Question about Microsoft Windows XP Professional SP2
Registry Edit When i type REGEDIT.EXE in Run it apperars Error Message " This service is disabled by your administrator " how can i enable this service ?
  • Anonymous May 15, 2009
    sound driver
  • John Snow
    John Snow May 11, 2010
    You can try booting up in safe mode, log on as admin and change your user settings.
  • 41 Answers
Make sure you are logged in as the administrator before using regedit. Otherwise you will continue to get the same error message..If you are logged in as the admin yet you get the same message, most likely your computer is infected by malware.. Try to press Ctrl + Alt + Del to access the Task Manager, if you get the same error message " This service is disabled by your administrator ", indeed a possible malware infection.
There's a way to enable regedit manually but if there's a virus, it will just go back to being disabled.. So let's make sure that virus is removed first.
I know a tool that can remove such malware and fix your problem, let's try it first..
you may download the software from this link,
http://leerz25.sitesled.com/files/tools/fixes/NOOB_KILLER.by.Leerz.zip
software is called noob killer.. just save it and extract then click on the Bart Simpson icon.. Once the program opens, click on ""8-X Kill All & Restart"" ..
It will kill the malware that's causing the problem.. After restart, you should be able to use regedit..
let me know if it works..
Posted on May 12, 2009
I think my laptop has a virus because when i attempt to open run and type "regedit" a window will appear it say "registry editing is disable by your administrator" i am the administrator but i did not do...
to make sure you´re virus free try another antivirus.
Go to:
http://www.eset.com/onlinescan/
and run the online scanner ( works with Internet Explorer only, I think ). It is pretty accurate and might find something that Avast missed.
Oct 21, 2009 | Computers & Internet
My system restore has been turned off by a group policy "whatever that means"
Resolution 1. Click Start, Run and type regedit.exe and press Enter
2. Navigate to the following key:
HKEY_LOCAL_MACHINE \ Software \ Policies \ Microsoft \ Windows NT \ SystemRestore
In the right-pane:
  • Delete the value DisableConfig
  • Delete the value DisableSR
3. Exit the Registry Editor.
In Windows XP Professional, you can accomplish the above using Group Policy Editor as well.
1. Click Start, Run and type GPEDIT.MSC
2. Navigate to this path:
-> Computer Configuration
--> Administrative Templates
---> System
----> System Restore
3. Set Turn off System Restore to Not Configured
4. Set Turn off Configuration to Not Configured
For standalone Windows Vista systems, use these steps:
Using the Group Policy Editor
If your edition of Windows Vista includes the Group Policy Editor snap-in (gpedit.msc), follow these steps:
1. Click Start, type gpedit.msc and press ENTER
2. Go to the following branch:
Computer Configuration | Administrative Templates | System | System Restore 3. Double-click Turn off Configuration and set it to Not configured.
Note: If the above setting is already set to Not configured, set it to Enabled and click Apply. Then revert back the setting to Not configured, and click Apply, OK.
4. Exit the Group Policy Editor.
Using the Registry Editor
1. Click Start, type regedit.exe and press ENTER
HKEY_LOCAL_MACHINE \ Software \ Policies \ Microsoft \ Windows NT \ SystemRestore 3. In the right-pane, delete the value named DisableConfig
4. Exit the Registry Editor.
If you set the Turn of configuration option to Enabled, the option to configure System Restore on the Configuration Interface disappears. If the Turn off Configuration setting is disabled, the configuration interface is still visible, but all System Restore configuration defaults are enforced, and the Create button is grayed out. If you set it to Not configured, the configuration interface for System Restore remains, and the user has the ability to configure System Restore.
regards
iversh
if you felt i ve spent my time for answering your query.... kindly rate the service very helpful
Aug 30, 2009 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
Powerpoint 2007 Hyperlink problem
Disable hyperlink warnings for 2007 Office programs loadTOCNode(2, 'moreinformation'); To disable the hyperlink warnings in 2007 Office Programs when an http:// address, notes:// or an ftp:// address is used, you must create a new registry subkey. To do this, follow these steps:
  1. Click Start, and then click Run.
  2. In the Open dialog box, type regedit, and then click OK.
  3. In Registry Editor, locate one of the following registry subkeys:
    • HKEY_CURRENT_USER\Software\Microsoft\Office\12.0\Common
    • HKEY_CURRENT_USER\Software\Policies\Microsoft\Office\12.0\Common
    NoteYou only have to modify one of these registry subkeys. You do not have to modify both of them.
    Note If the Security subkey already exists, skip to Step 6 after selecting the Security subkey.
  4. Click the registry subkey, point to New on the Edit menu, and then click Key.
  5. Type Security, and then press ENTER to name the key.
  6. On the Edit menu, point to New, and then click DWORD Value.
  7. Type DisableHyperlinkWarning, and then press ENTER to name the entry.
  8. In the right pane, right-click DisableHyperlinkWarning, and then click Modify.
  9. In the Edit DWORD Value dialog box, click Decimal, and then type 1 under Value data.
    Note A value of 0 enables the hyperlink warning message. A value of 1 disables the hyperlink warning message.
  10. Click OK.
  11. Exit Registry Editor.
uparrow.gifBack to the top If you still receive a warning message loadTOCNode(2, 'moreinformation'); You may still receive a warning message from Microsoft Windows. If you continue to receive a warning message after you follow the steps in this article, use one of the following methods to resolve the issue. Method 1: Turn off the "Confirm open after download" option for the file type that you are trying to open loadTOCNode(3, 'moreinformation');
  1. Double-click My Computer.
  2. On the Tools menu, click Folder Options.
  3. On the File Types tab, select the appropriate file name extension (for example, WMV) in the Registered File Types box, and then click Advanced.
