Question about Maytag MDB5100A Dishwasher
Water keeps coming into the d/w from the valve even when the machine is not on why is that
    Sergeant:
  • 138 Answers
It sounds like the water valve solenoid is bad or it is getting power when it shouldn't
Posted on May 12, 2009
My intelowasher keeps water running? WD-80613 front loader runs for 5 mins then error code FE? comes up and water keeps running thru it even when i unlug the power from the wall? i have to turn tap off any...
yes the intake valve has failed
or the machine is fitted with a low pressure valve and your using high pressure water supply
i recon the valve spring or something has failed
youll need to replace the cold water intake valve {ebay or local shop}
then clear the error by resetting the machine
mains off press button on the front main on wait 5 secs
usually they beeeep one long beep and your done
Dec 04, 2014 | Washing Machines
My washer is filling with water non-stop, even when its not on. I have to turn the water off to the machine to keep it from filling with water. Is there a valve stuck open? Or is it circuit board going...
The water LEVEL SENSOR has failed and so there is no detection of the level selected on the washer. Hence the inlet valve is not cut off even after the water level has reached,
You need to check this unit and replace.
Secondly as mentioned even after the power is put off if the water comes into the washer then it is possible that the INLET valve has failed or is stuck OPEN .
Remove clean and reset or replace.
Jun 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine keeps filling with water even when washing machine off. can hear the water coming through the drawer at top and fills into drum. had to out cold water valve off
You will need to replace the inlet valve inside the washing machine. It is stuck in the open position. It's a fairly easy to replace. you will just have to unscrew the top[ in the back and lift the lid to access.
May 28, 2011 | LG Washing Machines
Why the cold water keep coming even when the washing machine is of
the cold water is coming in the machine when the water is off is that what you said? shut off the faucets that go to the machine bad water valve its the piece that the hoses connect to please write back to clarify on when the cold water shuts off thanks again
Rick
Dec 03, 2010 | LG WM2277H Stainless Steel Front Load...
Keeps running even when shut off and states "overfilling".
sounds like the water solinoid valve is stuck in the open position. look at the hole where the water comes in machine. alot of times it will be a slow dribble of water which overtime overfills the machine. just replace water valve if thats the case
Aug 01, 2010 | Asko Dishwashers
Keeps filling up with water even on spin
Close the water supply valve and allow the machine to completely drain the water from the tub. Turn off the machine and disconnect it from the power outlet. Open the water supply valve. Replace the water inlet valve if water drips into the tub when the machine is off.
Start a new cycle if the machine stops filling when it is off. The control board or the water level switch is malfunctioning if it keeps filling even during the spin cycle. Indicate the model number for proper troubleshooting and repair assistance.
Feb 05, 2010 | Washing Machines
The water keeps coming in the machine and the ringer won't spin to get it out
from your explanation it would sound like a faulty daiphram switch it is this device that informs the electronic inlet valve to turn of and advance onto the next step of the programm if the water keeps comming into machine even when operating then it would be a faulty inlet valve, isolate water supply to avoid flooding
Jan 17, 2010 | Roper RAS8445KQ Top Load Washer
Tub overflowed during wash cycle
there is valve in the back of the machine where the 2 pip going to the machine if it get power even when the spin cycle is on then the controll panel is bad if it is not getting power but the water keep comming in the valve is bad also check that the pressure switch is working fine and the tube to it is clean from suds.
hop it help you any more help you need go to 911servicetoday.com :)
Dec 31, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Water keeps running into my washing machine. Even
Water valve is stuck open, probably by lime or calcium build-up. Proper fix is to replace the water valve. How old is the washer?
Jun 11, 2009 | Washing Machines
Maytag MDB5100A Dishwasher Logo
60 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
