Question about Actiontec GT704 Router
How do I add a password to make it security enabled
I have broadband through a third party router Actiontec. I have no security enabled and would like to set this up, any idea how I do this
  • 1 more comment
  • Carl Navarro
    Carl Navarro May 11, 2010
    BTW, it's not that I don't know where to find the manual, it's just that the instructions tend to be ISP specific. you can choose from 11 704 manuals here http://support.actiontec.com/doc_files/
    When you get the right one, look under wireless security.
  • Carl Navarro
    You could start with a model number and tell us what you know....
  • kalpesh jain
    kalpesh jain May 11, 2010
    this ia a wireless devices or what
    Scholar:
  • 82 Answers
It should be pretty straightforward. The ISP specific stuff is generally in how the PPPoE is set up.
You should be able to log into the router by going to 192.168.0.1
UN: admin
PW: <is blank> change it when you log in.
Go to wireless on the left hand side. Select WPA. Give a password in pre-shared key. Save your settings and you should be godd to go.
Posted on May 12, 2009
My DHCP is not assigning a dynamic address to one of my seven wired devices. I've had to switch over to a stati
On the second router just plug a port cable in from your main routers port into the wan port and then be sure to change the second routers gateway and IP address to a different number. Say that your main router IP is 198.18.1.1 and for your second router IP you could use 10.10.10.1 or what ever combo you want and then you should be able to use both routers together. Is this what you are trying to do?
Linksys routers as well as all routers with DHCP enabled should be able to handle up to 255 separate IP address's for a LAN network. Is the firmware of the Linksys the latest? If not, down load the latest firmware and flash the router to update it. Or, check out third party firmwares like Tomato to flash that tired Linksys and turn it into a real router.
Apr 14, 2017 | Actiontec Verizon Fios Mi424wr Modem...
Hi I want to know on how to setup the verizon Modem/Router I already have a Westell 6100G and i want to upgrade to the new one called Verizon Wireless modem/router model:GT704WG.
Are you on Consumer Verizon DSL? Fair warning if you are using Business Static- the Actiontec is a poor choice due to issues working on a static IP circuit. - I'd use a 6110 and a third party router! However, by default, the only thing you would need to do to setup the modem is go through the activation page when you plug the modem in. If you require an user name and password, it would set that up. Bar any problems, you can contact Verizon technical support since the Actiontec Gateway is fully supported.
Aug 28, 2010 | Actiontec GT704WG Wireless Router...
Cannot connect linksys wireless broadband router with at & t dsl modem to connect to internet ?
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Then check
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 05, 2010 | Linksys Wireless-G WRT54G Router
Want to know how to put a security lock on my router so people can stop stealing my service ?
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
Apr 29, 2010 | Linksys Wireless-G Broadband Router
I have a d-link router, i need a password to it. how can i get a password
You need to configure your router.
http://192.168.0.1
or
http://192.168.1.1
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Mar 23, 2010 | D-Link DI-604 - 4-Port Broadband Router [...
How do I reset a password that I have forgoten
For that first press RESET button it is in back side of router.
Press it for 10 seconds.
Then connect t\router to computer with ethernet cable.
Then you can access it's configuration with http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Then click on wireless then enable wep security then add new password.
Configure WAN settings as your internet service provider settings.
Enable DHCP.Then save settings and restart router.
Thanks.
Nov 03, 2009 | Linksys Wireless-G Broadband Router
Using the router
First connect your router to computer then access your router as following link.
http://192.168.1.1
or
http://192.168.0.1
Then you can see configuration page .
Then set WAN settings as your internet service provider settings.
Enable DHCP.
Go to wireless enable wireless.
SEt wep security if you want secure wi fi.Add WEP code it is your password to connect internet so only who know the password are connect to your wi fi .
Let me know if you need more assistance.
Thanks.
Oct 04, 2009 | Actiontec GT704WG Wireless Router...
Missing installation cd for 1184 dell wireless router
first connect your router to laptop with ethernet cable. Then u can access it with following link http://192.168.1.1 or http://192.168.0.1 then type user name as "admin" and password is "admin" or blank or "password" then u can see configuration of your router. then check its ip range and enable dhcp and also if there mac security u have to add your mac adrese in allow list u can find your computer mac adreses with command prompt. type "ipconfig /all" in command prompt. then u get alL ADRSES physical adrses is your mac addreses.
Jun 05, 2009 | Dell TrueMobile 1184 Wireless Broadband...
I want to add a port to my Actiontec router, whats involved in do
I am going to make the assumption that you have the Actiontec GT704WG?
You will need to login in to the router using address: http://192.168.1.1
If you've never changed your username and password there, then you should use the default: admin and password. (You should really change that too!)
Click on Security.
You will need to add the port under the Applications area under the security settings.
There are rules established there to allow your game to play, just follow the screen prompts.
Your user guide is available here:
http://www.actiontec.com/support/product_details.php?pid=40&typ=doc
It wouldn't hurt to keep a copy.
Debbie Mahler
MICE Training, Technology & Education
http://mice.org
http://mice.org/blog
Dec 27, 2008 | Actiontec (GT704WG) Router
Reset
Press the reset button on the back for at least 15 seconds so it reboots & load factory defaults. You can download the manual from the link below: http://www.actiontec.com/support/broadband/54mbpswru.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Sep 08, 2007 | Actiontec GT704WG Wireless Router...
Actiontec GT704 Router Logo
67 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
