Question about Soyo DYLT032D 32 in. LCD Television
What screw do I remove from the back on my soyo 32" to mount ??
Need to know which screw should be remove from thr back to mount soyo 32" lcd on the wall...
    Problem Solver:
  • 16 Answers
The screws are already removed the should be plugs little ccircles on the back to remove for a wall mount if not check the tv manual
Posted on May 12, 2009
SOURCE:
How do I remove back off Soyo 32 inch tv?
If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Disassemble procedure to many popular brand TVs are given with illustrations.
Aug 04, 2014 | Soyo DYLT032D 32 in. LCD Television
How to remove base so it can be wall mounted
Put LCD TV on a pillow, with screen resting on the pillow. Now the base will be free in air. Then remove screws at the back of TV, where base is joining. You might need a screw driver with magnetic head to remove screws. After removing screws, slide the base clamp out from the back of TV, and you are done.
Nov 01, 2010 | LG 32LG30 32 in. LCD HDTV
Soyo 32" lcd tv
The only part I could find was at shopjimmy.com, part being a Polaroid PCB for $69 plus tax, ship & handle.
Feb 24, 2010 | Soyo SYTPT3227AB 32 in. LCD TV
I have a SOYO-DYLT032B...32in LCD and I need a main module...not hopeful based on research...any clues?
what is the code for soyo tv 32" lcd to activate my digital remote to use it for all functions instead of using two remotes one to turn off and on and the other to navigate.
Nov 07, 2009 | Soyo DYLT032D 32 in. LCD Television
I need a remote for a soyo 32 inch tv or a code that works with a universal remote
The RCA RCR312wv sold at Wal-Mart for about 7 bucks has 2 SOYO codes and the second one worked on my 32" SOYO
Oct 27, 2009 | Soyo DYLT032D 32 in. LCD Television
I need to remove tv stand from my Soyo DYLT032D to mount on wall, Also what screws do you remove in back of TV? Thanks...
Remove Back plate screws and match up the holes on the wall mount device with the holes on the back of your television. Attach the television to mounting devise, Then mount both to the wall. Hope this helps you with your problem.
May 09, 2009 | Soyo DYLT032D 32 in. LCD Television
Cannot remove the stand on the 26 inch LCD tv (soyo)
Hello you remove the last four screws on the back of the tv located down at the bottom theres two on each side the stand will slide out...
Jan 04, 2009 | Soyo DYLT032D 32 in. LCD Television
Removing stand to mount on wall
Just called the company and was told that you simply remove the 4 screws on the back of the stand that is holding it to the tv....They do NOT recommend mounting the TV because it will make your warranty ineffective-per the rep.
Jul 23, 2008 | Sylvania LC320SS8 32 in. LCD Television
Akai 32"
I just purchased this unit and briefly looked at removing the stand though I haven't taken it off yet. Anyways, I think you need to remove the black metal mounting frame from the TV before trying to unscrew the stand (4 screws) from the metal frame. After the frame is off the TV, I think you can then get at a couple of hidden screws to remove the stand from frame. I don't know if the frame goes back on the TV or not.
Dec 01, 2007 | Akai LCT3201AD 32 in. LCD Television
Soyo DYLT032D 32 in. LCD Television Logo
293 people viewed this question
Top Soyo Televison & Video Experts
Marvin
Marvin
Jaime Hernandez
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
