Question about Samsung SyncMaster 152 B 15" LCD Monitor
Whole display is of reddish colour -Samsung 945NX LCD
Im using Samsung 945NX LCD PC Monitor. I rebooted my pc when it came up the whole screen was of reddish. I plugged out VGA Cable cleaned and plugged in but it didnt help me. Also tried reset option in the monitor which also failed. Pls help
  • riyazibm May 12, 2009
    I m using NVIDIA Graphics card... U mean to update its driver...
    Riyaz
  • 50 Answers
Try to update the lastest version of your video card driver
Posted on May 12, 2009
There are only red,blue and green colours displayed on my LG tv
This can be the panel check required during manufacturing sessions.
Your only choice is to call the experts in to perform a selfcheck so that the whole system can be rebooted.
A self check is like when you reformat and reinstall your windows into your PC. Everything is back at default condition. Only technicians know the coordination between the remote control and the key button.
Above solution is if you are very lucky, if not can be a loose wire dressing inside the TV itself.
Unlucky is the data board has to be replaced. Usually nowadays technicians replace the whole board so that no time is wasted to find the exact problem. So it should be OK for you.
Oct 31, 2012 | LG Flatron L1951S 19" LCD Flat Panel...
LCD MONITOR DISPLAY PROBLEM
What your describing is a major video problem, poor color and it is blurr, It would be far cheaper to replace the monitor with a new one.
Mar 08, 2012 | Samsung SyncMaster Computers & Internet
I use my lg L194ws moniter screen only with tv-tuner set,and now a days,i found a problem with hthe sreen.there is a blue coloured vertical line came in middle of screen.plz tell me what to do to avoid...
Sad to say, there's nothing you can do. Solid lines like you describe are due to hardware failure in the LCD display panel itself. Instead of controlling a single pixel as designed, a whole column is now stuck on. There is no way to get into the LCD panel to repair that circuitry; the only option is to replace the panel. Replacing the whole monitor is usually simpler (and often less expensive) than locating and installing the panel alone. Until you're ready to buy a new monitor, just keep using this one.
Jun 21, 2011 | Computers & Internet
White screen
The white screen you are getting is it just right after turning on the computer? If yes it means that you were not able to see the Dell logo correct?
Try connecting an external monitor thru VGA. While monitor and laptop is on with white screen please do this. Hold down Fn key then press F8 at the same time. This will toggle the display from the laptop to external monitor. If laptop displays to external monitor means that laptop LCD needs to be replaced.
If you do not have an external monitor try this.
While laptop is OFF. Do this. Hold down the D key then press power button at the same time.
Check if the laptop will display colors the whole screen. If you still see white screen then LCD needs replacement.
LCD mean LCD panel or the whole screen together with LCD cable and Inverter.
Hope this helps.
Mar 25, 2011 | Dell Inspiron 1525 Notebook
Coloured squares appear on screen
Seems to me that the LCD cables are not properly atached.
Double check all the LCD connections.
Your problem will be solved.
Jul 05, 2010 | Sony VAIO VGN-NR220E/S Notebook PC
My whole screen has a blueish green tint
  • Make sure the plugs are hard into the sockets, one loose pin can cause strange colour problems.
  • A faulty signal cable between PC and monitor can also cause colour problems, try a different cable if possible
  • Try it on a different computer to find out whether the computer or the monitor is the problem. If it's the monitor and none of the above works, it will need service or replacement. If it's the computer, your video card is likely to be the problem.
Apr 09, 2010 | Samsung Syncmaster 940BW LCD Monitor
Acer al1717
Please try loading monitor specific drivers.Many of the time the monitor is recognised as "Plug and Play Monitor".
Samir
Mar 09, 2008 | Acer AL1717 17" LCD Monitor
External monitor
Try going into cmos and enabling multi display (external)
Also u can boot into safe mode and restore windows to a previous day
Next u can save your file on a flash drive then reinstall windows
Hopw this helps ... u also have an s video port
thanks
jaywizz
Nov 18, 2007 | Acer Aspire 5500 5570-2609 Laptop
Color Problem:
in Monitor CRT Red-Blue-green cathode guns are there.. Mixing of these colour we can get the original colour chrominace technique. if any of the colour gun is faulty we would get more REad or blue or green picture. Measure RGB voltages. you can verfify which gun is faulty. if then check RGB processing circuits. Else there might be problem Chrominance colour decoder system. Contact service centre
Jan 09, 2007 | Samsung SyncMaster 551 15" CRT Monitor
Samsung SyncMaster 152 B 15" LCD Monitor Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
