Question about HP Photosmart C7280 Printer
Scanner only scans black
Scanner suddenly delivers only black textured images of the full scan area, yet the lamp is illuminated and travels the full image area. Happens with copies and photos, it won't identify small objects, but instead travells the entire surface.
  • Anonymous May 19, 2009
    It all seems normal, but then when its done all that is there is a black rectangle
    Scholar:
  • 169 Answers
Try cleaning the scanner glass(both on the scan bed as well as the scanner glass on the automativ document feeder).then you can align thye printer from the front panel menus...if it stll does not work then You can try a reset on the printer using the # and the number 6,holding them down while plugging in the power cord at the back of the printer.if it still does not work then you can try the same with the # and the number 9.If it still does not work,get your printer serviced.
Posted on Jun 25, 2009
Image scanned is black.
look to see if the scanning lamp come on when you scan a document. if it doesn't, then either the lamp is blown or you need the scanner main board
Feb 19, 2011 | Canon CanoScan 9950F Flatbed Scanner
Everything I scan, the result is black
Hello Lucie,
From your brief description it sounds like the Scanner Lamp is faulty/blown do you see a bright light that travel up the bed of the glass under the lid when closed if open be careful as very bright if it comes on when scanning.
If you do then you may need to reload the driver for the scanner.
Good Luck!
Paul 'W'
Onyer~EDson(:0)~[>< U.K.
Jan 08, 2009 | Umax Astra 3400 Flatbed Scanner
No image is scanned. Completely dark scanned area
Assuming the lamp is on.
Tyry uninstalling and re installing software.
If that fails must assume a CCD or associated component failure.
These items are not repairable usually,
Dec 07, 2007 | HP ScanJet 3670 Flatbed Scanner
Black area above the scanned image.
If you set Automatic brightness/Contrast this happens. Try manual setting. Adjust different settings and select the best suited for a particular type of drawing. The scanner takes couple of milliseconds to judge the best lighting, by then the paper has moved little. This area appears black. This is easily solvable.
S. Mohan, Chennai, India
Dec 06, 2007 | Canon DR-9080C Path-Through Scanner
Black output
This type of issue could be related to different sources. First step I would do is check to see if the lamp is coming on within the scanner, possible bad lamp. One other possibility would be the CCD failure, it may not be moving across to capature your film. Also, when attempting to scan does the scanner sound normal or abnormal. If abnornal sound is occurring then CCD could jammed/stuck hardware failure. Last step would be uninstalling/reinstalling your scanner software, check for updated drivers from the manufacture of your scanner. At this point if none of these suggestions helped then test scanner on a different computer system.
Sep 02, 2007 | Pacific Image PrimeFilm 1800u Film Scanner...
Light stripe on scans
Possible causes, CCD failure, smudges or marks that can only be picked up by the CCD if the underside of the scanner glass is dirty. Uninstalling/reinstalling your scanner driver will eliminate if its software related or not. From the looks of it, could be with the CCD if the lines are in the same area with every scan attempted.
Aug 18, 2007 | Canon CanoScan LiDE 600F Flatbed Scanner
PARTIAL IMAGE
Are you getting the full travel of the scan head, then it delivers only part of image? or Is the scan head only going part way. It seems to be a software maladjustment. Uninstall the software and driver Restart the computer and reinstall the software Then come back
May 25, 2007 | Microtek SCANMAKER 4850 Flatbed Scanner
Scanner scans half black images
IF YOU ARE ATECH OPEN THE TOP COVER UNDER TE DOCUMENT COVER (4 scrowes take out the glass and wip the mirrors the lamp reflectors and fix them back
Apr 27, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP Photosmart C7280 Printer Logo
284 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
