Back to:
Tags:
Emerson EWV603 VHS VCR
Change recording speed
posted by lynn57 on Oct 13, 2007
I need to change the recording speed, and dont have the remote.  Is there a way to change it without the remote?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jun 01, 2008
Thanks for Trying (70)
rushourg
Rank:Apprentice Apprentice
Rating: 70%, 1 votes
The only solution to this problem is to buy a new remote from the manufacturer. Aftermarket remotes that I have looked at: RCA, PHILLIPS, SONY, etc do not have a speed select button for the VCR. (which IMHO is stupid) Come on aftermarket people- it cant be that hard to program a speed select button!
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on change recording speed:
I don't want to Accept this solution
Solution #2
posted on Oct 13, 2008
Not Rated (0)
joe_creel
Rating: 0%, 0 votes
I know its aggravating but you can use the menu button and go through a program sequence and set the recording speed there, then just turn off the VCR and when the time is met it will automatically come on and record at the speed and length of time you have set.
Thank You!
Can you Help with these VCRs problems?
my vcr recordings have no sound
Hello. I have an Emerson VCR/DVD combo Model # EWD2004....
tapes partially load; up to the point where the mechanism...
I have a problem with my Emerson VHS it records the image...
as above; should I return to overstock.com or can I fix or...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
