Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
Can not install printer nor scanner - Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
    Sergeant:
    Champion:
  • 240 Answers
Try to uninstall all existing printer driver on your computer and then install a new compatible one..
Posted on May 12, 2009
How do I install the scanner. I installed the printer, it works but the scanner and fax did not.
You need to install the drivers for the scanner and fax. They are separate installs. They should be on the CD that came with the printer. You can get them from Cannon's web site too.
Dec 04, 2014 | Canon PIXMA Office Equipment & Supplies
I installed a printer on my PC and the scanner does not work. Should i install the scanner aswell?
Do you have the combo printer that comes with scanner and printer in one machine? If you do, then one installation should work the device as the computer will recognize it as one. If that's what you have, and the scanner still doesn't work, return the machine and ask for a new one.
If you have separate scanner and printer machines, then you should have two installation discs as each should have its own. You will need to install the scanner if this is the case.
Hope this helps.
Aug 30, 2011 | Office Equipment & Supplies
I download hp 5590 drivers from hp.com i tried to install it, the proces eend normaly, but if i connect the scanner, windows xp show the new hp connect like its not installed yet. I check at add remove...
FIRST UNINSTALL YOUR PRINTER COMPLETELY
REMOVE ALL CABLES OF PRINTER (USB)
REBOOT YOUR SYSTEM
HAVE DRIVER CD
PUT IT IN ROM(CD/DVD)
INSTALL PRINTER SOFTWARE
DONOT PLUG THE USB CABLE UNLESS & UNTILL PROMPTED
PLUG USB WHEN ASKED
FINISH INSTALLING PRINTER
NOW YOU CAN FIND THE SCANNER
Feb 15, 2011 | HP Scanjet 5590 Flatbed Scanner
I have network printer with scanner. Model is hp officejet pro L7580 printer. I installed a printer sucessfully but I want to use printer scanner. So how to install scanner & use it?
Hello!
In order to install your scanner, you need to print a test page. As you need to align the cartridges, you also need to align your scanner. See the printed alignment page for directions on how to complete the alignment process. Basically, all you have to do is put the test page in the scanner and press scan.
Mar 31, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
I WANT TO USE THE SCANNER BUT, I DON'T NOW HOW, It go to the printer all the time, could you please help me ? I have the EPSOM STYLUS BX300F PROFESSIONAL, PRINTER,SCANNER,FAX,PHOTOCOPIER.
Basically, you can use the scanner in two ways. Please open the scanner cover and place the document or image you want to scan face down.
1. Press the SCAN button (color button = color scanning, black button = monochrome scanning). then your scanner will scan the document or image in the scanner tray.
2. Go to the scanner program installed in your computer when you installed the printer. Open it and then click the command button SCAN.
Note: Make sure that you installed the Scanner software when you installed the printer. Without the software, your scanner will not work. Please reinstall the printer including the scanner software.
Feb 06, 2010 | Epson Stylus Multifunction Inkjet Printer/...
My pc is not recognizing the scanner
In your printer and fax folder you probably have more than one printer installed and your default printer is not the one you just installed, Select the printer you just installed and set it as your default and try again
Jun 19, 2009 | Uniden BCD996T Base Scanner
Installation of my scanner
While installing the software for the printer and scanner, try to install and chose custom installation chose scanner files as well. If the problem is that it is not recognizing scanner, than go to control panel 'scanner and cameras' go and try to add scanner there. If your device is installed perfectly it will recognize it there.
Mar 12, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
After running full system recovery I tried to reinstall my printer and scanner. I reinstalled my printer (HP Deskjet 870ces). Then tried to reinstall HP Scanjet 5100c on a machine running Windows XP Pro....
Some time printers and scanners conflict. Try this, uninstall both printer and the scanner, then install the scanner first and try it to see if it works. Then install your printer. If it doesn't work let me know I'll walk you through. Good luck :)
Feb 21, 2009 | HP Office Equipment & Supplies
Scaner is not working of hp3055 color laserjet printer
Step 1:. Check Hardware Driver Installed Properly
- My Computer-Properties-Hardware-Device Manager
- If Yellow mark in printer and Scanner field, the Printer
driver not installed properly.
- So reinstall Printer Software
Step 2: If Scanner Option only not working,
- Go to Scanner Settings(Start-Programs.....)
- Choose Correct Scanner Name.
Or
- Press the Scanner button in hp 3055
- If Hardware driver was installed correctly, its automatically
deduct on your PC
Jul 02, 2008 | HP Color LaserJet 2600n Printer
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
43 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