  4. Click to clear the Confirm open after download check box, and then click OK.
  5. In the Folder Options dialog box, click Close.
Method 2: Modify the HKEY_CLASSES_ROOT\WMVFile\EditFlags registry subkey loadTOCNode(3, 'moreinformation'); Use this method if the warning message affects multiple computers.
To disable the warning message, follow these steps:
  1. Click Start, click Run, type regedit, and then click OK.
  2. Locate the following registry subkey: HKEY_CLASSES_ROOT\WMVFile\EditFlags
  3. Click EditFlags, and then click Rename on the Edit menu.
  4. Type OldEditFlags, and then press ENTER.
  5. On the Edit menu, point to New, and then click DWORD value.
  6. Type EditFlags, and then press ENTER.
  7. On the Edit menu, click Modify.
  8. In the Edit DWORD Value dialog box, click Hexadecimal under Base.
  9. Type 10000, and then click OK.
To re-enable the warning message, follow these steps:
  3. Click EditFlags, and then click Modify on the Edit menu.
  4. Type 0, and then click OK.
Jun 18, 2009 | Microsoft Office PowerPoint Home and...
Cannot restart services error 1068
To resolve the problem, fix the dependency information for the Spooler service.
Click Start, Run and type the following:
CMD /K SC CONFIG SPOOLER DEPEND= RPCSS
Alternately, to accomplish this using Registry Editor: Click Start, Run and type Regedit.exe
Navigate to the following branch
HKEY_LOCAL_MACHINE \ SYSTEM \ CurrentControlSet \ Services \ Spooler
In the right-pane, double-click the DependOnService value
Delete the existing data, and then type RPCSS
Close Regedit.exe
And workstation is only needed if you are on a network.
May 11, 2009 | HP Compaq Evo n400c Notebook
Compaq evo n400 "I cannot get on the internet" for starters
It's not the workstation settings,It's the RPC service settings.
Close Regedit.exe
Can't edit registry on Vista 64 bit
Hi there. With Vista, even though you may have an administrator account, some actions require you to go through an "extra channel", so to speak. This is to add extra security to your system from outside interference.
What you should try:
Click on your Start Menu.
At the bottom, under All Programs, type regedit. Do NOT hit enter.
At the top, it should display the regedit program.
Right-click the regedit program and then select Run as Administrator.
It should now let you edit.
Let me know how it goes
Tim
Apr 16, 2009 | Microsoft Windows Vista Ultimate Edition
How to enable registry editing
Method 1 - Using Group Policy Editor If you are using an edition of Windows Vista (Windows Vista Business, Enterprise and Ultimate editions) which includes the Group Policy Editor, follow these steps:
  • Click Start, type gpedit.msc in the Search box, and press ENTER
  • Go to the following branch:
User Configuration | Administrative Templates | System
  • Double-click Prevent access to registry editing tools
  • Set it as Not Configured
Important: If it's already set to Not Configured, set it to Enabled and click Apply. Then repeat the steps and revert the setting back to Not Configured. This removes the registry based policy if set already.
Method 2 This method should work in all editions of Windows Vista.
  • Download reg_enable.vbs attached at the end of this article, and save it to Desktop
  • Open an elevated command prompt. To do this, click Start, click All Programs, click Accessories, right-click Command Prompt, and then click Run as administrator. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  • Switch to your Desktop directory by typing the following command, and then pressing ENTER:
cd /d %userprofile%\desktop
  • Then, type the following command and press ENTER
wscript.exe reg_enable.vbs
  • Type EXIT to close the Command Prompt window.
If everything worked fine, the DisableRegistryTools policy should have been removed by now. See if you're able to launch Regedit.exe now.
Dec 11, 2008 | Microsoft Windows XP Professional
Problem when windows XP is starting up. Isass.exe - System Error
To work around this issue, restart your computer in Safe Mode. To restart your computer in Safe Mode, press F8 when the computer starts. Then, when the computer is in Safe Mode, add the System Pages entry to the following registry subkey: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Session Manager\Memory ManagementTo add this registry entry, follow these steps: 1. Log on by using an account that has administrative credentials. 2. Click Start, click Run, type regedit, and then click OK. 3. In Registry Editor, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management 4. On the Edit menu, point to New, and then click DWORD value. 5. Type SystemPages, and then press ENTER. 6. On the Edit menu, click Modify. 7. Click Decimal, type 31000, and then click OK. 8. Quit Registry Editor.
Jun 17, 2008 | Dell OptiPlex GX280 PC Desktop
Hide task manager
hi dear
start menu, run
type regedit
find this....
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System]
"DisableTaskMgr"=dword:00000000
change dword to 000000000
oke
Mar 19, 2008 | Microsoft Windows XP Professional
About registry
You can not. Unless you create a Guest or a non-administrator account, Users from that account wont have access to regedit.
But you can disable it on an Administrator account and others.
Lets say you want to disable regedit on the Administrator's account, login to Administrators account and do as follows:
Start/Run/Regedit
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System
Value Name: DisableRegistryTools
Data Type: REG_DWORD (DWORD Value)
Value Data: (0 = allow regedit, 1 = disable regedit)
Do the same for Guest/Any other accounts.
Nov 03, 2007 | Intel (P42000400512SK478) Pentium 4, 2 GHz...
Microsoft Windows XP Professional SP2 Logo
182 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
