Question about Pioneer DEH-1600 CD Player
Don't know which is my memory wire
My harness got cut so i hooked the wires straight to each other. just dont know which wire of wires i connect to keep my memory. every time i kill my car and turn it back on i have to reset my eq settings. How do i know which wires to connect?
    Sergeant:
  • 138 Answers
Yellow is always memory, make sure that it is connected to an always on positive wire
Posted on May 12, 2009
88 vette aftermarket head unit stereo wireing diagram
Might be able to get an adaptor that plugs straight in painlessly.
Failing that it's the standard trace and identify method that eats time like crazy.
Apr 16, 2017 | Cars & Trucks
Wiring JVC car deck
Do you have factory infinity sound. If you do you need a another harness or bypass that infinity system. Also What year is the truck. I know for a dodge ram after 02 is a canbus system. When wiring in the harness leave the blue remote wire alone do not connect from radio harness to the harness that connects to factory harness. Unless you are running to an aftermarket amp. There is a brown wire also that you should not connect leave the remote blue and brown wires alone. this is atleast on a 02 dodge 1500 or newer and 03 or newer 2500+. not sure if this will solve your issue but it fixed my buddies.
Apr 29, 2013 | Dodge Cars & Trucks
Installing stereo in chevy s10 pickup now my gauges aren't workign
Did you disconnect the stereo wires you'd hooked up and see if everything went back to normal? It's easy to connect some custom equipment to the wrong wire. Depending on the stereo you installed, there would probably be 3 wires that are battery positive at any time, and at least one ground wire. There's a wire that's "hot" all the time that provides power to keep the station memory and clock, etc., set. Then the wire that actually powers the radio when you turn it on. The other wire would be hot FROM the radio when oyu turn the radio on, and it's meant for cars that have an electric antenna so the antenna raises automatically when you turn the radio on. If you connect either one of those wires to the wrong wiring harness wire, you can have power to something at an inappropriate time. The best thing to do (without cutting the harness wires) is to use the proper power leads in the factory wiring harness. Otherwise, if you look at your truck fuse-box diagram, you should see that one fuse is marked like "constant battery". I think that will be the fuse towards the front of the truck in the very bottom row of fuses. The wire for your station memory/clock can go to that fuse. The fuse towards the BACK of the truck in that same row is "radio/ignition". THAT fuse only sends power when you turn the ignition switch on or to accessories. Use it for the radio power. If you don't have an electric antenna, don't bother with that wire. To wire straight to a fuse, you need to determine which leg of the fuse power comes in on, then strip about half an inch from the wire and wrap it around the leg of the fuse that goes in the OTHER side. That way your system is protected by the fuses. If/when all that is done, you may have blown a fuse or relay in the big box under the hood on yop of the left fender-well. Let me know if you need help still, but as this problem is 4+ months old, I imagine you fixed it already. bushman_dread@msn.com
Mar 24, 2012 | 1999 Chevrolet S-10 Pickup
I have a 2005 pontiac grand am and cant seem to hook it up. the wire installation kit that advance auto parts sold me Metra autoworks stereo wire harness. the wire harness number is AT-WHGM3. The clarion...
Ok, relax. The purpose of the harness is to wire you radio to it, then be able to plug into the factory harness without cutting wires. Let's start from scratch. The harness you have should have all the wires you need IF you told the retailer all the specifications of your vehicle. Basically the harness should have a positive, negative, switched power, and speakers (4 sets). Speaker wires are generally grey, green, white, and purple. Constant power is red, switched power is yellow, and ground is black. However, you unit may have other wires coming off of it, such as remote turn on (usually blue), RCA outputs, and will have an antenna jack that you may need an adaptor for. Sometimes factory harnesses have two plugs. Sometimes they are not required for the radio to be functional (it may be the output and return for an external amplifier that you are currently bypassing). So follow the instructions on the package. Don't feel like you have to be stuck in your car to hook your radio to the harness either. Hope this helps.
Sep 03, 2011 | Clarion Car Audio & Video
I am trying to wire a 7 pin trailer arness to my dodge ram 2500,the harness has a dark green,yellow,green,green/white,brown, red and 2 black wires. the truck doesn't have the 2 black wires and the red...
Go to napa and they have the connectors that plug in to your existing wire connection, I don't know if they have the one for yours, but it won't hurt to check, you don't have to cut or splice the wireing with there trailer connectors, plug it in and done.
May 21, 2011 | Dodge Ram 2500 Cars & Trucks
Where do you connect the memory wire on a jvc kd g110 car stero.....what color is the memory wire ?? what does hook red wire to acc fuse mean??? what wire does the red wire on the radio connect to on...
The yellow wire is most likely the memory wire as it needs to be connected to a constant 12 volt source.
"Hook red wire to to acc fuse" means you need to hook into the fuse block under an Accessory Fuse. (ie: something that can't be turned on unless the car is running or the key is in the "Accessory" position)
The red wire is explained above. It does not connect to the harness.
Just remember that the yellow wire needs to be hooked to a constant 12 volts and the red needs to be hooked to a circuit that is only active when the car is running or switched to the "ACC" position.
Mar 02, 2011 | JVC KD-G110 CD Player
1985 Yamaha xj700 Maxim-I am confused about my positive and negative cables.I have a red wire coming from my main harness and a cable on the positive side of the battery does the red wire and the red cable...
Hi and welcome to FixYa,
Pls see your other post, but basically:
  • in most, one end of the red wire is connected straight to the battery's + terminal. The other end of the red wire goes to the main fuse;
  • the black of course as you posted goes to the ground;
  • interchanging the 2 wires from the starter relay would make no difference;
  • the starter relay is not directly grounded;
  • the starter relay's + wire goes to the starter button;
  • the starter  relay's - wire goes to starter cut-off activated by safety interlocks (neutral and clutch lever).
Good luck and thank you for asking FixYa.
Jul 08, 2009 | Yamaha XJ 700 S Maxim Motorcycles
97 dakota installed radio harness have power no sound
If you still haven't fixed this, look at your wiring harness. The blue wire that comes off your factory harness is the external amp in the Infinity stereo. I found this out when I hooked my Pioneer head unit up. Coming off the aftermarket stereo should be a blue wire that says remote. Hook those up and you should be good to go.
Jan 18, 2009 | 1997 Dodge Dakota
Wire harness diagram
www.scosche.com will give you the cars wires, u may want to just by a harness adapter, cutting wires=bad
Don
Nov 21, 2007 | JVC KD-S680 CD Player
Pioneer DEH-1600 CD Player Logo
406 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
