Question about Car Audio & Video
1600 watt pyramid royal blue 2 channel amp need diagram of amp itself
My car amp is a 1600 watt pyramid royal blue 2 channel and it keeps blowing the fusses and i smell burning when i take it apart i can see where the burn marks are but i need a diagram of the amp to figure out what the part is that is burning the model number is (pb-1236gx)
If i keeps blowing fuses then it means the amp is bad
Posted on May 13, 2009
I've bought a pyramid crystal 1000 watt 2 channel amplifier used it states it runs at 4 ohms can I run it at 2 or 1 ohms and if so what will the wattage be?
Not to disappoint you too much, but the 1000 watts advertised is just marketing hype. If your amp is the PB781X, it should have only a single 15A fuse on it. Your battery provides 12.5 volts when the engine is off, so at most, your amp draws 187.5 watts of power. Draws, not outputs. No amp is 100% efficient due to heat. When your engine is running, assuming your alternator outputs 14.4 volts, your amp's maximum power draw is about 216 watts. Again, this is what your amp draws, not what it puts out. What you should focus on is the RMS (continuous) output, not Max or PMPO. Those numbers are useless, unfortunately.
Your amp is rated to output 50 watts per channel at 4 Ohms, and 75 watts per channel at 2 ohms. This is when wiring your channels separately, not bridged. I did not see true power specs for your amp while bridged, but it's possible you'll just get the full 150 watts to the single bridged output. Do not attempt to apply a 1 ohm load to your amplifier, as you will run the risk of damaging it. It's not designed to handle a 1 ohm load. If you're lucky, you'll blow a fuse before the amp is damaged, but either way, there is nothing to be gained by attempting it.
Sep 12, 2017 | Pyramid Car Audio & Video
Need advice on setting up amp with my two speakers.
This is hard to explain and what needs to be done is wire in parallel both subwoofers. This website will help just put in the amount of speakers and amount of ohms each and it gives you diagram.
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=81#results
Mar 24, 2010 | Pyramid ZPA150 Car Amp
Amp for 12" Alpine Type R DVC 4ohm
i actually have 2 12" type s's and i did the same thing just wanted a cheap amp... i went on ebay and bought a pyramid 1600 super blue series amp..... its 1600 watts and ive also hooked it up to type r's and it POUNDS!!! ill copy and paste the website where i got mine from on ebay... if you tune it right it'll make it so you cant breathe inside your car......http://cgi.ebay.com/NEW-1600-WATT-PYRAMID-PB559X-Car-Audio-Amp-Amplifier_W0QQitemZ350169009069QQcmdZViewItemQQptZCar_Amplifiers?hash=item5187b30bad
Nov 11, 2009 | Alpine Car Audio & Video
Hi,just bought a 6x9 jbl gto937 speakers for my car,each speaker is 100watt rms and 300 max .Can anybody advice on what amplifier should i get for them?I know i can run them without any amp but think they...
Pyramid makes the PB series of amps. I have one that's driving a Sub.
The PB 700 puts out rms 60watts x 2 @ 2ohms, which gives you some "headroom" for your speakers. You don't want to over drive speakers with , for example, a 1000 watts for 100 watt speakers, because that's a good way to blow your speakers.
There are many brands and models of amps that will fit your speakers. Just make sure the amp will drive 2ohm speakers, since your jbl's are rated at 2ohm impedance.
You may want to consider adding a Sub woofer to your setup. A single Sub would fill in the low end very nicely. If you got a 4 channel amp, then two channels will drive your jbl's, and you can bridge the other two channels to drive the Sub. That would be a kick'n sound!
Just make sure the amp is bridgeable
For example, the Pyramid PB 1200 is a 4 channel, bridgeable amp. This particular amp will drive the 2ohm jbl's, but you would want a 4 or 8 ohm Sub connected to the bridged channels.
Jul 05, 2009 | JBL GTO937 Car Speaker
Wiring issues
ok here is how it goes power wire from the battery all the way to amp..then ground wire from amp to a good ground on car then the remote wire which you have to run from the amp to the back of your stereo which in most cases is blue then hook subs from the sub box to the amp
May 30, 2009 | Legacy 2 Channel 1600 Watt Bridgeable...
Pb1281x pyramid crystal 2ch mosfet amplifier 1600w what size fuze i got a 20amp in it it blows when i got it terned up
Hello sunshanel,
You did not say what you have the amp connected to and what the impedance load is. It is only stable at 4 ohms and if a lower impedance is connected, say 2 subs in parallel, it would try to produce more power when you turn it up and would most likely blow the fuse. 20 amp sounds right for the amp. The power rating of 800 watts per channel is peak power, not RMS, and many low-end manufacturers tend to state bigger numbers in the ratings.
Hope this helps.
Apr 26, 2009 | Pyramid PB1281X Car Audio Amplifier
Amp over heating and cutting off
sounds like the Impedance of the speakers does not match that of the amp, therefore the output stage of the amp is trying to compensate, driving the amps too hard and eventually causing the thermal cut out to activate. Check the ratings on everything are compatible before you start sending it off to be fixed.
Mar 22, 2009 | Pyramid PB736GX Car Audio Amplifier
Speaker amplifier calculation
for $85 i can sell you an Almani 900 watt 2 channel amp i would stay way away from those 3 brands they are all really poor quality and i can get you any major name brand cheaper.
I can get you a hifonics 4008 amp (800 watts peak 100 watts per channel rms) for $100 shipped with full factory warranty. you find an amp you like and i will get you a price. I am a factory wholesale distributor for most brands.
Jan 08, 2009 | Legacy 2 Channel 1600 Watt Bridgeable...
2006 12" Kicker L7 4 ohm
first whats the range in terms of WATTS that your 12" sub can handle in 4 OHMS ? second , lets check the AMP , POWER ACOUSTIK 1800 WATTS , Now thats a lot of power to drive a single 12" sub speaker . your amp is 1800 watts , per channel is around 500 watts , if BRIDGE thats around 1600 watts rms for ONE channel , if your sub can handle that kind of wattage fine , but it will not blow the amp , what it does is shuts down , some kind of protection mode , it will come back on after a minute or so. I suggest to use one channel in stereo mode , or purchase another sub to use the other channel. i hope this helps AJ
May 06, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Car Audio & Video Logo
453 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
