Question about Canon PIXMA iP1800 InkJet Photo Printer
My Canon iP1800 printer tries to print too close to the left edge of the paper and therefore cuts off the first two letters of each line. It started doing this suddenly. Previously it worked correctly. How do I correct this ??? Thanks for your help.
    Sergeant:
    Champion:
  • 341 Answers
I suggest you try to install the printer to another computer. This is to isolate a hardware or software problem. if the problem persists then it is a hardware problem or mechanical defect in the printer paper feeder
Posted on May 12, 2009
Canon ip1800 is experiencing paper jam.whener tries to print, cannot feed the paper properly
Sometimes a printer just needs some cleaning.
Remove the jammed paper following the procedure below. (1) Slowly pull the paper out, either from the Auto Sheet Feeder or from the Paper Output Slot, whichever is easier.If the paper tears and a piece remains inside the printer, turn the printer off, open the Front Cover, and remove it. Be careful not to touch the components inside the printer. After removing all paper, close the Front Cover and turn it back on.If you cannot pull the paper out, turn the printer off and turn it back on. The paper will be ejected automatically. (2) Reload the paper in the printer, and press the RESUME/CANCEL button on the printer. If you turned off the printer in step 1, all print jobs in queue are canceled. Reprint if necessary.
Make sure to clean the paper feed rollers if paper is not fed properly. Cleaning the Paper Feed Roller of the Auto Sheet Feeder consumes it, so perform this only when necessary. 1. Make sure that the printer is turned on, and then remove any paper from the Auto Sheet Feeder. 2. Open the Printer Properties dialog box. 3. Click the Maintenance tab and then Roller Cleaning. 4. Confirm the message, and then click OK.The Paper Feed Rollers will rotate as they clean. 5. When the message appears, load three or more sheets of A4 or Letter-sized plain paper in the Auto Sheet Feeder.Set the Paper Thickness Lever to the left. 6. Confirm the displayed message and click OK.The paper that is loaded in the printer will feed through the printer and be ejected. 7. When the confirmation message is displayed, click OK. If this procedure does not solve the problem, clean the surface of the roller with applying a slightly moisten cotton swab with water to wipe off dust or stain.
If the problem still persists, contact a Canon service representative.
Mar 28, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
My canon ip1800 paper jam
Turn it upside down and shake vigorously. Also, is there a reset hole where a paper clip inserted can do a system reset?
Aug 22, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
The same problem with my ip1800
Hi There, if you go onto the top of the page on this website and type in manula for canon ip1800 it will bring up the manual and it will show you how to fix it.
Jun 22, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
I changed the ink in my canon ip1800 and now it the me the print head need alignment and i don't know how to do it.Can you help
1. For Windows XP, select the Start menu -> Control Panel -> Printers and Other Hardware -> Printers and Faxes
2. Select your printer model name icon.
-> Printers and Faxes.
3.Open the File menu and select Printing Preferences.
The printer driver setup window appears.
4.Click Print Head Alignment on the Maintenance tab.
A message appears.
5.Set the paper thickness lever to the left, and load a sheet of A4 or Letter size plain paper into the auto sheet feeder.
6.Follow the instruction in the message.
7.The Print Head Alignment dialog box opens.
Select the numbers of the patterns with the least amount of streaking in the associated boxes.
Clicking the patterns with the least amount of streaking in the preview window, will automatically set their numbers in the associated boxes.
8.When you have entered all the necessary values, click OK
And that should do the trick for you.
Sean
Feb 25, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
The ink absorber is full... for the canon PIXMA iP1800
My printer is not printing for feed paper. It tells me that it has a paper jam, but there is no paper in the printer. Please advise
Dec 05, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
L7780 won't print on edge of paper
it could be the printer settings. Before you actually print something go to File>print:- and then choose properties, click on advanced and ensure that the correct paper and size is set to how you want it.
Oct 28, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Jammed paper
If the paper is lodged too far into the printer and can't be removed:
Press the power button to turn the printer off.
Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
Close the front cover.
Press the power button to turn the printer back on.
Resend your document to print.
Ensure that:
The paper is a recommended paper for inkjet printers.
You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
The printer is on a flat, level surface.
The left paper guide is against the side of the paper.
You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
The left paper guide does not cause the paper to bend in the sheet feeder.
Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
Envelopes or the appropriate specialty papers are selected in the printer driver.
You are using a paper or envelope size supported by your printer.
Apr 28, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon PIXMA  iP1800 InkJet Photo Printer Logo
54 people viewed this question
old marine
old marine
