Question about MSI K9N6PGM-F Socket AM2/ nVIDIA MCP61V/ DDR2/ A&V&GbE/ MATX Motherboard [7309-040(K9N6PG... (MB-K9N6PGM)
My motherboard won't turn on...won't power up.,,.. model: msi k9n6pgm2 tried, replacing PSU, still thesame...
  • 400 Answers
SOURCE: got new msi motherboard k9n6pgm2-v works ok with
Perhaps one of your ram chips is bad, or the new ram is not compatible with the old. I would swap out one stick at a time to find the bad one. Another possibility is you need to go into BIOS and accept the ram change. I hope this helps.
Posted on Oct 23, 2009
Zacnickp
  • 33 Answers
SOURCE: no display
first thing, make sure there is a speaker so you can hear the beep codes, those are critical, and then configure your computer with the least amount of prepherals possible, one ram module, the cpu,and the integrated video card, if no integrated, then only one video card, try pulling out all ram modules and listen for a beep code, they can be very quiet, lastly stalk the motherboard for burnmarks, you could have a fried board, especially if you disconnected something while it was on, or within 15 seconds of disconnecting power...
Posted on Feb 17, 2010
  • 80 Answers
SOURCE: I Want to msi 7309
please find all your drivers at the following link:
http://www.msi.com/service/search/#/?kw=K9N6PGM2-V&type=download
Regards,
Posted on Jan 11, 2011
Lady Nel
  • 97 Answers
SOURCE: Good day i have problem
Since you mentioned that you tried to remove everything, it's possible that your monitor is defective.
Try testing another monitor to your pc to prove what is wrong.
Hope it helps.
Thanks!
Posted on Feb 03, 2011
  • 7 Answers
SOURCE: I installed a msi k9n6pgm2-v2 motherboard - and
Have you checked the BIOS jumper? Sometimes it needs to be seeded as per the manual the other thing to check would be to make sure your start button functions, I have had a bad button on a tower before. You should be able to use a small screw driver or paper clip and jumper over the posts for the start button on the Mother board and see if you get anything. This might have already been checked, but are you sure the Power supply is ok? You may already know this as well but just verify your ram is in the "0" slot as well.
Posted on Apr 15, 2011
I have the MSI K9N6PGM2-V MOB and i want to but the MSI ATI 6870 HAWK ON IT will it run it even thow it has a PCI 1.0 port the card has a PCI 2.1 port.
Dont do it , it wont run cause voltage is different and you might damage both card and motherboard if you try.
Jul 18, 2011 | MSI K9N6PGM2-V Motherboard
Do not have network driver
try to download it thru www.msi.com and search for the appropriate network driver to it
May 31, 2011 | MSI K9N6PGM2-V Motherboard
Good day i have problem with my motherboard msi k9n6pgm2 it turn on but no display i disconnect all peripheral dvd rom, hdd,pci e video card.... no beep at all plss....
Hope it helps.
Thanks!
Feb 03, 2011 | MSI K9N6PGM2-V Motherboard
I have a MSI K9N6PGM2-V mother board with AMD CPU. It has problem to read hard drive or DVD writer during bootup. The BIOS of mother board can see the two drives. However, it cannot read data from any...
Hello, Please try and insert the DATA cable properly from the motherboard to the hard disk as well as DVD writer,and try and interchange the power cable to this devices, or change the power pack and see if the problem continues.It might be that the power to this devices are not enough. If this fails, then try installing a different operating system. Cheers
Dec 08, 2010 | MSI K9N6PGM2-V Motherboard & AMD Athlon 64...
K9N6PGM2-V2 motherboard.. I power it on & the monitor doesn't come on..I have had it about 2 months & this is the first time I had a problem. I change out my dvd player & when I turn it back...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to boot
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 05, 2010 | MSI K9VGM-V Motherboard
MSI K9N6PGM-F Socket AM2/ nVIDIA MCP61V/ DDR2/ A&V&GbE/ MATX Motherboard [7309-040(K9N6PG... (MB-K9N6PGM) Logo
208 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
