Question about Dell Latitude D600 Notebook
Dont know whats up doc - Dell Latitude D600 Notebook
  • 1 more comment
  • ROD GANDY May 11, 2010
    NEED MORE INFORMATION IN ODER TO HELP YOU
  • Randy Hough
    Randy Hough May 11, 2010
    Either we can fix it or we can say THA THA THAT'S ALL FOLKS
    Cool name,cool post,But what's it doing?
  • Brittany Garner
    Brittany Garner May 11, 2010
    what is it doing?
Hiya. how come certain files dont copy to my san disk cruzer slice? there comes a message saying 'type of file error' and it tells me to skip.please help me out as i need to back up some files.thaks
If you KNOW what file types these are (eg: .doc or .jpg) try making a copy of one, rename it to the appropriate file and see if that works
(example, you have a word file that is say.. me.doc. make a copy, call it me2.doc, delete the file extension (.doc) then rename it with the file extension again before saving it.. Sometimes this works.
If that does not work, try copying to a different usb disc or device, if it does work, you should reformat and check the san disc for potential future failing
Jan 27, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I have a FIA POPNETSERVER 4600 with no Software or Docs HELP!!!
The IP-address probably is provided by a DHCP-server on your network. Login to that DHCP-server, and look at the list of "active" clients, i.e., computers that have obtained an IP-address from the DHCP-server. One of the IP-addresses should be allocated to your FIA box.
Rather than "flatten-and-rebuild", you probably should investigate new software and new hardware to replace it, *BEFORE* it "dies", forcing you into a "panic-repair" situation, i.e., you need a "BCP" (Business Continuation Plan) which proactively addresses the non-availability of your "unmanageable" server.
Apr 08, 2010 | FIA Storage Systems Group POPnetserver...
No new txt doc.
There is never ant option for .txt docs. It is only for a word doc and what you save it as is your problem. So, dont worry about it. After .txt you will ask for normal txt or rtf. The list is very long. So, the short cut is to open a new doc and save it as whatever you want.
Aug 22, 2009 | Microsoft Windows XP Professional
Easy one for you i guess , but i have just designed a sales page in word but i dont know how to save it so it can be uploaded to my host ? what should i save it as and what type of file ??
if you are using microsoft office 2007 then by default it save as docx form..... I suggest you to save this file into the doc 2003 which have a utility in ofice..to convert in doc 2003 format...(because most of the user still using office 2003)
Just go to file option menu and there is option for save as click and save this doc.....(if you find a solution plz rated us)
Hope it will wrk for you
May 14, 2009 | Microsoft Office Professional 2007 Full...
Compaq a1500 printing probs
ok you might have tried printing a doc/app out earlier and it might have failed so while you trying to print out this present app/doc the printer still might be focused on that failed or it might be confused. Now to stop this follow these instructions. Go to the start bar click control panel. Then once that window pops up ( control panel ) click printers and other hardware. Then once that window pops up ( printers and other hardware ).  Click Printers and faxes and that page will have all the printers and faxes ever installed to your computer. Now click on the printer thats yours and then a smaller wider window will appear you will that window will have all the doc/app you have ever tried printing out. the status bar will show what is going on with each doc/app. Now you should first stop all the doc/apps and refresh. To do this you should highlight all the doc/app and then go into the document tab ( there are several tabs in this window such as document , printer, view and help) then click cancel and cancel all the doc/apps. last step is to go into the view tab and click refresh and it should work :-). If not contact your printer manufactor.
Jul 09, 2008 | Compaq A1500 All-In-One InkJet Printer
Dell Latitude D600 Notebook Logo
467 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
