Question about Epson Stylus Photo R220 InkJet Printer
Colour matching I cant get my printer to match the colours on my screen, they always seem to be darker and also different shades. Any Suggestions please
  • 363 Answers
There should be some adjustment in the printer properties dialogues.
But first make sure the profiles for the monitor and printer are set correctly.
See
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/icm_sync_monitor_printer.mspx?mfr=true
Posted on Oct 13, 2007
I have white kitchen cupboards. What color should the wall be and what color for the back splash. No window in the kitchen.
Bear in mind that the splashback will be with you for a fairly long time, so pick a colour that will last and not bore you. Also if the splashback goes behind the hob make sure that you pick a shade which won't show grease marks too easily. As far as the wall colour is concerned, pick something that will tone with the splashback but is maybe a couple of shades darker. You can always change the wall colour in a year or so if you want to.
Jun 16, 2015 | Kitchen Ranges
Colors not matching computer
It is possible your colour cartridge has cross contaminated the ink reservoirs. To check this take the colour cartridge out and turn it over to see the coloured pads. They should look red, dark blue, and orange ( the colours are actually Magenta, Cyan, and Yellow, but are concentrated). If any of the pads are pale or particularly green - change the cartridge.
If the colours look alright, your issue is probably that your monitor makes colour by emitting light frequencies so is bright, printed images make colour by absorbing light frequencies so will always be darker. There is always the issue of course that your monitor also has a colour "temperature" bias. Photo pros calibrate their monitors and printers to match.
Mar 25, 2012 | Canon PIXMA iP90v Printer
The printer is not printing the same colours that are on the screen
How different is the color from the printer with the screen? If, you can see yellow, but the printer prints a shade of green, then your ink (particularly the cyan color) may be leaking. Check your ink cartridges if there are leaks. If there are none, try printing blocks of colors and see if the colors match with the screen. If they don't match, maybe try using a different monitor and see if the problem persists.
Apr 04, 2011 | Brother Office Equipment & Supplies
Printed colours doesn't match with monitor colours
Here is a list of reasons why colours on electronic designs might differ from printed designs:
  • Monitors work in the RGB (Red,Green,Blue) colour space while printers use the CMYK (Cyan, Magenta, Yellow and Black) colour space.
    Designs look fine on a monitor if they are designed in RGB to begin with. Converting them to CMYK might make them look odd on screen, but they will print correctly, to a certain measure. It is difficult to sign of an image file that is currently in CMYK mode while viewing with an RGB monitor.
  • Monitor settings differ.
    The designer was sitting in a darkish room when choosing the blue and his blue looks vibrant. The client was viewing the same design in a well-lit room, making the blue seem lighter. The designer uses an LCD display and the client uses a CRT monitor and the vibrancy differs. The contrast and saturation settings on each monitor might differ as well, rendering the blue with different values.
  • Each printer in the world prints colour slightly different.
    Sometimes it is really obvious and sometimes it is almost impossible to see the difference. Normal desktop printers are definitely not something to do colour proofing with. If you print the design out on your desktop printer then a slight shortage on any of the colours will make the colour come out wrong. There are a lot of factors that can influence even the most expensive printing equipment. These include altitude, humidity, the current heat of the printer, age of the printer, quality of ink, the paper that is being used, special coatings on the paper etc. Even viewing the same printed material in different lighting conditions may make the colour seem different.
Tips on getting the most accurate colour
Go to your nearest printer company and ask to see their Pantone colour matching system. Each colour in the Pantone chart has a matching number. Most design applications have the same Pantone charts built in so that colour matching is easy. Read up on Pantone at Wikipedia. Make sure that the file is converted to CMYK (If not designed in it originally) before sending it to print. Some printer companies might ask for colour separation prints which the leading design packages can produce. It is also important for the designer to choose the correct colour management profile in the design package.
Dec 05, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Ap3800c will not print the colour it sees
So the quality is good, it's just not "exactly" like the screen? It never will be "exact". Depending on what you're describing, if the colour is off, it could need the drum(s) or Development unit(s) replaced to improve the quality; however, if your just talking about "matching" the screen colour, you could line up 100 different printers and you'd get 100 different outputs....it's not an exact science. Perhaps you're using a generic toner vs. the OEM brand, this would change your results too.
There are also 3 different printer "languages" (drivers) that the printer can print with: RPCS, PCL 5c, and Postscript 3. All of which will give slightly different print qualities. You may want to try installing a different driver than you're using, and you may prefer the output. Postscript 3 is the best in my opinion.
you can go to this link, select your OS, and download another driver:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/p3800c/p3800cen.htm
I hope this helps.
Jun 05, 2009 | Ricoh Aficio AP3800C Laser Printer
Color matching
If this is a print problem and not just a screen issue, here's what I suggest.
In Illustrator, double click the colour swatch for the Pantone Book colour you are using and obtain the CMYK values.
In Quark, instead of using the same Pantone Book colour, create a new Process colour with the same CMYK values as the Illustrator swatch.
May 20, 2009 | QuarkXPress
Colour from printer does not match colour shown on screen
The manual WILL have instructions on which ink to use, it will be by the same company and have a special number. If you cant find out what it is just ask PC-WORLD or google search it. Simple :D
May 20, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Prints light purple instead of grey
I think your Black Cartridge is Empty. Check it and replace it with the new one.
Your Printer is trying to produce Black Colour from your Colour Cartridge with a mix of Cyan, Magenta and Yellow.
Apr 23, 2009 | Canon PIXMA MX850 Multifunction Printer
When printing is give it prites in 4 colour always
put that color chart on the glass with the darker end facing the let, and then press start. You will have to do it about 3 different test, so keep follow the intruction.
Apr 14, 2009 | Canon imageRUNNER C3200 Copier
Epson Stylus Photo R220 InkJet Printer Logo
52 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
