water spills when you turn the machine over) so that the brushes are facing upwards. Look right behind the brushes for two red plastic tabs that are slightly sunken into the bottom housing of the machine. Pull these two tabs upward as far as they will go. There is a metal filter screen that will be exposed when you pull the tabs. Make sure that this screen is clear of debris. This screen protects anything from going into the motor, and if it has debris blocking it, this can cause the machine to loose suction.
Also make sure that there is nothing in the clear plastic suction channel on the top of the machine where you can see the water being sucked up. Sometimes if something gets stuck in this suction chamber, this can also cause the machine to loose suction.
I really hope that this helped you find the cause of your suction loss. If you were able to diagnosis this problem, and would like me to help you fix the cause of the suction loss, I'd be more then happy to now walk you through the repair as well. Please just use the Clarification Request form here on the same page, and I will then help you out with your repair. I just ask that if this repair was helpful to you, please help other Fixya members to find it, and rate the repair helpful by clicking the 4 Thumbs Up icons in the top corner of the repair.
Thank you very much,
Chris J.
GoVacuum
Apr 09, 2010 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Pet hair and dirty water back on carpet
If you have followed the instructions.And your not happy i would return it.Get a repacement.
Aug 08, 2009 | Bissell 1698 PowerSteamer ProHeat Upright...
Shampooer won't pick up water
look on the vacuum where the suction is to pick up and you will see its clogged ,clean out the suction ports
Apr 13, 2009 | Kirby G6 Bagged Upright Vacuum
Not picking up water on a bissel proheat turbo 2x
If unit is not picking up solution it is most likely the small red plastic filter that is just above the small float door in the top piece just left of the tool switch.. pop it out clean muck out of it and it will work like new again.. have fun!!
Jan 25, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
470 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
