Question about Acer Aspire 6920 Notebook PC
Acer 6920 LCD Screen damaged
My ACER 6920 LCD screen looks damaged. Looks like there is a crack from the top and now the screen looks white and with some black lines. Can it be repaired/replaced?
What will be the expense if required to replace?
    Sniper:
  • 125 Answers
The screen is impossible to repair if its cracked. Getting a new LCD isn't that expensive but only if you know how to replace it. Getting one from manufacturer is around 130. but there is an ebay link on the bottom you can get one for 70 or so with shipping.
This link shows you how to replace a LCD screen. even tho its not your model but is very close to how yours look.
http://www.insidemylaptop.com/remove-lcd-screen-inverter-board-acer-aspire-3620-laptop/
This is the link to a new LCD screen for your laptop.
http://cgi.ebay.com/NEW-ACER-ASPIRE-6920-LAPTOP-LCD-SCREEN-16-WXGA-GLOSSY_W0QQitemZ350199312405QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item5189817015&_trksid=p3286.c0.m14&_trkparms=66%3A2%7C65%3A15%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
Posted on May 12, 2009
    Problem Solver:
  • 5 Answers
Ive just replaced one of these screens, bit hit n miss along the way plus the discovering of numerous small screws. a word of warning though, be very careful of the small wires linking to the power jack, a black one came out on mine and im not really sure if ive got it back on right (not charging all the time)
Posted on Oct 11, 2009
Listen mate I just solve it on my own but it took me a little time to do that. Reparing in any service will cost you 200£ or more (include price of screen). The best shop I found is laptop-lcd-screen.co.uk - delivery next day. Cost 95£. Remember that there are 2 types of screen may be installed in acer 6920 so you have to check it very carefully. Check your model on the bottom of your laptop, then go on acer official page and check what type of screen you`ve got - then you can order. Next I`ve found a page with instruction how to open that type of computer (www.eservicemanual.info) and downloaded it (cost 2.20£). Problem with that type of laptop is that`s not easy to replace the screen. In most laptops you can change it by opening front (bezel) of the screen and it`s quite easy. In acer 6920 you`ve got to open it from the botton then loose some cables, remove screws which keep your front speaker board, remove both ends of tube and completely remove all screen from your laptop. Then you`ll have an access to 3 screws which are on the bottom of your screen so you can remove your screen bezel. Believe me it`s not easy so if you are not feel confident with things like that do not try on your own. Good luck anyway. If anybody have a same problem and would like to ask me about anything - pete.no.1@interia.pl
Posted on Oct 08, 2009
    Problem Solver:
  • 8 Answers
Yes, the crack in the corner is probably a replacement, range from £100 on the diy buy a screen and fit yourself, to £600+ to a professional (rip off) replacemen ie send it off then get it back, prices probably a bit off though, been 4 years since i did mine, also depends on the size/quality of the replacement screen
if the lines are perfectly horizontal/vertical theres another problem, try an external monitor, if that works fine there may be an inverter problem,
How do you fix a acer laptop cracked screen
The LCD screen needs to be replced.
You maybe able to get a replacement screen from this WEB site.
LCD screens and Inverters www.lcdparts.net
Jan 20, 2013 | Acer Computers & Internet
ACER ASPIRE 3680 LOOKS LIKE INK IS BLEEDING INK INSIDE OF IT..
It indeed is a fairly easy repair in case of your Acer. However you will need a replacement screen which would cost a lot if you order it new. You might be better off searching ebay for a broken "donor" laptop (make sure it's exactly the same model, as even similar models with same screen dimensions might have different connectors or inverters - I learned the hard way ;)
Good luck,
Raf
Nov 08, 2009 | Acer Aspire 3680 Laptop
Hi there....i accidentally stepped on my laptop and the screen looks liks its cracked....the actual screen isnt cracked it just looks like it...kinda looks like you can see the inside of it...HELP!!!!
Yup, its cracked. The actual LCD (liquid cristal display) is inside the protective plastic casing and that is supposed to help keep it from being damaged. It has to be replaced..
Oct 27, 2009 | Acer Aspire 5500 5570-2609 Laptop
Anyone replace the inverter on an Acer Aspire 6920?
I haven't replaced an inverter on this model before, but have done on a few other makes.
Generally the inverter is located on the bottom edge of the LCD screen behind the bezel.
The bezel is secured with screws on the front and or the edges of the bezel. these screws in most cases are hidden by small round plastic covers, they need to be carefully peeled off to reveal the screws. Also the bezel is held in place with plastic clips and double sided tape. Slip a thin metal strip between the screen and the bezel and carefully pop the bezel off, start at the bottom edge and work along each edge to release the bezel. Be careful not to scratch the LCD screen and be careful not to apply pressure to the face of the LCD screen otherwise you will crack the LCD screen.
Aug 12, 2009 | Acer Aspire 5720-6661 Notebook PC
Acer 6920g had a cracked screen...ordered a new one..doesn't work
racist maybe? hah. just kidding. but you should check to see that the connecting part of the screen (where the screen connects to the "computer") and see if there was anything loose (due to shipping) or if there are any anomolies in the chinese screens as compared to the original korean one.
(also, i was wondering if you could PLEASE tell me how to remove the screen, i know there is the keyboard bezel, but how do i remove it?)
Jun 10, 2009 | Acer Aspire 6920 Notebook PC
My laptop, an Acer Aspire 5715z, has a big ol' white patch on it with a smaller one at the top of the white one. It covers about half of the screen, and it has blue around the start of the white line.
Oh okay. Your screen is physically cracked. Its broken, its going to need to be replaced. Thats why a part of the screen is coming and then you see splotches on the screen. Looks like somebody hit directly with something or stepped on it. If you turn the laptop off and shine a light on it, you might be able to see where the crack originated.
In the meantime until you get another lcd screen, you can hook up an external monitor to the laptop and use it like that for now.
May 23, 2009 | Acer Aspire 3610 Notebook
Acer Aspire 6920 Notebook PC Logo
1,219 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
