Question about Hotpoint Ultima WF860 Front Load Washer
My washing machine keeps coming up test can you help me
Every time i try to put a wash on it comes up test
  • 34 Answers
Hello Lainy34,
Give this a try, turn off then back on. When on appears on the screen press and hold the "start/cancel" and the "on/off" at the same time until "D:off" appears in the display. It should be back to normal after that. Hope this fixes it for you.
Thanks,
edgin96
I’m happy to assist further over the phone at https://www.6ya.com/expert/ryan_7b238a1b08d97b98
Posted on May 12, 2009
Toshiba 10kg washing machine display error code E7, it can't wash but can spin so what's the problem? Can anyone help please???
try reset the machine's control board. try this step and bear in mind this may working/not working:
- plug in and power on
- press Rinse, Preset and Water Flow simultaneously, keep pressing and release after lights come on.
- wait about 5 second then press Cancel/Off
- unplug about 5 minutes
- plug and power on, test if it works
good luck
Sep 28, 2017 | Washing Machines
Lid lock is blinking and won't cycle Whirlpool Washing machine Model WTW4850XQ1
blinking lid lock light tells you their is a code being stored in the computer, something is wrong. the booklet that tells you how to access the codes is located on the front of the machine, to get to it tilt the washer back (get help to hold machine) look up to the right side toward the top of the front, plastic bag, remove the booklet and follow the diagnostic test. you may not get it into diagnostic first time if you have not done this before but keep trying you will make it , it will give you a code to your problem please put the booklet somewhere in case the serviceman needs it if he has to come out
Jul 02, 2017 | Whirlpool Washing Machines
The cold water is not working in my washing machine
Check the supply hose filter, and the filter on the intake of the solenoid. Switch the wires on the solenoid to see if rinse will put hot water into the machine, the contact at the timer may be going bad. While reversed, see if it puts cold water into the wash, that will test the solenoid.
Dec 01, 2013 | Maytag Washing Machines
My machine keeps bleeping to tell me the cycle is finished but will not begin another programme ?
1. Set the cycle knob to any "X" (reset) position
2. Press and hold the Pre-wash and the Start buttons at the same time. While still holding these buttons, turn the unit on by pressing the On/Off button
3. Keep holding the Pre-wash and the Start buttons until the digital display comes on (about 5 seconds)
The digital display will show 00 for no faults or will show a fault code.
To end the test program turn the washer off at any time
Let me know what error codes come up, if any.
Nov 25, 2010 | Bosch Washing Machines
I have a hotpoint ultima wf860 washing machine when trying to do a wash it just keeps saying test what is wrong with it ?????
SomeHotpoint's are designed to go into test mode when the start button and the on/off button are pressed at the same time. If you are stuck in Test mode, simply hold the start button down until it comes out of test mode, then hold both the start buttons and the on/off button down until you see 'D:end' (or similar message). Now try a normal wash programme again and hopefully it should be fine. If it goes into test mode by itself, then it may be an indication that there is a real fault, or a faulty programmer board. hope this helps.
Sep 26, 2010 | Hotpoint Ultima WF860 Front Load Washer
The machine keeps showing test. it won't go onto any other programme. it keeps running through the test programme then stops, i then try and put it to wash and it will come up with test again.
http://appliancejunk.com/ge/washer/31-9103.pdf OK, to help you, I have found you your service and troubleshooting manual. Below is a DIY self help. washer link, this will help you to troubleshoot your issue. http://www.acmehowto.com/howto/appliance/washer/washer.php
You should try to reset it, but if that doesn't work, you may find you have a main controller board failure.
Jun 06, 2010 | Hotpoint Aquarius WD640 Front Load...
Hotpoint
turn the machine on while pressing the start and on buttons at the same time until dOFF appears.
Oct 18, 2008 | Hotpoint Aquarius WF220 Front Load Washer
Washing machine
Pressing and holding the two centre buttons ie on/off and start/cancel together for a few seconds causes the machine to run in 'test' mode. Doing the same again puts it back to normal wash.
I nearly called an engineer once because my daughter causes it all of the time!
Sep 28, 2008 | Hotpoint Ultima WF860 Front Load Washer
Test on washing machine
yes try pressing the on/off button and start/cancel button at the same time
May 26, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Problems
You could simply have a blocked drain pump. Is there water still in the unit when the code LE comes on, if so simply remove obstruction (outlet filter) and try spinning unit. Click above on troubleshooting, and look for drain, filter, etc. You're bound to find something useful. And rate pl.
Dec 01, 2007 | LG WD-12126RD Front Load Washer / Dryer
Hotpoint Ultima WF860 Front Load Washer Logo
62 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
