Question about Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso washer (model #gvw9959kl2) selector buttons
I just had the repairman out to unplug the pump and now all of the control buttons seem to be locked.  Everything is lit up across the middle setting and 42 minutes shows in the display window but nothing i push will change the settings and the start button does nothing.  When i unplug the unit and plug it back in everything is dark until i hit any button.  Then everything lights up across the middle again and the 42 is in the window.  Does this machine have a reset of some kind?  It looks like i tilted my pinball machine.
  • 240 Answers
Afraid to say that there is no reset on these washers, and the problem is probably the touch pad board in the console has gone bad.  Usually not a cheap repair.  The part is usually between $200.00 and $350.00 depending on what part of the country you live in.  Hope this helps you, but that sure seems to be the problem.  Let me know if you need further information.  Good Luck!!!!!!    Jim
Posted on Oct 24, 2007
Whirlpool calypso top load washer stuck on FL
Fl means flood
you either have a bad flood switch or something is in the pump.
the pump is located under the washer
if you where to tip back and remove the 3 5/16 inch screws and look to the very right you will see the pump.
it could be these 2 things and or it could be something in your sump balls. which you would need special tools to gain access to.
let me know if this helps
May 12, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I have a calypso washer it seems to be stuck on the ultra hand wash. the only button that does anythinbg is stop. i have unplugged it time and again, but nothing changes
keep it unplugged for at least a half hour -- if nothing solves it you probably need a new board. Ours is going the sidewalk on junk day because of this. Have had it 7 years and more than a dozen service calls on it. Have had the board replaced 2x and the pump 4x -- other calls were techs trying to figure it all out. Garbage machine.
Oct 24, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My Calypso washing machine doesn't allow you to select start. It is an intermittent problem which seems to clear itself after a couple of hours. How do I fix it?
Hi , I,m online now trying to fix my calypso dryer problem , ijust got done fixing my washer 10 minutes ago (clogged pump) . In the past I have unplugged the units when they acted up (re-boot) and worked up til this sunday . Good luck !!
Aug 17, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso Leaking
try replacing the drain hose where it connects to the pump? perhaps the pump itself had something caught up in it, i own one of these machines as of a few days ago and i aquired it with it not draining, after i cleaned up the pump and put it back, all is good... check your pump assembly if possible or run it thru with the front panel off to see where the leak is coming from.. directions are avaliable under the owner center on just enter your model # in and look for a parts diagram of the cabinet...
good luck..
Apr 29, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso model GVW9959K-0 leaking during rinse cycle
hi my name is joyce
Sounds like your pump is leaking. if it is leaking when you are on a spin cycle.
now if it is stuck on f1 cycle and wont drain unplug and let stay unpluged for 60 seconds and replug and see if you can restart on drain and spin cycle. let me know if I can help with any other problems.
Feb 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Beeping and Frozen, 44 min
If it is a Calypso, abandon it immediately... it is amazing you still have it. One of the worst designs, ever. Whirlpool Washing Machine Drain Pump 285990 No Longer Available
Apr 23, 2017 | Whirlpool Calypso GVW9959K Top Load Washer
Washer shows no signs of power
Yup, this is what happened to me. I also get a "44" error code and erroneous beeping. This is exactly what the class action law suit was about. The Whirlpool Calypso's of your type have the red LED and touch controls, right? They go bad internally after a few years, regardless of how much or how little you use them. There is nothing you can do. Order a new or reconditioned control panel, or have it serviced and repaired by a qualified company referred by Whirlpool Service... Don't do this yourself... The part is about $200 or so plus $60 to $80 minimum call out charge, and sometimes the new parts are as bad as the one you currently have. Best Bet... Time to upgrade to something newer. You may spend your money on this repair, yet in a few months, have the same thing again or something else go wrong. It's just not worth the repair.... Indy :)
Sep 14, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Callypso Model #gvw9959kl2 Serial #cm3202070
I had the same problem, it turned out to be the "U-Joint", which was a fairly easy repair. The part comes as a kit, (It is probably very common), the cost I got from Sears was $112. With tax and a $44 overnight delivery charge, my total was $170. And while I had it apart, I also cleaned all the gunk out.
May 19, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washer stops in middle of cycle,
Junk it! Cut you losses now. I had a Calypso for 6 years and went through 3 pumps, various circuit boards , a drive motor ,etc..... not to mention the down time of not having a washer in a 4 person household. We bought a Whirlpool Duet HT 9200. Clean , fresh laundry not all balled up anymore. Junk it. You'll thank me.
Nov 01, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
515 people viewed this question
Dan Webster
Dan Webster
Sal De
