Question about Acer Aspire 3680 Laptop
How do i switch my default hard drive from c: drive to d: drive
How do i make my d: drive my default drive instead of my c: drive because everything saves to my c drive and its full and i still have 30 gigs free on my d: drive? I have an acer 3680. Any help would be appreciated, thank you. Nate Patterson nathan_globaltech@msn.com
    Problem Solver:
  • 3 Answers
Ei... its so simple.. just reinstall all the files that you have in your drive c then install that in your drive d when you are asked where to install that file... (just uninstall  the files that you have an installer to those files so that you can install it again)... but if you hAVE THE  installer for windows reformat it then choose your drive d as your bootable drive instead of your drive c...
Posted on May 12, 2009
My 2002 mazda premacy sticks in gear when the transmision is cold,what can i do to fix this
I would consider a transmission oil change to freshen up the oil . The hard braking may be that there is a rust build up on the rotors and that makes the pads grab for a few applications. May be a way to fix the gear problem is to start it and let it idle for say 10 minutes to allow everything to get some heat into it instead of starting and driving immediately
Jan 24, 2014 | Cars & Trucks
I got a new hard drive for my dell dimension 2400. I have tried everything I know to do, jumpers to cable select, master. I know the hard drive works as I hooked it up along with my old drive and cloned...
Enter the BIOS (setup menu on power on) and then holddown the key and depress the then the keys insuccession. This will force the motherboard to load default settings and alsoforce the motherboard to redetect all IDE devices. Note: The selection for thefloppy drive will be set to ON. If you do not have one then you must disablefloppy in set up (BIOS) menu.
Aug 27, 2011 | Dell Dimension 2400 PC Desktop
Where do i get the usb format utility for my G3 external hard drive
right click on drive in my computer select format leave default options and hit ok simple as that you don't need an extra utility
hope this helps
regards
djbr1ck
May 13, 2011 | Samsung G3 Station 1TB USB 2.0 Black...
What is the maximum size of hard drive for the travelmate 2300
Please keep in mind this unit uses IDE hard drive instead of SATA. The default 2300 uses a 30 GB high-capacity Enhanced-IDE hard disk. With latest BIOS upgrade, this unit will be able to have anything installed. 80GB, 160GB, 250GB, 320GB, 500GB.
However, I believe that IDE hard drives are slowly but surely becoming obsolete and legacy and they seem to be more expensive as well.
May 16, 2010 | Acer TravelMate 2300 Notebook
I disconnectd my hard drive from the computer and let someone else plug into my cumputer with there hard drive. since i did that mu computer is caling my hard drive f instead of e. i have it pluged in the...
Don't worry, if it works. You are talking about external HD with USB connector?
The computer assigns the drive letters in 'operational order' and it doesn't matter in which order they go. In WinXP - system the drive letters 'rearrange' after reboot.
Oct 24, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Can't fin hard drive in bios
try switching the jumper pins on the hard drive to slave instead of master theirs alot of stuff that can cause this like the hard drive might have died but thats only one reason and that might not be it at all
May 28, 2009 | Dell Computers & Internet
Hard drive
For programs installations you would have to manually change, redirect or point the program folder locations to the Lenovo disk ( E:/ or F:/ , etc, etc).For all other personal documents, image files, music files, video files you would have to do the same thing, go that programs (whichever program you use) options or preferences and edit the default file save locations to point to the Lenovo ( E:/ or F:/ , etc, etc) instead of your C:/ drive
Jan 18, 2009 | Lenovo IdeaPad Y510 Notebook
Hard drives western digital essential edition 500gb
Start with this document - http://www.wdc.com/en/library/usb/2079-701081.pdf You should have received a CD with your drive that has all the software you need on it. Additionally, you will need to have a home network hub or switch to connect your computer(s) and your drive. For additional information on home networks and how everything is connected, see this article: http://en.wikipedia.org/wiki/Home_network
Sep 11, 2007 | Western Digital 500GB My Book World...
No display and not functioning
I suggest that you clear hard drive and reformat it,again.Most of the time,booting from a floppy or optical drive,does the job satisfatorilly.I will suggest leaving your BIOS settings in their default state and make your adjustments when everything is up and running. from:justIT
May 11, 2007 | IBM eServer xSeries 206
Acer Aspire 3680 Laptop Logo
95 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
