Question about Sony STR-DE825 Receiver
Protector mode.. Sony STR-D1015 went into protector mode today, checked all fuses, good, blew all dust out, can see no visible heat damage, no leaking caps, what now?
    Sergeant:
    Champion:
  • 319 Answers
I own this model and found if powered from an isolation transformer type surge protector, with other equipment, this may cause insufficient line voltage to unit. Try plugging directly into wall socket, if that was the case. Otherwise, protect indicates problem with circuit, take to prof. tech for check out.
Posted on Apr 13, 2008
    Genius:
  • Sony Master
  • 1,550 Answers
Cambiale los IC de audio que esten dañados.
Posted on Apr 04, 2008
Protector light flashes upon power-up
Audio amplifier IC it's in short circuit you need to replace him
Aug 03, 2012 | Sony STR-D1015
How do i get my sony DA30ES am -fm reciever out of protector mode
I have a Sony DA30ES - 18 years old now (legal age to smoke knock on wood) and started getting clicking, popping, static and other noise that I could whack out of it for a time but recently started getting 'Protect Mode' and no audio.
I gave it a visual inspection and although dusty inside, no broken fuses, bad solder joints, loose pins/ICs or bloated caps. So I was thinking replacing caps due to the age but after fiddling with it and trying to narrow faulty caps I realized there's a BLACK RUBBER CUBE glued to the bottom of the Main Board accessible when unscrewing the bottom plate. When pressing up on this Rubber Cube the receiver would work no problem. So I think the rubber cube has decayed/shrunk (18 years).
I added cut to size sticky foam pieces (from command strips) directly to the cube to prop-up this section of the Main Board with the bottom plate closed and problem solved. Leave it to Sony to build a superior product 18 years ago that still works beautifully today. Sony's high end products only fail due to rubber belts (walkmans) and pieces like this rubber support cube. Thank you Nihon ES Engineers! ?? ??
Jun 09, 2012 | Sony STR-DA30ES Receiver
The word protector starts flashing a few seconds after the receiver it powered on
It indicates you have an output short circuit.First check if all the speaker cables are all right with no shorting of the wires.Next disconnect all the speakers and try turning it on, if you still get the protect display you have to repair the output stage of the Amplifier.You will have to get professional help for that if you have no experience in electronics.
Aug 23, 2011 | Sony STR-D1015
My sony str- is getting a sony protector check code 22. Is that a fuse problem or do i have to get sony to fix it? napa.king@yahoo.com
Unfortunately this is not a fuse problem, as the fuse would burn before the protector check code appears. Probably there is a short circuit and you should take to an authorized sony repair shop. Good Luck.
Flavio/BRAZIL
Jul 22, 2010 | Sony STR-DA5000ES Receiver
Remote control for str-d1015
http://www.dvdremotecontrols.com/Mfrs/Sony/SonyAudio/RM-P341.htm is a website for finding the Original remote for your str-d1015 your remote model is RM-P341 and the link above will direct you to information on the remote as well as where to buy it and how much PLUS A PICTURE :-) hope this helps you
Mar 27, 2009 | Sony STR-D1015
Sony str-de525 system "protector" problem
You've blown it. It recognizes a potentally harmful situation and goes into protect mode.
Mar 15, 2009 | Sony STR-DE935
Receiver goes into protector mode
Nope, power supply it would not even power up.  The capacitors are fried
Jan 04, 2009 | Sony STR-DE635 Receiver
Sony da333es : protector (fan) ;how do I fix this
It's warning you that the fan is dead or clogged. Look at it and possibly clean out the dust bunnies.
Dec 26, 2008 | Sony STR-DE898 Receiver
My sony str-d1o15 says protector
Follow the steps below to troubleshoot if the word PROTECT or PROTECTOR is flashing on the A/V receivers display.
  1. Check the speaker wires and speakers for proper connections.
  2. Reduce the volume level. IMPORTANT: If the receiver is played back at maximum volume level it may enter the protect mode. Maximum volume listening will cause the receiver to run very hot and may drain the output capacitors.
  3. Disable the surround sound option if both the A and B speakers are being used simultaneously.
  4. Ensure the top of the receiver has proper ventilation to keep it from overheating.
  5. If the message only occurs when using a DVD player, the sampling frequency may be set too high. IMPORTANT: Some receivers provide compatibility with the higher sampling frequencies through alternate connections. Consult the owners manual for specific information.
  6. Unplug the AC power cord for about 1 to 2 hours to reset the output transformers.
If the issue is still unresolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Dec 20, 2008 | Sony STR-D1015
Sony STR-DE825 Receiver Logo
1,220 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
