Question about Vivitar ViviCam 5100 Digital Camera
Bright pictures it doesn't matter what setting the flash is on (or off), the pictures turn out too bright, & some have lines through them!
  • 797 Answers
If this is in the normal modes, try the following.
Go to the set up or menu and reset all.. what you are doing is resetting all settings back to default or factory settings.
If the problem does not show at all in any of the menus or playback from a card, then the problem is more than likely a ccd problem of some kind. This problem may be fixed for free, not sure if Vivitar will fix, but worth a try to email or call them at:
Go to:
http://vivitar.com/en-us/Support.aspx
Ask for your model.
Posted on Sep 29, 2008
SOURCE:
Regarding Samsung LCD TV LN37A550P3FXZA. On 4/9/17 picture became too dark, looking like brightness setting is way too low and color saturation too high -- I'll call this the "Too Dark Picture."
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 10, 2017 | Samsung Televison & Video
Turn tv on,picture good for 4 seconds,then green curved line like a rainbow all green,then 4 green sequence flashes,picture goes out theN volume continues for 2 seconds then out front red power light then...
This is a set with bad picture tubes-not available except on rebuild basis.
Are you seeing bright green screen and then set shuts off?
Let me know so I can help--8 blinks is AKB error.
SD TECH
Sep 15, 2010 | Sony KP-51HW40 51" Rear Projection...
Pictures turn out too bright or too dark...
Go into the menu and find "reset"...follow the on-screen instructions.
Feb 05, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
I have a brand new Finepix S8100fd camera and the majority of the photos are speckled no matter what setting I use. However the super macro setting rocks and pictures are super clear! My Fuji 7.1 mega
Common issue with the A8100fd. The most likely problem you are having is not enough light. Try shooting in bright sunlight to test the "graininess". Make sure you use the flash anytime the light is not bright. Even though the camera will shoot in low light (without flash), because it defaults to a high ISO setting, which (just like film) accentuates the "grain", or more properly termed in digital photography, "noise". Set the camera for a low ISO setting and use the flash whenever you see the "red hand" symbol on the screen.
Apr 22, 2009 | Fuji FinePix S1000FD Digital Camera
Turn on pic turns red with thin bright red horizontal lines
Sorry to say, but that's usually the sign of a bad picture tube. One of the elements inside the tube shorts and you see the picture you describe, and the set shuts down due to high voltages getting to places it shouldn't. There's no solution except picture tube replacement, and that is uneconomical. You're better off replacing the TV when the tube goes bad.
Mar 31, 2009 | Toshiba Televison & Video
Flash makes my pictures too bright/too dark
u might want to try and put a coffee filter over your flash when you take pictures to make the flash less bright. it sounds really silly but it actually works.
Oct 29, 2007 | Samsung Digimax S500 Digital Camera
RCA 32V420T 32" TV
This RCA set uses the CTC187BD chassis. Look on the back of the set and to the right of the cable connector you will see 2 controls sticking out, one on top of the other. The top control is for focus and the bottom one is screen, or overall brightness. If these controls have been turned clockwise then you will have a bright, fuzzy picture with white lines (retrace lines) through it. Tune in a channel with white letters on the screen and turn the top (focus) control until the letters are crisp and sharp. Go into the menu and turn the contrast and brightness all the way down, and then turn the bottom control (screen) until you can just see the picture, just above the point where the picture is too dark to see. Go back into the menu and reset the contrast and brightness and the picture will be back to perfect.
Jun 28, 2007 | RCA 32V420T 32" TV
Photos are too bright, almost white....
camera makers would like to use flash lights as bright as the sun, so the flash is fine. the problem lies in the exposure time. continue trying different exposure settings. most makers provide these as pre-programmed settings while some offer manual fine tuning.
May 25, 2007 | Fuji FinePix S5000 Digital Camera
Pictures look like a bright light has been turned on.
Hello, posted by clowrie When I take a photo (doesnt matter if I am nusing flash or not) the photo is all white washed and there are fine lines along the entire picture. Does any one have any suggestions for what may be the issue? Comment by clowrie, Because of your help I was able to findout that Sony is aware of the CCD problem and is reparing the problem for free. Thanks so much for the help.
Apr 14, 2007 | Sony Cyber-Shot DSC-F717 Digital Camera
Vivitar ViviCam 5100 Digital Camera Logo
114 people viewed this question
Top Vivitar Cameras Experts
Damen Wong
Damen Wong
DMS-UK
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
