Question about Epson STYLUS R230 InkJet Photo Printer
I am having problem with Epson R230 printer. whn ever i print i get message "Parts inside your printer are at the end of their service life" what to do.
  • saikanth_p May 12, 2009
    NO it doesn't work
  • Dixit Sardana
    Dixit Sardana May 11, 2010
    Does it print okay even after that error?
  • 813 Answers
Try this:
  1. Unplug the power and USB cables from the printer.
  2. Prepare your work area by putting scrap paper down. Have some spare, just incase. You may also require tissue paper. It is also recommended you use protective gloves as the ink will stain your skin for quite some time.
  3. Unscrew the screw at the back of the printer.
  4. There are two or three tabs at the back and two at the front. Gently push them in, and then using a bit of force pry apart the cover.
  5. At the back of the unit you need to locate some white pads, or sponge type things, initially they will seem fine, but they will infact be full of ink. You need to grab a pair of pliers and pull them out one by one, there should be four, put them on your scrap paper.
  6. Take the scrap paper with the pads on to your sink, turn on the hot tap and hold each one under the tap using the pliers until the water runs clear. If you have protective gloves on it may be worth squeezing the water out also.
  7. It is recommended that once you have done this, you let them dry.
  8. Now return the pads back into the printer.
  9. Put the printer back together, (mind out for the paper alignment, and give it some force), not forgetting the screw at the back.
  10. Plug in the USB and power cable and turned it ON. (Yes the lights will still flash)
  11. Download and install the SSC Service Utility for Epson Stylus Printers from http://www.ssclg.com/epsone.shtml
  12. Select your printer and model number (There is no Stylus C42 UX, so select Stylus C4x), then close the window.
  13. If it asks if you replaced with the pads; say “YES”. Then close the window.
  14. You will see a SSC Service Utilitiy icon (it looks like a printer) in the system tray (next to your click), and LEFT click.
  15. A menu will appear, from here you can click on “Protection counter” (its a red cross), then “reset protection counter”.
  16. Turn the printer power OFF, wait 10 seconds and then turn it back ON.
Done!
Posted on May 12, 2009
3 Suggested Answers
SOURCE: service required for EPSON STYLUS R230
red light bhoth blinking
Posted on Dec 28, 2009
Probably need to have the ink pads replaced in your printer, I would call Epson for support.
Jun 16, 2011 | Epson STYLUS R230 InkJet Photo Printer
Parts inside your printer are near the end of their service life. See your printer documentation
Hi!
Click on this link for more information about that message. Click HERE.
Hope this helps.
Dec 13, 2010 | Epson STYLUS R230 InkJet Photo Printer
Is saying parts have come to the end of their life service needed
Your waste ink tray is likely full. The machine has a small container with a felt-like pad in it to absorb ink that is expelled during cleaning cycles. It is telling you that it is full so that ink does not spill out and make a mess where the printer sits. You should either have it serviced or purchase a new printer. Purchasing a new printer is likely less expensive, but beware of which one you buy. We have had customers bring new Epson cartridges (Epson 97 series) to us and tell us that they only got 25 pages of printing out of the black.
Jan 19, 2010 | Epson STYLUS R230 InkJet Photo Printer
How can i solve my problem in my EPSON R230." this is the message that will display in my screen...: Parts inside your printer are at the end of their service life. and its ink and paper lights is...
Care to read this link
http://www.fixya.com/support/t1905683-r230_photo_printer_epson_stylus_sevice
http://www.fixya.com/support/t2015031-two_red_light_blinking
Sep 24, 2009 | Epson STYLUS R230 InkJet Photo Printer
It's is asking service required,
parts inside your printer are near the end of their service life. This is message is coming, how can i do this problem, please tell me
Sep 06, 2009 | Epson STYLUS R230 InkJet Photo Printer
EPSON Stylus Photo R230 Series
don't replace the ink pads install a external waste ink tank instead, then reset the printer using reset program . . search on eBay for epson waste ink tank, search ebay for "Epson Waste Ink Tank" it comes with reset program.
Aug 11, 2009 | Epson STYLUS R230 InkJet Photo Printer
Parts inside your printer are at the end of their service life. See your printer documentation.
Reset the waste ink counter!
Assuming you have completed your modification you can reset your printers waste counter using this method (I did this and it worked on the CX6400) can't guarantee it works on all)
1. You will see big button on your printer like power on (this is on the left
2. side), black & white photocopy, color photocopy, and then the stop button (these are on the right side).
3. first turn off your printer
4. push the b/w + color + stop buttons together and hold
5. push the power on button and hold (so you'll now be holding down 4 buttons together)
6. Don't release all the buttons until you see the light indicator is blinking and then a message display on the lcd
7. release all the buttons
8. push the color button (once)
9. turn off the printer
10. turn it on again
After this one may need to reload the printer driver and locate the printer!
May 27, 2009 | Epson STYLUS R230 InkJet Photo Printer
PART INSIDE YOUR PRINTER EPSON STAYLUS PHOTO R230 ARE AT THE END OF THEIR SERVICE LIFE SEE YOU PRINTER DOCUMENTATION
Parts inside your printer are near the end of their service life. See your printer documentation.
Mar 09, 2009 | Epson Stylus Photo R200 InkJet Printer
Service required for EPSON STYLUS R230
http://www.efillink.com/Support/HowToWasteInkDrainR200.html
Sep 25, 2008 | Epson Stylus Photo RX700 All-In-One InkJet...
Epson STYLUS R230 InkJet Photo Printer Logo
292 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
