Question about Canon PIXMA MP210 InkJet Printer
How to feed the paper??
I'm putting the paper in but it doesn't feed in, message comes up no paper??
    Sergeant:
    Champion:
  • 240 Answers
Hmmm,,,try clean the tray and then load the paper again or add the paper so the sensor can detect it easily..
if the problem still exist ..
try check the tray sensor.
Posted on May 12, 2009
Paper jam but no paper is jamed in printer
I have had this issue before. I hope this helps you. Try these steps:
1) Open the the top cover; then close it..read the message on the screen. If it doesn't resolve..
2) Remove paper and insert a fresh stack of paper. Making sure that edges are smooth..no creases or wrinkles.
3) Open paper feed area. If you have pipe cleaners available, clean each opening. You can use the fine hose attachment from a vacuum to do the same thing, if needed. Proceed to close the paper feed compartment..read the message on the screen. If it doesn't resolve..
3) Turn off the printer for a few minutes; then power it back on. Printers 'read or sense' the paper as the printing job occurs. Even the smallest shred of paper can cause the printer to identify it as a paper jam
I hope this helped you.
Apr 02, 2012 | OKI C3530N Color MFP Printer
PAPER DOESN'T FEED THROUGH
check on the panel of the printer if the selected paper tray is the lower tray or the upper tray put paper on both tray mark the paper so you can see which tray is being feed,
Aug 04, 2011 | Canon LaserCLASS Fax 710 Printer
Hi, my calculator casio hr 8tec shows the message " e P" and it's doesn't print anything. It`s like it's stuck.... Thanks
It thinks it's out of paper.
Pull out and re-feed the paper.
If it's out of paper, put more in.
If that doesn't help, remove the paper, and take a look at the paper out sensor, and make sure it's functioning ok, and re-insert the paper.
Jun 27, 2011 | Office Equipment & Supplies
We have messages in the memory but keep getting message to 'load Paper' there is paper in the machine . I hvae tried putting fresh paper in , but it comes up with the same load paper message?
first thing is you have to insert new A4 sheet in to the rec/paper tray.then press the STOP key.after machine try to feed the paper in to the printer unit and you can get print.( if the machine cant feet the paper,the machine have some paper feeding problem and you have to get technical support to solve this problem)
Mar 07, 2011 | Canon L220 Plain Paper Laser Fax
I put paper in the printer, but it will not recognize that there is actually paper in the Machine.
The paper feed sensor is malfunctioning.. I would suggest cleaning if that doesn ot work..and it still does not feed you will need a new sensor.. Rate me by advice only Thanks
May 20, 2009 | HP Photosmart 7450 InkJet Printer
HP Photosmart C 7280 paper feed problem
check the feed tray is good, if so.
Clean the feed rollers,
Lint free cloth, distilled water.
Should be good.
Regards
Richard.
Apr 18, 2009 | Office Equipment & Supplies
Paper feed problem
You need new feed components. Feed rollers and retard rollers or pads that stop multisheet feeds.
Dec 14, 2007 | Xerox DocuPrint N17 Laser Printer
Riso GR3770 Paper Jam, Check paper feed
Sounds like you forgot to plug the High voltage transformer or a sensor back
Dec 11, 2007 | Office Equipment & Supplies
Will not feed paper
There could be a small piece of paper or other matter blocking the feed. Try feeding a piece of thin card- simple load and eject don't try to print anything. Or Put a vacuum nozzle in the slot to suck any debris out. Come back for more advice if this is not the answer.
May 08, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP210 InkJet Printer Logo
old marine
old marine
