Question about Hoover F7205900 SteamVac V2 Wet/Dry Vacuum
Plastic parts breaking
I've had 4 problems of breakage with my machine.  The first one was the detergent cannister.  I had it repaired at the Hoover store and a new valve was put on.  Shortly after that happend, the housing for the same cannister broke and the cannister will not stay on the machine - therefore I cannot use a cleaning solution to clean my carpets.   Then one of the green levers on the bottom tank broke off in my hand.  Then I found a small clear plastic "pin" on the floor after I finished cleaning.   I use only Hoover products - clean the brushes and the machine everytime I use it - in other words I take good care of it.  I am very dissatisfied with the quality of this machine.  What can you do for me regarding a replacement?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 184 Answers
None ! in most cases Hoover is the best. Whatever you do don't buy Bissel
Posted on Feb 10, 2008
My Hoover max extract Spin scrub FH50220 is leakiing bad what can I do
You'll have to find out where it's leaking! Its not real hard. I will help you!
1. Fill the clean water tank. Check that the valve on this tank doesn't let water through when not on the machine. If it does this the tank is the problem.
2. Take off the 4-6 phillips screws holding the hood on to the machine. They will be on each corner underneath. Be Gentle! Do not break any of the plastic parts.
3. Check where the clean water comes to a L valve. This valve is a very common problem. Place the water tank on the machine. DO NOT hold the handle down. Use paper towel to check for wet spots if you can't see where it is leaking. It should be fairly obvious.
4. If the water is coming from the "back" of the machine or the handle pry the cover off the inside of the handle revealing the hoses. The water release valves may be leaking. Be sure to check all hoses for cracks or breaks. Simply find the water.. and trace it back.
90% of the time it is the L valve which looks like this:
http://www.vacuummedic.com/product.php?id=231
Carefully put the machine back together not forgetting anything and test!
Good Luck!!
Aug 10, 2012 | Hoover SteamVac Carpet/Upholstery Deep...
I have a Hoover V2 Steam Vac widepath and the
This is a notorious problem with the Hoover V2 SteamVac's. In fact the tank design by Hoover on your SteamVac was so bad, that Hoover redesigned this tank almost immediately due to the numerous problems customers were having.
For your particular problem, you really have two options. The first option is putting a bandaid over the problem, but will still fix it. We sell the entire gasket assembly on the bottom of the detergent tank as a replacement part. Unfortunately it's sold together with the seal, spring, and valve together as an assembly;
http://www.govacuum.com/hoover-steamvac-dual-v2-tank-valve-part-43513015.html
You also may wish to fix the problem completely by replacing the entire clean water solution tank. Hoover has redesigned this tank, and the new one I don't see near the amount of problems that I do on the older style tanks. The plastic is much more sturdy, and less prone to having the gasket and valve issues that the old tanks do. It's important to point out that the new tank does not come with the handle. You'll need to remove the handle from your old tank if you buy a new tank assembly complete. Rest assured that if you do purchase any part from GoVacuum, you'll have 60 days to return it for a full refund, just in case the repair doesn't work. Not only do we not deduct restocking fees or shipping charges, but we also include a return label with every order that you may use to return any item to us, and we'll even pay for your return shipping!
Here's the Hoover SteamVac V2 Clean Water Solution Tank, Part 12002549
If you'd like us to do a repair photograph series on this repair of the valve and gasket assembly, please just request a repair clarification here on Fixya, and we'll be happy to do so. If you found this helpful, please be sure to rate the review as helpful by clicking on the 4 Thumbs Up Icons in the top right hand corner of the repair.
Thank you so much,
Chris J.
GoVacuum
Mar 23, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
My Hoover Z 400 collapsible vacuum won't lock in the upright position. I pull the pin to change from a cannister to an upright, but the unit won't lock into position
this just happened to me. i took the vacuum completely apart and found that there is a locking plastic "tooth". this had snapped off but still it the track. the damage was bad but i was able to wash of all the lube off it and used a 2 part epoxy glue to put the tooth back into place. it works ok now. Not like new but it will hold. this was sorta easy but i enjoy fixing things. If your not handy i wouldnt recommend you try it. i am in the process to making an aluminum version of the tooth so it wont break again.
Dec 24, 2009 | Hoover F5858-910 SteamVac Vacuum
Stand up lever is plastic, broke when stepped on to release handle, can it be repaired, replaced with a better one, plastic breaks too easily?
The pedal release can be replaced but the base will need to be checked for cracks as well. if the base is broken most common is the socket the pedal release snaps into. some of the plastic parts have been made with better materials
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Oct 20, 2009 | Hoover Ultra U6430-900 WindTunnel Bagged...
I knocked my savvy over and the cannister came out. misplaced the manual.need instrucytions how to reinstall the cannister.
aline the canister with the machine, handle facing out and push it in. if you go to hoover.com you can download the manuel for this machine. just remember not to put the dash in when entering the model num.
hope this helps
Jul 31, 2009 | Hoover U8181-900 Savvy Upright Vacuum
We have had three belts break on your hoover vaccum cleaner u5472-940. It is easy to replace, you just remove the plastic part over it, put belt on wheel and then put it back on. Any idea on why the belt...
sometimes when you buy belts from the walmart or target, they are not at the correct specification and they brake as soon as you turn on the machine. i would suggest that you buy these belts from the company.
Jul 18, 2009 | Hoover F6021-900 Steam Vacuum
Hoover V2 SteamVac
Under the detergent side, there is a metering plate,(located on the machine) which can be removed. ensure that this is installed. have you verified whether the machine will dispense detergent only without any water in the water tank?
Jan 03, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
HOOVER F7430-900 STEAM VAC
I recommend to use the same detergent that came with the machine. Some detergents can cause problems such as damaging seals and causing build up. Hope this helps, post back.
Jun 23, 2008 | Karcher DE4002 Steam Vacuum
I own a Hoover Steam Vac V2 deep cleaner with Auto Rinse feature. The Model Number is not available ex: was on the bottom of the machine and the sticker is completely worn off the machine. I am having a...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=641300
Generic problem for all Vacuums
Posted by w_brennan on Jun 02, 2008
I own a Hoover Steam Vac V2 deep cleaner with Auto Rinse feature. The Model Number is not available ex: was on the bottom of the machine and the sticker is completely worn off the machine. I am having a problem with the bottle you fill with detergent ex: this bottle is separate from the main clean water tank. THE PROBLEM: The little plastic part that goes in the bottom of the bottle has an "O" ring ex: cone shaped with a spring.....it keeps falling out. Can you supply a part number for this component? The bottle has a number ex:36778-002. Thanks...Linda (504) 888-2120.
E-mail address: w_brennan@bellsouth.net
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hover SteamVac V2 with Auto Rinse feature. I would suggest because the model 3 and the serial 3 have been worn of the machine to contact your local vac dealer in your area and or the Hoover Factory Service or the Hoover Website for the Factory Model #, but the part that you are requesting is not very expensive and can be replaced. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 02, 2008 | Vacuums
Hoover F7205900 SteamVac V2 Wet/Dry Vacuum Logo
79 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
