Question about 2wire 2700HG-B Router (2700HGB)
2wire 2700HG USB Wireless Adapter for Vista
I have a new computer and my Qwest cd is missing! I need to install this router. I have tried everything that I can find to install it, however, when I go to configure it says that the key is wrong. I don't know if the insall I did was for vista or not as I installed one that was for xp and had to reinstall. Please advise as 2Wire won't give me any help on finding the download and Qwest is just about as good as 2Wire. Thanks!!
  • kelley6mom May 12, 2009
    the cable is no were near the computer....near impossible to get it there without tearing apart the house....is ther another solution???
serra_baby
  • 144 Answers
SOURCE: win98, Linksys USB Adapter, 2wire router... no internet
hello!
try to uninstall/remove the old driver and reinstal the latest driver of your linksys usb adapter. you can download it from the linksys website.
check again if you can get a wireless connection from the router to your 98pc. if not try to change the wireless channel of the 2wire to channel 1 and configure the wireless security again using the linksys usb wireless utility
if you still cant get a connection try to manually assign this ip address on the 98pc then check connection afterward.
IP add: 192.168.0.5
subnet mask:255.255.255.0
gateway:192.168.0.1
dns: dns number of the 2wire router
if you still cant get a connection after this try to install the wireless usb adapter to a diff computer to further isolate the problem.
Posted on May 08, 2008
  • 310 Answers
SOURCE: 2Wire USB Remote NDIS Ethernet driver
U can get driver from this site
http://www.dsldepot.com/dslmodem.asp?mm=9
Posted on Jul 10, 2008
scrodamoon
  • 659 Answers
I uploaded the drivers to my server for you hope it helps!
http://www.files.hpifdesigns.com/drivers/BT1800HG_Drivers.zip
Posted on Aug 02, 2008
  • 4 Answers
The drivers are located on the 2wire website. You need to go to support > downloads > Gateways > 100/1000. Those drivers will work for any 2wire gateway that has USB.
Posted on Dec 03, 2008
SOURCE: 2Wire router
I had a similar problem, but instead of no connection, our connection kep dropping. We were about 100feet from the router, using a Belkin USB wireless adapter on a desktop running XP. I went into the router, changed the power setting dropdown from 6(default) to 10 and when I hit save, the connection status lit up super fast and has stayed in "excellent" for a few days now! YES!
Posted on Dec 12, 2008
I use 2Wire router and usb adapter. I switched
you dont need to install the driver for the 2wire, you just need to configure the computer to look for the 2wire, if unable to locate the 2wire from your computer, there is a problem on your 2wire it self
Jun 13, 2010 | 2wire (1000-100052-000) 802.11g/b Wireless...
Can't re-install 2Wire USB Wireless adapter
If you are on windows vista it could be your driver. You can go into safe mode on the computer with F8 while the computer is starting up, then go to the control panel and device manager. Plug the adapter in and remove the driver for it. Download a new driver at http://support.2wire.com/index.php?page=download and install it.
Mar 30, 2009 | 2wire HomePortal 100W (1000-400026-000)...
I have a new Dell with Windows Vista and I cannot access my 2wire
the key is in brackets on a sticket on ur modem
should be 10 digits long
Mar 29, 2009 | 2wire 2700HG-B Router (2700HGB)
2Wire 802.11g USB Wireless Adapter driver in qwest
try getting the drivers from
Dec 09, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
2wire wireless usb adapter installation for desktop
elomarcillo1,
You are attempting to install a (brand name) 2wire wireless usb adapter, normally the SBC DSL CD is ONLY what you would use to set up your SBC DSL modem. You should have a specific 2wire CD that you put in your CD Drive when you want to install the 2wire wireless usb adapter. Can you locate this CD?
-ms
Nov 09, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
Computer can't detect 2wire adapter
*Heres the thing youre doing the right thing install the driver, make sure that you remove the the 2wire wireless manager in the add/remove program and leave the 2Wire Wireless LAN USB driver
*To connect your computer to the 2WIRE router make sure you know your SSID or the network name and the network key, if you call the AT&T Uverse tech support they will ask you to configure the wireles network key to your phone number
*The default SSID is 2wire and the last 3 digits of the serial number of your Router and the Default Netowrk key is located @ the bottom of the router theres a sticker and it is under S/N
Jul 25, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
WUSB Linksys adapter connnection
check your dns value ,firwall,proxey server, ipaddress and router configuration also.
Jun 23, 2008 | 2wire 2700HG-B Router (2700HGB)
Use 2700 as router only?
there's a way to make the gateway act as a router only but it's not really recommended since there's a possibility that the connection will not be as stable as it should.
anyways you can try the following steps in making your gateway act as a router (not really a router but just a switch and a wireless access point).
- access the router's web user interface by typing http://192.168.0.1 on your web browser
- then click on the "Advanced Configuration Settings"
- select the "Transparent Bridging" option (note: you must configure your wireless settings first before trying these steps since you might not be able to access the gateway's page anymore once you save the changes)
- set the vpi to 0 and vci to 32 if it asked you for those settings. next to 'ATM PVC Search' select the radio button next to Disable. ensure Bridged LLC is selected next to 'ATM Encapsulation'.
- then save the settings
- connect now the new modem to one of the ethernet ports of the 2700hg-d using an rj-45 or an ethernet cable
hope this'll help you.
Jun 09, 2008 | 2wire 2700HG-B Router (2700HGB)
Wiring up 2700hg-b wireless router
Hi, you will need a ethernet card in the pc to connect up a wireless router, most dont work with usb,
otherwise you would need a wireless adapter.
once you do get it connected, go into internet explorer and type in the ip adress for the router, will then come up with a menu for you to programme in your broadband details, once you get the router up and going, go into the PS3 settings, network settings, it will pick up the router all you need to do is enter the network key and its all go from there.,
ethernet card should cost you about £10 from any shop
Happy New Year
John
Jan 01, 2008 | 2wire 2700HG-B Router (2700HGB)
2wire 2700HG-B Router (2700HGB) Logo
225 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Bruce Silvernagle
Bruce Silvernagle
Level 1 Expert
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
