My washing maching will not spin and is giving an oe error
  • 15,935 Answers
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
Gives you the error code for the spinning does not work
If you have the error code # you will find it on the net.
Sep 09, 2015 | Washing Machines
WASHER DISPLAYED "OE" NOW IT WILL NOT DO THE SPIN DRY
Hi there, my mum actually had that problem with her LG washing machine, we did clean out all the drains and hoses just like you did, and also checked the pipes for any damages(cracks/ bends). Turns out the cause was that the machine just wasn't sitting level, so it wasn't draining out properly. Water just collected inside the front of the machine causing that error. Check if the machine is level, and while you're at it check your filter for clogs.
Mar 08, 2014 | Kenmore Washing Machines
My washing machine is giving me code OE. it is not not spinning. checked the belt and it is fine. any help would be great. thanks kylie
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
Jul 30, 2011 | Washing Machines
Machine doesn't drain & spin, it says "OE" or sometimes some other message "E something"
Here is a tip that I wrote that gives more detail about how to fix the OE codeon LG washers....
LG Washing Machine OE Error Code
heatman101
May 23, 2011 | Washing Machines
Dryer does not spin dry, water left in drum...Error code OE
heatman101
May 02, 2011 | LG Dryers
My lg washer will not spin out it keeps flashing OE no matter what i do
Here is a tip that I wrote that gives more detail about how to fix the OE code on LG washers....
heatman101
Sep 02, 2010 | LG WM-1832C Front Load Washer
NEC washing machine won't spin. Letters OE flashing
Jan 06, 2009 | Washing Machines
LG WM2277HW trouble
take off the front kick plate on the bottom and there is a pea trap thats conected to the pump twist it off and see if it is cloged thats what usaully makes it not spin
Aug 11, 2008 | LG WM2688HWM TROMM SteamWasher
WATER WILL NOT DRAIN OR SPIN
OE is inded a drainage error.
From what you describe it is most likely that the drain motor is not working properly due to a loose electrical connection or bad motor itself. This is not that easy to verify since it requires some machine moving and disassembly to get at it.
I can give you further instructions if you like...
If your machine is still under warranty you should call someone in for service.
Aug 06, 2008 | LG WM1815CS Front Load Washer
Washing Machines Logo
78 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
