Question about Chi Mei Corporation CT522A 15" LCD Monitor
Out of range H and V after AFTER i USED PARAOGIC DRIVER CURE.
Now can't open windowns. tested all cables. have not tested monitor on another computer yet. could it just be broken?
I opened gotomyPC from my laptop and was able to remote access the problem computer.w nt into control panel and reset the computer back to a previous date. it worked
Posted on May 12, 2009
Not able to change screen resolution for lgw1742s for windowns xp
Reinstall your VGA driver, after it if you can not do, be sure that wrong betwenn windows and driver
May 28, 2011 | Computers & Internet
My Westinghouse monitor is not going on but the power light is on do I need another monitor it is 5yrs old or more
It could be your monitor driver card that is bad.
Before you go buy a new monitor, do a quick test on
connecting the monitor to a laptop or portable computer if you have one,
or if you can, get a friend that has one a laptop and use the monitor
signal cable that is already there, and connect it into the
temporary or borrowed computer to see if you get a picture.
Your borrowed computer will need to know that your attaching
and external monitor, so that will need to be done to let the
new computer being used, to know that it is being attached.
If you get a picture, its your old computer driver card.
If it still stays blank, or no picture, then your 5 year old monitor is bad.
Also, but unlikely, it could be the monitor signal cable that
is bad, in that case it will not work on either application.
You could substitute the cable to make sure its not the cable also
for a quick check, on both applications.
May 24, 2011 | Compaq Audio Players & Recorders
The screen is blue and greem
The most probable cause is a break in the cable (red signal line). Try gently wiggling the cable at the computer connector and right at the monitor - these are the usual places for breaks. If this brings the red back into the picture (pun intended), you'll have to find a way to repair or replace the cable.
If you have red or white when the cable is disconnected (check cable warning message) or in the monitor adjustment menus, it is definitely either the cable or the computer video card.
If you can't get red to work at all with the tests in the preceding paragraphs, then it's time to open up the monitor. Check for continuity on the red line (pin 1 on the DB-15 connector to the red shielded wire where the cable terminates inside the monitor). Note: if you are not comfortable working near high voltage or don't know what not to touch, leave this task for an electronic technician. If the cable tests good, then it's time to troubleshoot the red cathode driver circuit on the CRT board, starting with the input signal. You'll probably need an oscilloscope for this job.
Jan 02, 2011 | Acer P201WD CRT Monitor
My samsung 940N acts like a florescent tube, tries to start and doesn't
Use the self test feature.. follow the steps..
1. Turn off both your computer and the monitor.
2. Unplug the video cable from the back of the computer.
3. Turn on the monitor.
If the monitor is functioning properly, you will see a box in the illustration below.
This box appears during normal operation if the video cable becomes disconnected or
damaged.
4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the
monitor.
If your monitor screen remains blank after using the previous procedure, check your video
controller and computer system; your monitor is functioning properly.
Warning
The Power supply inside the monitor can be hazardous and donot open the monitor while power on.
Donot work with the monitor when it is open and the power supply is on.
If there is something wrong with the input signal, a message appears on the screen or the
screen goes blank although the power indicator LED is still on. The message may indicate
that the monitor is out of scan range or that you need to check the signal cable.
Feb 13, 2010 | Samsung SyncMaster 940N 19 inch LCD...
Monitor LED blinking--no display--How to open the cabinet
check the vga cable if it is attached properly to your computer. Make sure that the VGA cable is connected to the Video Card that you are using.
check in the manual if you need to install the driver first.
also check if the monitor will work to another computer. If not, Then you can check the VGA Cable and replace a new one.
Hope this will help you out .. =)
Aug 24, 2009 | LG Studioworks 700S 17" CRT Monitor
No input signal
Make sure that the correct cable is used vga to vga or dvi to dvi..... try some different cable.... try a monitor slf test you cannot access it by just removing the monitor cable..... if do get the test the monitor is bad
May 02, 2009 | Computers & Internet
Mag 17
it is a problem signal cable of the monitor open the monitor test the continuty of 15 pin signal cable
if pin no 13 & 14 (hsync & vsync)are open then change the cable problem will be solved
Oct 25, 2008 | Computers & Internet
Heavy white lines accross the screen
Replace it, it is going bad. I could tell you what would cause this such as bad driver IC etc. but bottom line is its five years old, you got your moneys worth out of it so bite the bullet and get a new one.
Feb 11, 2008 | Envision EN 9110 19" Flat Panel LCD...
INPUT SIGNAL OUT OF RANGE
some how your screen resolution has changed above or below what your monitor can display. you need to boot your computer using another monitor that can work with the resolution your computer has switched to(i used a spare crt monitor when it happened to me) change your resolution in display properties to a normal level like 1027x768, and while the computer is on swap the monitor cables to verify the lcd is working.
It is perfectly safe to unplug the video cable and plug it back in while the computer is turnned on.
Dec 26, 2007 | Relisys TL775 17" LCD Monitor
Chi Mei Corporation CT522A 15" LCD Monitor Logo
96 people viewed this question
Top Chi Mei Corporation Computers & Internet Experts
richie46
Steven's...
Steven's...
Paul Norman
Level 1 Expert
Are you a Chi Mei Corporation Computer and Internet Expert? Answer questions, earn points and help others
