Question about Samsung HCL473W 47" Rear Projection Television
BLUE UPPER ARCH ON SAMSUNG TV
HELLO, I HAVE A BLUE ARCH ON THE UPPER PART OF THE TELEVISION & SOMETIMES A MIRROR IMAGE OF WHAT I AM WATCHING. I WOULD LIKE TO KNOW IF THIS IS A CONVERGENCE PROBLEM? IF SO, I AM TOLD THAT THE BOARD NEEDS TO BE CHANGED, IS THAT TRUE? THE REPAIR MAN IS ASKING FOR 400.00$ DOES THE BOARD ONLY NEED TO BE CHANGED? DO YOU THINK IT IS POSSIBLE I DO THIS ON MY OWN BY OPENING THE TV AND REPLACING THE BOARD?
  • 4 more comments
  • huet Oct 13, 2007
    I HAVE BEEN DOING SOME HOMEWORK AND THE CONVERGENCE BOARD AA9502002A HAS BEEN REPLACED BY BP95-00142E PRICE $80 WITH THE ICs. SO,IF I REPLACE THE BOARD WILL THE PROBLEM BE REPAIRE.
    THANKS
  • huet Oct 14, 2007
    I AM WATCHING FOOTBALL AND ONTOP WHERE THE SCORE BOARD IS I CAN SEE IT AGAIN IN BLUE LIKE A MIRROR.  IS THIS THE CONVERGENCE BOARD PROBLEM. THANKS
  • huet Oct 14, 2007
    WHERE WOULD I ADJUST THE BLUE FROM , I HAVE NO CLUE WHERE IT IS.
  • huet Oct 14, 2007
    PERFORMED A PREFECT FOCUS AND  CONVERGENCE AS PER MANUAL SEE NO CHANGE
  • huet Oct 15, 2007
    I AM WILLING TO SPEND $100 TO CHANGE THE WHOLE CONVERGENCE BOARD,
    BUT AFTER CHANGING THE BOARD IS THERE ANYTHING ELSE I NEED TO DO.
    THANK YOU.
  • huet Nov 09, 2007
    I AM JUST GETTING BACK TO SAY THAT I CHANGED THE CONVERGENCE BOARD
    ASSEMBLY FOR $110.00 AND SOLVED THE PROBLEM. THANKS
  • 709 Answers
Hi Huet,
You may have a misalignment problem with the projector.  When you open the back up, you may want to tinker with the adjustment of the Projector alignment to see if you can get the blue arc to go away.
Also if it is your Convergence circuit, Get the numbers off the board and go to www.partstore.com to see if they have a good deal on your circuit board.
Posted on Oct 13, 2007
  • 2 more comments
  • Greg Stokes
    Greg Stokes Oct 14, 2007
    Hi Huet,
    Have your tried to adjust the projector like I said earlier?  If you have tried to adjust the Blue convergence and got it better, then come back to watch and the Blue goes out again, you most likely have a covergence circuit problem.  I cannot tell whether it is focus alignment or Blue convergence with what little I know about Projection TV's,  I have had success in getting my project tv better with adjusting the Projector.
  • Greg Stokes
    Hi Huet,
    Use this URL to get the Manual in Adobe format.
    http://downloadcenter.samsung.com/conten...
    Now go to page 25 to see the procedure for Perfect Focus and Convergence settings.
  • Greg Stokes
    Hi Huet,
    Did you possibly read on in the manual to pages 26, and 27 to see the centering and edge alignment adjustments?  If so check out the expert "Hardroc's" solution for projection TV convergence.
    http://www.fixya.com/support/t115541-con...
  • Greg Stokes
    Greg Stokes Oct 15, 2007
    Hi Huet,
    AllI can tell you is to just click on my posts as Thanks for trying. You will be best served by Hardroc from the Url below.  I apologize for your trouble and my not being able to help any more than I have.  I wish I could do more. Hardroc focuses on your kind of problem.
    Genius:
  • 1,694 Answers
Normally,the convergence circuit is repaired on the board in
need.Board replacement is usually more expensive than 400.00.
Blue convergence IC is bad. Replace both IC's for reliable,long lasting repair.Use OEM quality or better parts--I use Panasonic
STK-392-040 with good success.Repair bill about 495.00.
  • Vista Electronics Oct 13, 2007
    Post written by Terryfic 10/13/07.
Why does upper half of screen go dark?
http://www.shopjimmy.com/samsung-bn96-03365a-g-buffer-board.htm Watch the video. Also be advised that plasma sets are getting very hard to find parts for.
Feb 01, 2016 | Samsung HP-S5053 50 In. Plasma HDTV
Red dots going across screen when watching TV is this worth fixing and how much would it cost? approx. 5-6 years old.
This tv is a DLP one - the image is created in a special chip with tiny mirrors on it; each mirror is commanded individually by an image processor that in your tv is starting to fail.
The replacement of the mainboard on which this processor is soldered would cost you about $300 - i don;t think the tv is worth as much. Keep using it for as long as you can and use this time to save for a new one.
Jun 03, 2011 | Samsung HL-S4266W 42" HDTV
CRT Arch / Blue Tube, Now what do I do.
Replace Blue Tube and re-align - Big job and expensive Tube cost min $300 + installation. You can see the tube arching internally?
Sep 21, 2009 | Zenith R56W36 56" Rear Projection...
Arch in color on Panasonic
hello sound like convergance chips also check resistors and capacitors hope you get it fixed
shaun
Jul 31, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Arched picture on Sony KV-34XBR800
Your TV has problem in Pin-Out area. I know its technical term but I have no other words to explain it. TV needs qualified technician to fix it.
Jun 11, 2008 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
Reccomended settings for Samsung 52 inch LCD tv
I have recently posted a question regarding my Samsung 52 inch LCD hi def television. After doing some research online and reading some others experiance I have adjusted my settings in the menue of the tv to provide the best picture.
May 30, 2008 | Televison & Video
Vertical Tilt on Screen & Occational Blue Spot
firstly check the 1000micro farad near the ic vertical,u have to change it.
secondly for the blue green change the positor,if you dont know where it is!!!! it the near the degassing plug
Apr 20, 2008 | Sanyo DS24425 24" TV
Samsung HCM553W 55 in. Rear Projection Television - image duplicated
Hello, I am a Samsung TV repair man. What happened was one of your bulbs in your tv has burnt out. you have to contact your samsung repair phone line. how old is that tv? do you have a warranty? if you do, it might be repairable for free. I hope this info is useful!
Apr 20, 2008 | Samsung HCM553W 55" Rear Projection...
Toshiba 50H82 blue arcing?
color shadows on numbers or letters indicate a possible convergence problem.. might be a crt deflection problem.
Dec 18, 2007 | Toshiba 50H82 50" Rear Projection...
Samsung HCL473W 47" Rear Projection Television Logo
73 people viewed this question
Jerry Greenberg
Jerry Greenberg
