I need to peek up the out going power of my cobra 150 gtl/dx but i dont know how can you please help me?
4 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: what size fuse do i
30 should be enough to run it at optimal level.
Posted on Jan 28, 2009
  • 478 Answers
SOURCE: need a new Cobra 150 GTL DX power,vol,sqlch pot
you can write to parts department requesting price if you have a truck stop around you which has a cb shop they can sell u one
Posted on Jun 26, 2009
  • 773 Answers
SOURCE: i have a cobra 150
If this radio has been peaked and tuned already, and it is not in need of a full alignment, then it's most likely the antenna.
Your antenna is everything. You need a good antenna, and it needs to be tuned to the lowest SWR.
It is important to tune your CB radio antenna to the proper length. The length must exactly match the wavelength of the frequency you transmit on. Or be really really close.
All Cb antenna's have a way to adjust the length of the antenna. If it's a mag mount, the metal whip can be slid in and out of a metal collar. Usually a set screw. If its a fiberglass whip, the way to tune it is on top. It either has a small metal rod with a set screw to adjust the length, or it threads in and out to adjust length.
Either type you have it will need to be adjusted for proper length. Here is how to tune the antenna to lowest SWR.
Some radios have a built in SWR meter. Some do not. If yours doesn't have an SWR meter, then you have to use an external SWR meter. Radio shack carries one, and you can find them cheap on ebay.
If you have a built in SWR meter or external, the procedure is the same:
1. Turn the radio to CH 20.(This is the center of the band.)
2. Switch the meter switch to CAL. (CAL stand for calibrate.
3. Key the radio. (Important. Do not talk while keying the radio.)
4. turn the CAL knob up until the meter hits the CAL mark.
5. Now while still keying the radio flip the meter switch to SWR.
Where the meter falls after that point is you SWR reading. If its above 3, that is real bad. 2 is not gonna kill your radio but its not the greatest. 1.5 and under is a good place to be, but the lower the better.
If your SWR is high, Here is how to find out if your antenna is too long or too short.
1. Turn to CH 1
2. Repeat SWR procedure. You must calibrate every time you do it.
3. Remember the SWR reading.
4. Turn to CH 40.
5. Again repeat SWR procedure.
6. Compare the reading between CH 1 and CH 40.
Now if the SWR is higher on channel 1 then channel 40 your antenna is too short. You must make it longer.
If the SWR is longer on channel 40 then on channel 1, then the antenna is too long, you need to make it shorter.
Make height adjustments about an eight inch at a time, and take reading each time.
once the SWR is significantly lower and the reading on channel 1 and 40 are about the same, you a about matched. At this point turn the radio to the center of the band, channel 20 and take an SWR reading.
You should now have a low SWR reading, 1.5 or under. If you are 1.5 or under, you are good to go.
If you cannot get the SWR to an appropriate level, there may be an antenna problem.
Posted on Oct 21, 2010
Cobra 150 gtl dx peak and tune
first off if you don't have the proper equipment to do this you will have a cobra 150gtl dx used in the box that you can use for a chock block. turn the wrong can and you will never be able to get it back to working order.
Jan 16, 2012 | Cobra 150 GTL DX Base CB Radio
Need a new Cobra 150 GTL DX power,vol,sqlch pot
Jun 26, 2009 | Cobra 150 GTL DX Base CB Radio
Getting regular cb chanels
go to cbtrick.com to radio information go to corba radios and you will find the mod for 11 meters.
Jan 01, 2009 | Cobra 150 GTL DX Base CB Radio
Cobra 150 gtl?
RV12 is the modulation adjust for the 150. Check with cbtricks.com for physical location.
May 20, 2008 | Cobra 150 GTL DX Base CB Radio
Talkback on a cobra 200 gtl dx
This procedure is not as simple as just cutting a wire. Note that you can possibly mess your radio up if any maintenace is not done properly. I do suggest taking your radio to a proffesional to have the talkback removed, but, if you really want to do it yourself, go to ghe following link and basically reverse what has been done.
http://www.cbtricks.com/radios/cobra/150gtl_dx/tsb/cobra_200gtl_dx_tsb_10041.pdf
This is the service bulletin for the addition of talkback to the Cobra 150GTL DX and the Cobra 200GTL DX.
As long as the talkback was added correctly, this can be put back origional.
If this does or does not help, please reply on here or email me at rollincbmods@yahoo.com. I look forward to hearing from you.
Dean
Rollin CBs
Mt. Vernon, TX
Feb 13, 2008 | Cobra 200 GTL DX 4-Channels Base CB Radio
Night watch lights are dimmer than when new
The dimmer pcb driver has a tendency to go bad in these radios contact cobra and ask them they migth be able to send you one if not write back to ma and Il see if I can get you one...Chia
Dec 15, 2007 | Cobra 150 GTL DX Base CB Radio
37 people viewed this question
 Grubhead
Grubhead
